Old 12-31-2012, 08:41 PM   #1
wraprail
wraprail's Avatar
Motor Mounts
While acquiring parts for my T56 swap and needing motor mounts anyways I came across these and after looking at what is out there for the factory "clam shell" type they seem like crap and a poor design to begin with. They want you to peel apart a factory mount, remove the worn mount, install their mount and put the old crap back in. Lame.
I found these Camaro solid frame mounts from Moroso planning to weld them to my frame brackets and guess what. They BOLT IN! $30 from Jegs.
Then I went with a PROTHANE short motor mount early 70s Malibu/Impala ish also from Jegs.
They will end up being same height as stock block mount/clam shell setup, bolt in and way cleaner looking.
Anyone use this?
Mounts in either set of frame holes...
Bolt is an old cab mount bolt I cut down
Had to drill out hole in Prothane mount so I tapped threads in one end so don't actually need a nut.
wraprail is offline   Reply With Quote
Old 01-01-2013, 12:06 AM   #2
king-918
king-918's Avatar
Re: Motor Mounts
Posted via Mobile Device I just rebuilt the old ones not bad just time consuming
<----Christopher
Oh yeah I'm really a Toyota guy, but had some stuff sitting around.
Oklahoma
king-918 is offline   Reply With Quote
