My 72 build
Hi guys, This truck has been sitting in my father in laws shop for about 10 years and I figured it was time to start doing something with it. This will be my first "nice" build as all I have done before is bush/camping trucks. Plan is to be long and low. Proper satin black paint with lime green pin stripping and lime green smoothy style wheels. Heres the start...
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() I made some pretty slick patches for these holes by cutting a 3/8" bolt into 1/8" plugs. ![]() result, still needs a lil filler ![]() |
Re: My 72 build
Looks like you got a nice one to start with, good luck on your build.
I don't think we get smarter as we get older. We just run out of Stupid things to do. |
![]() Join Date: Mar 2010
Re: My 72 build
Welcome..Keep the build pics coming.
MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=423629 1969 custom/10 swb--SOLD 1968 swb 50th anniv.--SOLD 1967 camaro ss/rs..LS-6-speed, 16-year long project 1956 chevy nomad 1955 chevy 210 2-dr sedan 1978 el-camino ss 1-owner |
Re: My 72 build
Thanks guys! I patched the other door and riped out the interior yesterday. I was very lucky to find very little rust on the drivers side floor, I will have to make a patch for that and replace the front cab mounts. I will post pictures later.
Re: My 72 build
Ok so I patched up the passenger door today making sure to mark the holes I need for the new mirrors this time instead of just welding them all up!
![]() ![]() ![]() ![]() Some interior shots before I took it out ![]() ![]() ![]() I took out the seat and carpet and I am positive that the carpet was replaced at one time as it was glued to the floor. I also found some duct tape covering up some rust... not bad though ![]() rest of the floor ![]() annnnd the gas tank... Im not sure why I took this picture haha ![]() Can anyone give me an idea as to how involved it would be to do a body drop? I have found lots of information on how to drop the box but not the cab. I'm just weighing the options right now. Thanks in advance! |
Re: My 72 build
3rd day in, Took out the front metal cab mounts. I botched the drivers side a lil but nothing my welder won't fix. Cut out most of the bad rust and removed the fuel tank. I have decided to relocate the tank to the rear with the filler in the side marker light, but that wont be for awhile.
Re: My 72 build
Got out to the shop this weekend. Started striping the rear of the truck in preparation for my axle flip and C notch
![]() ![]() ![]() Kinda had a brain fart.... if I would have left the axle in for a little bit longer I wouldnt have to do this... ![]() ![]() ![]() ![]() Axle Cleaned up ready for paint ![]() ![]() My flip kit from DJM should be here on Wednesday So should have it all bolted back in this weekend... |
Re: My 72 build
So this arrived in the mail today...
![]() So I fit everything. I still need to adjust the pinion and what not. More pix for your viewing pleasure. ![]() ![]() ![]() ![]() ![]() ![]() Also started some work on the box ![]() Deleted the stake pockets cause it just looks cooler ![]() To be continued... |
Re: My 72 build
Looks good, welcome to the board.
Kerry My build thread. http://67-72chevytrucks.com/vboard/s....php?p=3657823 1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears 1988 Chev Extendacab 2010 Honda VT1300CS Sabre 2005 Buick Rendezvous wife's ride |
Re: My 72 build
Thanks Chevy88!
Ok got back to it this weekend, and I am starting to think I need to rename this thing the might as well truck. I will explain.... Was out in the shop staring at the truck, trying to decide my next move and I started to think. "You know it would'nt take much to pull the engine, then I could really clean the firewall... might as well" ![]() So I busted out the ole MF ![]() ![]() ![]() ![]() ![]() So once tha was done I figured it was time to pull the glass, then I figured. "Cabs already unbolted... Might as well pull the cab". ![]() ![]() I picked up some pipe for my C-notch ![]() And here is how I left it... ![]() Ill get the notch done this week some time, then its time to paint the frame! |
