01-07-2013, 10:19 PM | #1 |
Switching crew from 8 to 5
What all is involved in changing a c30 to 5 lug?
1969 chevy camaro Z28 #matchin Factory 4wheel disc 1969 chevy cst10 big block overdrive 5/7 drop dog dishs 1997 gmc yukon 2 door 2 wheel drive project 4/5.5 22s 2004 gmc sierra dually 4/4 lowering daily driver |
01-07-2013, 10:20 PM | #2 |
Re: Switching crew from 8 to 5
buy a half ton truck
01-07-2013, 10:24 PM | #3 |
I'm going to air ride and tub the rear so I'm going to go 9in rear so it wouldn't be worth buying a parts truck
01-07-2013, 10:26 PM | #4 |
if your gonna do that, idk, spindles on out would make sense
01-07-2013, 10:35 PM | #5 |
At the body shop.
We just did one. Got 1/2t spindles had them reamed for 3500 ball joints. And changed brake hoses. Theyre different on the caliper side. And a 1/2 rear axle used a spicer cross over U joint. 1350X1310., did it in weekend.
http://67-72chevytrucks.com/vboard/s...d.php?t=552412 Posted via Mobile Device
" That didnt make it any newer " " Dont antique the equipment " Last edited by KQQL IT; 01-07-2013 at 10:49 PM. Reason: link |
01-07-2013, 10:37 PM | #6 |
Go to the junkyard and pull the upper and lower control arms and 5 lug spindles/hubs/brake calipers and bolt them on ur truck.....i'd prolly grab some new inner and outer tie rod ends from parts store....and most likely balljoints cause its doubtful you will get lucky enough to find one with new/good ones
1991 Square CCLB Dually...laid out on 22s with an old noisy 12 valve |
01-07-2013, 10:49 PM | #7 |
I'm going to be air riding with probably porter built drop member. So I would need drop spindles?
01-07-2013, 10:51 PM | #8 |
If you are goin with a drop member just order new drop spindle....comes with new arms....you will need new rotors/bearings and new calipers/brake lines and you will be set...drop member come with rack so your steering is took care of
01-07-2013, 10:56 PM | #9 |
Are racks worth having?
01-07-2013, 10:59 PM | #10 |
Yea rack and pinion steering is gonna be alot tighter
01-07-2013, 11:04 PM | #11 |
But the ones I've seen they don't steer is far side to side
01-07-2013, 11:13 PM | #12 |
So here's my plan. I want to lay frame on 20s with a 31/18r20 on the back. I know my dads 66 has a maverick 9" under it and it had 29/18r15s on it with just tubs it wasNt laid out though just lowered. If I don't have to use porterbuit to do this that's be great anything to save money is a plus. So what all will I need to do so? And does someone make a 3 or4 link set up for a third member?
01-09-2013, 09:47 AM | #13 |
is there a way to make them 5x4.75 bolt pattern?
01-09-2013, 10:50 AM | #14 |
If your going to dropmember the front all you need is 1/2 ton spindles and let nate know what your doing so you get the right ball joints.The rear you could probably get away with a weld on rear dropmember ask nate first about your 9 inch.Or a weld in kit from http://www.scottshotrods.com/4link.asp On the bolt pattern take a look at http://www.kplinks.com/product.php?p...&cat=95&page=2
01-09-2013, 10:52 AM | #15 |
Some local guys tell me you can put a s10 hub on a c10 spindle and it will work to swap to smaller lug pattern....never tried it though
01-09-2013, 10:55 AM | #16 |
the 9" i have is 5x4.75 the normal truck is 5x5 the wheels i want are 5x4.5 or 5x4.75 only. which is a car pattern. unless someone makes 5x5 wheels that are 20x14or15
