Old 01-07-2013, 10:08 AM   #1
dieseldawg142
dieseldawg142's Avatar
quest for silence
after shouting at my wife in our crewcab for years, i finally decided to see if i could make it more livable. a big part of the problem- headers with 3" pipes & flowmasters, 38.5 swamps, & custom deluxe trim, a piece of jute & rubber floormat & nothing else.
dieseldawg142 is offline   Reply With Quote
Old 01-07-2013, 10:30 AM   #2
dieseldawg142
Re: quest for silence
after ripping out the interior, found the factory jute rusted to the floor
in good shape in the rear
next up, get it in the garage (also have to unbolt the garage door)
Old 01-07-2013, 10:50 AM   #3
dieseldawg142
have to trim around t-case shifter, my case is dropped for the lift, also filled some holes in dash.want to talk holes? 18 in roof (safari rack), 54 asst. holes in bed & box, 12 around the shifter,(had a console & fire ext. mounted there), 8 in rear of cab (assorted stereo equip.), 14 in dash, look at the top of the front fender-18 non stock holes (guess the prev. owner could'nt decide where to put that antenna)
trim & fill t-case
darn shop is to small-off with the doors
Old 01-07-2013, 10:52 AM   #4
bnoon
Originally Posted by dieseldawg142 View Post
LOVE the lightweight racing seat!
- 1981 Sierra 454, NV4500 swap
- 2006 Z06, 25k miles
- 1973 Nova - Project CarNova Virus on Youtube
bnoon is offline   Reply With Quote
Old 01-07-2013, 11:10 AM   #5
exfordman
this will be good subscribed!
I used to be a ford man... then i learned a thing or two
-81 K10 350, DD, will be mildly modified... eventually
exfordman is offline   Reply With Quote
Old 01-07-2013, 11:20 AM   #6
comegetsome2003
comegetsome2003's Avatar
So whats your plans to get it quieter? Its something i need to look into myself
1991 Square CCLB Dually...laid out on 22s with an old noisy 12 valve
comegetsome2003 is offline   Reply With Quote
Old 01-07-2013, 11:31 AM   #7
dieseldawg142
filled the hole & stripped & painted floor & rockers with 3 coats por15 plus 2 coats chassis black as well on rockers.also laid in some fatmat & new wiring for the seats, console, amps, subs, & speakers
Old 01-07-2013, 11:39 AM   #8
86c20
86c20's Avatar
my 6.2 was so f-ing loud it was dumb. i got some of that sound pil and stick then the pading and then the rubber flooring. also whent in the doors and did some spray under coat. new shifter boot. sounds good now but need felts
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph
1985 k30 "the ice cream truck from hell" no rust az truck
197-8??? c30 "ramp truck" 454
1978 monte carlo 350 350th with 2.73 gears. no rust. sc car
86c20 is offline   Reply With Quote
Old 01-07-2013, 11:43 AM   #9
dieseldawg142
now i'm laying in some closed cell foam. glued this to the fatmat with 3m spray adhesive
now the real big part of noise reduction- mass loaded vinyl, & yes it's heavy, just over a pound per sq. ft & i have 100sqf. i also glued it down & taped the seams. this stuff is heavy, but suprisingly flexible
[ATTACH]Name:  076.jpg
Size:  46.0 KB[/ATTACH]
Old 01-07-2013, 11:49 AM   #10
dieseldawg142
yeah bnoon, should have left the drivers seat in untill i got it in the shop.
keep reading comegetsome, my computer skills suck ( 1 finger typer), so i'm a little slow
Old 01-07-2013, 12:08 PM   #11
dieseldawg142
what i thought would be the easiest part turned into the hardest. because we use our crew to haul our camper & quads, carpet was out of the question, so i picked up a new vinyl mat from ACC. it's 2 1/2 times as thick as the stock rubber, awesome quality, but laying it down in the winter (even with a propane shop heater) is a chore it's so stiff. i spent a week with a commercial heat gun getting it to lay reasonably flat.
time to put the interior back together. it is green & tan, but i'm going to go tan & black as i can afford it.seats going back in
Size:  49.0 KB Name:  083.jpg
Old 01-07-2013, 12:21 PM   #12
LEEVON
Moderator
LEEVON's Avatar
Looks great, I'm curious about the results. Where did you get the closed cell foam and mass loaded vinyl?
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 01-07-2013, 12:30 PM   #13
dieseldawg142
bought it at the SOUND ISOLATION STORE, sorry, i don't know how to load links, $120 for a 100 sq ft roll, & did i mention heavy?-$60 to ship
Old 01-07-2013, 12:44 PM   #14
dieseldawg142
the fatmat is more for panel resonance, the foam & mlv are the real ticket to block noise. i also sprayed some expanding foam in the roof, (don't have a headliner to cover anything), & if you look at the fatmat pic's, you will see i also put a second shifter boot out of a dakota, as well as the new hurst boot on the t-case shifter, (205 whine at 55), & had some extra mlv, so i doubled it up on the front floor, also re seam sealed all panels, plus a piece of jute that came with the floormat.i'll see how it goes when i'm done, but with what i had, anything should be a big improvement
Old 01-07-2013, 01:10 PM   #15
dieseldawg142
my doors, like the rest of the truck, have some extra holes to weld up before anything else. once i got that addressed, por15, fatmat, & mlv in them
i'm hoping by the time there done, my new black dashpad will be here
Old 01-07-2013, 01:44 PM   #16
dieseldawg142
a couple of posts back i screwed up. i meant to say i want to change my interior to GREEN & black, not tan & black. that being said, i tried my hand at painting plastic for the first time. my console used to be tan, now it's
in my never ending quest for quietness, i lined the cup holders & inside with rubber to keep our pop & keys & stuff from rattling.also for the sake of quiet, i put a cig. lighter outlet in it so the kid can plug his video games in (works better then duct tape!). if i can scrape up some money for armrests, i think i'll paint the door panels to
Old 01-07-2013, 02:21 PM   #17
Hulk Will Smash
Hulk Will Smash's Avatar
What seats are those in the rear? That's exactly what I've been looking for. And custom brakets or are they stock from something? Thanks!
'87 R30 Crew Cab Dually
It's 11 PM, do you know where your IAC pintle is?
Hulk Will Smash is offline   Reply With Quote
Old 01-07-2013, 04:13 PM   #18
Rubble
Great job,dieseldawg!! When your done,can I send my crew down to you!! It's not lifted yet,so will fit into your garage easier....
1977 Chev C30 454/465/14ff DRW
1974 Chev C20.350/465/14ff
" Rock n Roll ain't noise pollution"
Rubble is offline   Reply With Quote
Old 01-07-2013, 05:46 PM   #19
dieseldawg142
ahem, cough, cough, let me clear my throat, their leather, power, heated, king ranch seats out of a ford,- but they were CHEAP & in perfect shape. those are stock brackets. there's 6 bolts (4 on the 60, 2 on the 40), the 2 fronts hit the factory holes, the 2 back ones missed by a couple inches, made some quick 3/16 brackets, & the 2 middle ones i had to drill out. they do go threw the factory cab support like the other ones, but i also put 3/16 fish plates on them as well
Old 01-07-2013, 06:00 PM   #20
dieseldawg142
hey, thanks rubble. i was actually just wandering in alt. tinkerings admiring pickup67man's awesome garage. i'm hoping to build something similar but a little smaller, then small or tall, bring them all!
Old 01-07-2013, 07:02 PM   #21
LEEVON
Moderator
LEEVON's Avatar
Don't sweat it. There is another guy in this very forum with King Ranch seats in his truck, can't remember who. They look great though.
Old 01-07-2013, 07:14 PM   #22
Hulk Will Smash
You guys just made my day... My kids are just about big enough to get out of their booster seats and I've been plotting on how I'd make myself some rear headrests to protect them in the event I got hit in the back. That seat is perfect. Thanks and keep up the great looking work!
Old 01-07-2013, 07:53 PM   #23
dieseldawg142
they flip up & fold down too. i dont know if you can see the booster seat marks still on the 40, my kid gave his up last yr. and him & his friends are pretty much the only ones who sit back there, so it was gr. 8 all the way. like i said, they were cheap, a couple of hours labor for them was the price & their worlds above the old clapped benches that were in it
Old 01-08-2013, 11:27 AM   #24
bnoon
Nice job! I sound deadened my Silverado SS with MLV on the floors too, but the biggest improvements by far came from doing the cab's back wall and roof with the Dynamat. Before I learned about MLV I used lead sheet that's usually used to line hospital walls in their x-ray rooms. Same idea as MLV, maybe just a bit heavier, but quite a bit harder to get to lay flat.
Old 01-08-2013, 11:28 AM   #25
motornut
78K & 79C Jimmys
motornut's Avatar
sounds like it will be quiet for sure,nice!
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
