01-04-2013, 10:49 AM | #1 |
Dash color
On the part of the dash where the speaker grill & defrost vents are should it be painted body color or is it a low satan black looking for the factory original look ? Thanks
01-04-2013, 11:49 AM | #2 |
Re: Dash color
That part is always the same color as the dash pad, not necessarily body color. And always satin. Definitely not Satan!
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
01-04-2013, 12:07 PM | #3 |
Re: Dash color
01-04-2013, 01:57 PM | #4 | |
Re: Dash color
The boys at GM made that part not shiny on purpose.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
01-04-2013, 02:57 PM | #5 |
Florida Edition
Re: Dash color
We painted mine body color then wet sanded the shine off of it. Mrein3 is correct, if you don't you will be seeing it in the windshield. This is also much easier to do without the windshield in.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
01-04-2013, 03:48 PM | #6 |
Re: Dash color
Mine is painted body color and I dont have any problems from it.
Posted via Mobile Device |
01-04-2013, 06:57 PM | #7 |
Re: Dash color
Mine also.
01-04-2013, 06:59 PM | #8 |
Re: Dash color
There never seems to be a real answer to this question. For what it's worth, mine was painted same color as the dash pad (Sandalwood).
71 K20 64 GMC mud truck |
01-04-2013, 07:22 PM | #9 |
Re: Dash color
Interior cab colors is something I have posted on before several times. The cab does have a flattened paint forward of the dash. It should be a similar shade to the cab interior trim in most cases.
The Ditzler color cards carry the application and paint codes keyed to the GM interior trim code on the back side. Look for (2) Upper Instrument Panel. Here is a 72 card as an example.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 01-04-2013 at 07:27 PM. Reason: never let your cat edit |
01-04-2013, 07:49 PM | #10 |
Re: Dash color
My bad on the typo but i did look at a unrestored truck today black dash pad & flat black paint on the dash
