#351 |
Re: 67-72 Chev Crewcab Build
Here is a good tech tip for those of you can't stand the squeeking whenever your wipers are on:
I thought that just greasing the linkage cups would take care of my problem, it did not. So after removing once again, figured out that is was the actual pivot assembly or whatever you call it. This is a non-serviceable part, at least it wasn't. As you can tell by the pictures a small drill bit in about the middle of the assembly allows you to use a mini grease gun to add grease and squeek is gone. ![]() ![]() ![]()
Randall Cowboy the 70' Crew Cab The DUKE K50 Crew Cab 2nd gen build thread Drill Sergeant The Ponderosa |
#352 |
Hey guys thought I would update you on my 2nd gen crew cab build. The cab is basically done now, I'm just doing little touches up here and there will be ready for a new home by Saturday.
I will like your opinion on something. I have had a few requests for a two door extended cab. Of course you know that I would build it to look factory if they every made one, I would love to get your input...yeah or nah. Pictures below our currently being voted on, on our facebook (rtechfabrications) for a t-shirts we are having made up for the Portland Swap Meet. Would love your input on this also. I have started stretching a longhorn frame the same way I stretched the frame for my truck. I'm building a two wheel drive one ton dually short bed frame. Well begin working on that next week and then starting another crew cab. PS; Jeremy how is your crew cab project going? PS; Diesel Wrencher how is your twelve valve project coming? ![]() ![]() ![]()
#353 |
I like the middle picture!
Posted via Mobile Device |
#354 |
I think an extended cab would be awesome! The hardest part would be getting the rear windows to flow with everything else and look like they belong there. I see lost of really nice extended cab conversions where everything looks wicked except for the actual window itself. But if anyone can make it look right, it's you
![]() Posted via Mobile Device
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
#355 |
Absolutely have to agree ^ if you could actually build the rear side windows with the look of the front that would be amazing it might have to keep the round from the tea of the window and make it on both sides up top to look correct I'd have to draw it out to see that vision though
![]() Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289 - Dylan (209)-985-7721 |
#356 |
6>8 Plugless........
![]() Join Date: Sep 2007
I say the middle one too.
On the rear window, I've always thought they would look cool with a window the same shape as the front door except with a squared off front. Then maybe take a door frame top part, split in half and use as trim so it will look like the front window. I don't know how it'll actually look for real though. ![]()
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#357 |
Well, the Suburban project is coming a long real nice. I haven't messed with the Longhorn in a while. But, once this suburban is out of here it's back at the Longhorn. How have you been doing?
#358 |
I'm curious to see what a crew cab short would look like...I know there was a "tahoe" build on here a while back that looked pretty deadly.
1967 K30 4x4/12v Cummins/getrag/D60/D70/355s 1967 GMC suburban 4x4/LS swap 5.3/4500/205/10 bolt/14 bolt full floater 1963 C10 reg cab long box 1970 Chevelle 1968 Biscayne 2dr post "...there is no excuse for what I am about to do, but dangit....it's gonna be fun!" |
#359 |
Drew's is a crew short if you're wanting to look at pics of one.
#360 |
Cool Truck
This is probably my favorite extended cab conversion
1968 Chevrolet C20 Longhorn "Cool Truck" 1937 Chevrolet Pickup - Project Looking for a patina'd 68 50th Anniversary longbed |
#361 |
67-72 parts collector,…
![]() Join Date: Nov 2002
Looks good^^^
#362 |
where is that one?
#363 |
That window is exactly how I was trying to describe what I thought of doing.
#364 |
It's a very long thread but a very awesome build!
http://www.67-72chevytrucks.com/vboa...d.php?t=426382
#365 | |
Junk Yartist
oh yeah, i got someone to make 6' 3" rockers but they wont give me a quote on the phone! Posted via Mobile Device
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
#366 | |
I can't wait to see what long doors look like on a crew cab. Have you started your frame yet? My second cab will be completely finished tomorrow, I will be starting two new cabs next week, one will another four door and the other will be an extended cab ( like the green dually above) that is definitely the way to do an extended cab.
#367 |
I just want those center caps
#368 |
does anyone know what rear windows they used on the green extended cab?
i have been thinking about doing an extended cab as a DD, i would really like to see your version on it |
#369 |
I finally found the tires that I was looking for. So I have finally been able to put my white wheels and hub caps on my truck. I also chose to put beauty rings on it. All that I have left now is to install the headliner which will be the same kind of headliner that is in the suburbans. In addition to that I will be coming up with some kind of way of concealing a sound system, so that it can be heard but not seen.
Finally got the t-shirts back that we will be selling at the Portland Swap Meet. I think they turned out great (see picture below). ![]() ![]() ![]()
#370 |
Truck and t-shirts look great!
#371 |
Chevy Enthusiast
Wow it looks amazing!
Tony 1985 GMC K2500 restoration Project: Rust, White & Blue 1989 Chevy R3500 CC Cummins & 4X4 swap some day... 1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress) |
#372 |
67cheby
![]() Join Date: Sep 2008
Very nice work !
#373 |
Still Learning
Super looking truck!
#374 |
![]() Join Date: Dec 2004
an absolute amazing work of art
21 2500hd duramax 58 apache HILLJOB GRAPHIX--for all your graphic needs My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=542497 LS ENGINE SWAP INFORMATION THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=377348 4l60 to an NP205 http://67-72chevytrucks.com/vboard/s...43#post3697343 |
#375 |
Very nice!
