I have a 1968 C10 Stepside w/ a 350 crate engine that has 15000 miles and gear vendor overdrive. I just put a new Holley manual choke 2 barrel carb on it. Yesterday I was on the interstate and when I got up to 65mph it would hold but then start to jerk and go down to 55mph then to 50mph. It runs fine when I am on surface streets and going only up to 45mph but once I go to 60mph it starts to do it again. Today, I'm going to change the spark plugs.
Anyone Have any ideas or have experienced this same problem. -Jon Cheun |
Re: 68 won't go passed 60mph
Is the choke open?
Active Member
![]() Join Date: Jul 2007
Ignition could be the culprit or it may be fuel related. Weak fuel pump, restricted fuel lines, filter clogged up, or float problem -fuel logged or has hole depending on what kind you have.
Other possibilities are distributor or may timing. Hard to say until you start eliminating the possiblities.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
Active Member
Forgot to say welcome...
Also, don't know if you're aware of it but have a double post. You may want to delete the other one.
This might sound silly but is the fuel filter Inside the Carb in backwards...sound like its loosing flow...
Measure with a yard stick Mark with Chalk Cut with a torch ![]() Built it yourself, don't count on others to to do it for you or with you. It will never get done |
yeah, I was thinking the same sort of thing.. I had that issue with a wrong fuel filter in the carb, when it was tightened in, it crushed the filter restricting the fuel flow.
In my opinion, it works best to have the seat out so you have room to flop your body around while standing on your head. -ashx2 |
Thank You Everyone for your suggestions.
My fuel pressure gauge read only 1 psi when it should be around 5-7psi. I had a clogged fuel filter so I replaced it. Thank You for the welcome. Sorry if there is a double post. I am still learning how to use this forum. Here is a photo of my 68 Last edited by JonCheun; 01-05-2013 at 08:50 PM. Reason: add a photo |
NICE stepside love the paint
20' Daredevil (Ret)
![]() Join Date: May 2003
Nice truck! Glad you found the problem. And welcome to the site!
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
Sweet truck glad ya got it fixed!
Nice truck
Nate 1967 short fleet Project Blue Goose 'If it don't bounce back... heeheehee you go hungry!" Blues Brothers |
