Old 01-05-2013, 06:25 PM   #1
danheit
danheit's Avatar
Need Help on Bolt Size
Hey guys, I've been searching all over the net today and can't seem to find it anywhere! What size are the bolts that hold the mechanical fan to the water pump? Essentially, what size bolt goes into the pump through the pulley? My truck didn't have any of this installed when i got it, and even though I am swapping to an electric fan, I still need the pulley attached!
Oh yeah, it is a 1957 3100, with the "assumed" original motor, a 235.
1955 Chevy 3100 Task Force Pro Street - Sold!
1957 Chevy 3100 Task Force "Rat Rod" a.k.a. SLOTH - Sold!
1971 C10 Longbed factory A/C all stock 350/350
1979 Jeep CJ7 - Build date on the day I was born! -Keeper
2004 Expedition - Family Hauler
2007 Accord - Wife's around towner; I have more but not enough lines to post them!
danheit is offline   Reply With Quote
Old 01-05-2013, 09:05 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: Need Help on Bolt Size
They should be 1/4"x3/4" with a lock washer. As far as I remember the older pumps used a coarse thread but not positive
Old 01-05-2013, 09:30 PM   #3
Speedbumpauto
Speedbumpauto's Avatar
Any of the ones I've done, mostly V-8's use a 5/16 NF(24) on that water pump flange. That and the crank pulley to balancer are the few fine thread bolts on that vehicle.
Speedbumpauto is offline   Reply With Quote
Old 01-05-2013, 09:47 PM   #4
Divine 59
On a 235 the bolts will be fine thread.
Divine 59 is offline   Reply With Quote
Old 01-06-2013, 01:00 AM   #5
mr48chev
mr48chev's Avatar
Yes, I've never seen a small block pump with anything else.
I've never seen one with 1/4 inch bolt holes either.
In case you can't eyeball a bolt and tell it's diameter, outside of a few odd ball bolts the following almost always holds true.
1/4 inch bolt = 7/16 wrench
5/16 inch bolt = 1/2 wrench
3/8 inch bolt = 9/16 wrench
7/16 inch bolt = 5/8 wrench but often has a nut that takes a 11/16 nut.
1/2 inch bolt = 3/4 wrench
The larger sizes can be mix and match so I left them out.
My ongoing truck projects:
Old 01-06-2013, 01:20 AM   #6
dwcsr
Hollister Road Co.
dwcsr's Avatar
My mistake. Yes 5/16
Old 01-06-2013, 08:23 AM   #7
danheit
danheit's Avatar
So just to clarify, as it looks like we may have gotten off track as far as the v8's go, (sorry, I may be misunderstanding) on my 235 straight 6, The bolt that goes into the water pump pulley is a 5/16 fine thread? Just want to be sure as I have nothing to go off of right now - nothing there. I would really like to get the truck going with the cooling system working so that I can run it for longer than 3 minutes without cooking anything! Thanks for the help guys!
Old 01-06-2013, 09:29 AM   #8
crossfire84
crossfire84's Avatar
you could run a tap in the hole and get the fit, you should be able to do this with out a wrench so as to not cut a differant thread. startwith a fine thread tap, this works for me good luck.
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
crossfire84 is offline   Reply With Quote
Old 01-06-2013, 02:29 PM   #9
mr48chev
mr48chev's Avatar
Most studs have a fine and a course thread side. you should be able screw the correct threaded stud or bolt in with your fingers.
You could use a tap to clean the threads if they have rusted for some reason but usually you don't need to do that.
