Old 12-30-2012, 10:10 PM   #1
kellytheaker
01 heater cutting out on high
i have a 01 and after a bit of high heat it will cut out and if switched to a lower setting will come back on and shacking of the conections of the harness outside the box will switch it back on monentarilly , is there a consistant problem with the resisters for the heaters in this model or ? thanks for any input you may have thanks
kellytheaker is offline   Reply With Quote
Old 12-30-2012, 10:17 PM   #2
gmclowsierra
Re: 01 heater cutting out on high
Unplug your resistor. You probably need a new connector. Normal problem. Usually put new resistor at the same time. Check with your dealer there was a special policy on those.
gmclowsierra is offline   Reply With Quote
Old 12-31-2012, 01:59 PM   #3
hick
When you say resistor you are refering to the contorl knob it self correct? nplug that whole control pannel?
1989 3+3 2wd Dually. 454 BB. Factory loaded for the day, including Alcoa rims.
hick is offline   Reply With Quote
Old 01-01-2013, 04:30 PM   #4
gmclowsierra
On the passenger side under the dash there is a black panel two screws hold it up. Lower the panel. You will see the blower motor and resistor. The resistor has a relay built in. The connector im talking about is a seven or eight wire. You might not even be unplug it. Sometimes they melt fast together
Old 01-02-2013, 10:07 PM   #5
kellytheaker
thanks for the replies - going to look at the resister and connections thanks again .
