01-05-2013, 04:03 PM | #1 |
PorterBuilt ECE 2 1/2" dropped spindles
** SOLD to TSHORT1. Thanks Toby! **
EDIT: 1/23/13: These are new ECE 2 1/2" dropped spindles. Test fitted only. The have some surface rust. 63-70 balljoints. The tie rod holes have been drilled out to be used with a Porterbuilt Dropmember rack and pinion setup. I will include the new upper and lower ball joints, plus the dust shields for $315 shipped in CONUS. Thanks,
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 02-02-2013 at 12:43 PM. |
01-05-2013, 05:31 PM | #2 |
Re: PorterBuilt ECE 2 1/2" dropped spindles
This is just for the spindles correct?
ANDREW 1972 Chevy SWB Cheyenne Super JANE http://67-72chevytrucks.com/vboard/s...d.php?t=462072 1972 GMC Jimmy PENNY http://67-72chevytrucks.com/vboard/s...d.php?t=735827 1968 GMC patina swb PEARL http://67-72chevytrucks.com/vboard/s...d.php?t=731315 1972 Chevy K20 BRUCE http://67-72chevytrucks.com/vboard/s...d.php?t=805788 |
01-05-2013, 05:51 PM | #3 |
That is correct. I added more to the ad to make it less confusing, .
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
01-05-2013, 05:53 PM | #4 |
Let me know if you wanna sell those control arms
01-05-2013, 07:33 PM | #5 |
GLWS!
I had a question if you don't mind answering. It looks like your running a porterbuilt drop member, what long tube headers are you running on your LS engine? Do they hang below the frame framerails? I know is off topic but if you can get me that info it would be greatly appreciated. Posted via Mobile Device |
01-05-2013, 07:46 PM | #6 |
So, will any stock size tie rod work on these with a bastard sleeve. Not familiar with porter built front.
01-05-2013, 07:53 PM | #7 | |||
01-05-2013, 08:02 PM | #8 |
I guess what I'm asking is will they work with a stock tie rod size. 67-70,71-72,73 up? Bastard meant different size on each end.
01-05-2013, 08:37 PM | #9 | |
01-05-2013, 08:43 PM | #10 |
Thanks man, I'll follow up On your build and ask how they worked out when the cab is on.
01-07-2013, 01:08 PM | #11 |
bump
01-09-2013, 09:46 AM | #12 |
ttt
01-10-2013, 12:55 PM | #13 |
Still have them? I have a full big brake drop spindle kit from porterbuilt that I dont plan on using. Only been installed for mock up. I need a smaller disc brake setup. I plan to use factory 71-72 disc brake wheels.
01-10-2013, 01:00 PM | #14 |
Yes sir, I've still got them!
01-10-2013, 02:58 PM | #15 |
from what I understand this is for the spindles with the ball joints for a 68 correct? if thats the case, I would be intrested in these if Rusty passes on them.
01-10-2013, 03:02 PM | #16 |
It has 68 balljoints, and the tie-rod holes have been drilled out to use Porterbuilt heym joints to attach to a mustang rack.
01-10-2013, 03:05 PM | #17 |
Ok I understand that the tie rod hole has been Drilled to 5/8 to accept the heim joints. Do the ball joints come with the spindles or is 230 shipped for just the spindles? Sorry if im making this difficult.
01-10-2013, 03:08 PM | #18 |
Just the spindles, I don't want to change the balljoints out. No worries, sorry I wasn't clear. I'll give Rusty Wrenches today to respond to whether he wants them or not. If he doesn't, do you?
01-10-2013, 03:13 PM | #19 |
I am in need of a set for sure, and from what I can tell ECE spindles are 249+ Shipping so you are giving a nice savings but I am a little worried about making a Tie rod fit in the larger hole. I wonder if 71-72 tierods would fit as they are suposed to be larger than the 67-70 I Think. Im doing a little research on that and will let you know as soon as I find that answer.
01-10-2013, 03:32 PM | #20 |
67-72 parts collector,…
These spindles are designed to work with balljoints and outer tie rods,... for the 1963-70 model trucks.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 01-10-2013 at 04:59 PM. |
01-10-2013, 03:51 PM | #21 |
I am going to have to pass because of the 5/8 hole being drilled straight through. Im being told that the top of the orginal hole was 5/8 but tappered to about 1/2 at the bottom. so a stock tie rod will not work with out filling the hole and machining the tapper back in to it, more work than Im willing to do. Thanks for your time and the great deal on the Lowering blocks I got from you. Good luck with the sale.
01-11-2013, 09:33 AM | #22 | ||
PM sent.
01-14-2013, 10:59 AM | #23 |
bump
01-17-2013, 10:23 AM | #24 |
New price, $215 shipped.
01-17-2013, 11:27 AM | #25 |
Rusty Wrenches do you still have the big brake drop spindle kit from porterbuilt, if so how much are you asking and do you have any pictures thanks.
