12-31-2012, 05:24 PM | #1 |
6 cyl engine ID assistance
Hi all .. I am new to the board as well as the new owner of a basket case 1962 Chevy C10 Stepside shortbed. She has a 3 sp manual in the floor and I was told the engine is not original and is a 292 engine. The engine is defiantly a straight 6. The engine ID # is F0409PC. Here is my problem .. I can't find a PC designation in any of the chevy engine code lists. Any ideas ? Thank in advance for the help.
Michael snyderm@charter.net Posted via Mobile Device |
12-31-2012, 05:30 PM | #2 |
Re: 6 cyl engine ID assistance
are the motor mounts in the sam location or offset. Any pis of it?
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
12-31-2012, 05:43 PM | #3 |
Here is the only picture I have handy ... the believe the motor mounts are in the same location / position.
12-31-2012, 05:47 PM | #4 |
we need a photo of the Other side ...the motor mounts and side covers...
Measure with a yard stick Mark with Chalk Cut with a torch Built it yourself, don't count on others to to do it for you or with you. It will never get done |
12-31-2012, 05:49 PM | #5 |
I'll get some other pictures and send them ASAP.. thanks !!!!
12-31-2012, 06:00 PM | #6 |
Here are the pics.. hope quality holds up.. taken with phone
12-31-2012, 06:05 PM | #7 |
230 or 250
12-31-2012, 06:19 PM | #8 |
someone looked at it and thought it was an L25 292 .. made from 77-88 and used in UPS delivery trucks .. but again the numbers do not match any charts.
12-31-2012, 06:26 PM | #9 |
Its definitely a 230 or 250. 292's had pushrod covers that were much taller than the ones on 230/250 engines. The fuel pump and engine mount positions also were swapped.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
12-31-2012, 06:38 PM | #10 |
Thanks .. so how do I ID which it really is ? 230 or 250 ?
The number behind the distributor is #F0409PC ... this doesn't match any code list I have found to date. |
12-31-2012, 07:12 PM | #11 |
The only thing I could find is that F is for Flint assembly plant, and the PC is 66-67 230. I found that on a Nova site, about halfway down the page in the left column.
http://www.tpocr.com/chevIIec.html
12-31-2012, 07:26 PM | #12 |
There's numbers all over the engine. There should be one behind the bottom of the dipstick. If you have a phone with a camera and flash, take a pic and see what you come up with. Mine is 2775308, which is a Made in Mexico 250ci.
Once you have the numbers, this site should tell you what the engine is ... http://www.inliners.org/casting/numbers.html
My truck ain't dead, it just smells funny. |
01-01-2013, 12:38 PM | #13 |
"Where were you in '62?"
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
