Old 01-02-2013, 01:28 PM   #1
79Betty
79Betty's Avatar
Bell housing Questions
I have my 79 k0. 350 th350 203. Im going 465/205 setup but am wanting a hydraulic clutch. I am wonderin if there's a difference between hyd. And mechanical bell housin? And if anyone has a hyd one to sell i am deffinetly in need!!!! Been checkin the classifieds but can't find one. Thanks in Advance!
79Betty is offline   Reply With Quote
Old 01-02-2013, 01:40 PM   #2
Redcap
Re: Bell housing Questions
Yes, there is a difference in the bellhousings. The juice clutch ones are specific...and often rather expensive. I believe, however, that a bracket is available to bolt onto your mechanical bellhousing to convert it to juice.
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF
Redcap is offline   Reply With Quote
Old 01-02-2013, 04:04 PM   #3
79Betty
79Betty's Avatar
The one i want would be more expensive... Ill try n find that kit so i can use either one. Thanks!!
Old 01-02-2013, 06:57 PM   #4
geezer#99
geezer#99's Avatar
Get one of these and use any bell housing.
http://www.jegs.com/p/McLeod/McLeod-...50681/10002/-1
Old 01-02-2013, 07:28 PM   #5
79Betty
79Betty's Avatar
Man i ain't got that kind cash!!!!! Wow!! I found one on ebay it looks good. How strong is an all aluminium one? I've never had a straight shift before. This is my dd show off when i'm in front of girls not my use n abuser... That's my ranger >
Old 01-02-2013, 08:44 PM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Get a normal bellhousing and one of these brackets for the hydraulic slave cylinder.
http://www.summitracing.com/parts/add-715535
Much cheaper than a true hydraulic bellhousing. I've been looking for 6 months, cash in hand, for a decent priced hydraulic SM465 bellhousing and haven't found anything cheaper than the 250 dollar eBay ones. I am probably about to just buy that 40 dollar bracket above and a cheap mechanical linkage bellhousing.
Tx Firefighter is offline   Reply With Quote
Old 01-02-2013, 08:51 PM   #7
Redcap
If you were closer, I could hook you up with one.
Old 01-02-2013, 08:58 PM   #8
79Betty
79Betty's Avatar
Look at this on eBay:
GM CHEVY TRUCK ALUMINUM BELLHOUSING SM465 6263756 GMC 5 BOLT BIG OR SMALL BLOCK
http://bit.ly/Vwqzv9
I found this and it says it is for a 12" clutch... Muncie, t10... Will this work with my 465?
Old 01-02-2013, 09:00 PM   #9
Tx Firefighter
That's not the one I'm talking about. My truck is an 88 model R30 with SM465 and the bellhousing is much different than that. It has a built in bracket on the driver's side to bolt the slave cylinder to.
Like this one...
http://www.ebay.com/itm/160948357318...84.m1423.l2649
Old 01-02-2013, 09:02 PM   #10
79Betty
79Betty's Avatar
One i foun was 50 bucks and was just hopin it would work... Dang
Old 01-02-2013, 09:05 PM   #11
Tx Firefighter
I watch like a hawk. The first time a 100 dollar or less one pops up anywhere, I'm on it, assuming it's the style I need. All it will be is an eBay blur as I hit the pay button.
Problem is, while it's stock on my truck and mine needs replacing due to cracks in it, all of the rock crawler guys like them for building their trucks, so there's a good number of people in the market for them.
Old 01-02-2013, 09:07 PM   #12
79Betty
79Betty's Avatar
But would it work is what concerns me... Dont wana buy somethi that wont
Old 01-02-2013, 09:11 PM   #13
Tx Firefighter
I'm no bellhousing guru, but it doesn't have the pedestal on the side of it for the slave cylinder. That tells me it's a later style and will require an internal slave cylinder setup.
Old 01-02-2013, 09:30 PM   #14
Redcap
Like this one...
The spare in my barn is the later passenger side slave bellhousing, though still set up for SM465.
Old 01-02-2013, 10:44 PM   #15
Tx Firefighter
That makes me feel better. At least I know my perfect bellhousing isn't sitting unused half way across the country somewhere. I'm definitely looking for the one with driver side slave mount.
Old 01-03-2013, 12:12 AM   #16
79Betty
79Betty's Avatar
Y does it matter the side slave mount? Clearence issues? Is the driver side better in any way?
Old 01-03-2013, 12:52 AM   #17
Redcap
The good driver's side one is in my truck.
bellhousing
