Old 01-09-2013, 10:55 PM   #326
ryanroo
ryanroo's Avatar
Re: 72 k20 project
Originally Posted by Dieselwrencher View Post
On the Kelderman air ride, how do you mean by clunky? I've installed some of their kits and at first I thought it was over priced BS. But after I drove the first truck with the 4 link rear air ride, I was totally surprised. I feel their kit was heavy duty enough to do what ever I'd want to with a pick up.
i have no reason to doubt that it works, its just way to "bolt on" for this nutcase. i didnt mean it was clunky in operation, just that it looks.... i dunno how to explain it. i'm gonna do it my way and then ill be happy.
On the air compressor, used usually $400 up. A reman from holset is $1700 and a reman bendex was $750 last time I had to get one. The biggest issue is they use a different power steering pump that you will have to regulate down, and then find another source for vacuum for blend doors if you don't go with a vintage air kit.
i can stomach 4 bills for a used one if it works.(so,, if you happen across one...) i'm sure one of the hydro assist companies could detune the pump pretty easily. they have an internal bypass valve usually that just requires a different spring. the vacuum thing is a head scratcher. i wonder if there is a way to use the vacuum produced by the intake suction of the compressor... i doubt it makes much or any vacuum though. maybe ill just pony up for a decent electric and be done with it....
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 01-09-2013, 11:05 PM   #327
jbclassix
Junk Yartist
jbclassix's Avatar
Re: 72 k20 project
My buddies 2000 S10 had an electric vacuum pump on it... I have seen some other cars with electric vacuum too
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 01-09-2013, 11:07 PM   #328
SCHRUMGMC
SCHRUMGMC's Avatar
Re: 72 k20 project
Why do people add Modern Day beds to their trucks ?
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline   Reply With Quote
Old 01-09-2013, 11:43 PM   #329
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: 72 k20 project
You could incorporate a belt driven from any 7.3l, or an electric one found on 6.0 trucks.
I hear you on the Kelderman kit. I'd definitely like to put air ride on one of my trucks. But first I need to get one more running.
Ryan
1969 Chevy milk truck
Old 01-09-2013, 11:43 PM   #330
Dieselwrencher
Re: 72 k20 project
I have no idea. But Ryan's truck sure doesn't have one on it...................
Ryan
Old 01-10-2013, 12:14 AM   #331
ryanroo
ryanroo's Avatar
Re: 72 k20 project
i was laying on the couch after i typed that and remembered the electric pumps on various cars... not so much of a head scratcher as i originally thought.
Hahaha. i'm pretty sure the truck i snatched my bed from was a 72 so it is a dead match!
Ryan
72 K20 12v build
Old 01-10-2013, 09:25 AM   #332
RatRod68
RatRod68's Avatar
Re: 72 k20 project
I am serious on the statement of if you build it, build 2. I've got money. not much, but some!
build Threads:
Nasty 68 C10. My lil hotrod
Leftovers 68 C20
D-Ranged Ford Ranger on steroids
Semper Fi
RatRod68 is offline   Reply With Quote
Old 01-10-2013, 06:44 PM   #333
Dieselwrencher
Re: 72 k20 project
I'll sell my 72.
Ryan
Old 01-11-2013, 08:39 AM   #334
RatRod68
RatRod68's Avatar
Re: 72 k20 project
I'll sell my 72.
i just want the airbag setup!
build Threads:
Leftovers 68 C20
Semper Fi
Old 01-11-2013, 09:56 AM   #335
SCHRUMGMC
SCHRUMGMC's Avatar
Re: 72 k20 project
Yeah haha, man I just cant understand why
1971 GMC Sierra
1959 GMC 100
Old 01-11-2013, 10:15 AM   #336
sduckworth13
sduckworth13's Avatar
Re: 72 k20 project
Your build looks great, all around nice work.
Scott
sduckworth13 is offline   Reply With Quote
Old 01-12-2013, 03:56 PM   #337
BigRed76
BigRed76's Avatar
Re: 72 k20 project
Originally Posted by ryanroo View Post
so, to replace the crap stock stuff, i whipped out a pair of these today. bushing tubes are 2" .250" wall DOM. the frame has a 1.875" hole punched for clearance around the stock cast piece. i turned the tube down to slip fit tightly into the stock hole in the frame and will locate and holesaw the other side in the boxing plate after it is firmly in place. the bolt sleeves are just .750" .120" wall DOM faced on the lathe for the cool guy effect. and mostly just because i was there. i will use a normal spring eye bushing for the new upper shackle bushing, hopefully greatly increasing the durability with the added weight of the cummins.
Are those universal bushings you used for the frame? Where did you get them?
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 01-12-2013, 06:35 PM   #338
ryanroo
ryanroo's Avatar
Re: 72 k20 project
Thanks!
They are 1.5" t-bushings. I think i bought them from ruffstuff. They are pretty standard but they are considered leaf spring eye bushings.
72 K20 12v build
Old 01-12-2013, 06:39 PM   #339
SCHRUMGMC
SCHRUMGMC's Avatar
Re: 72 k20 project
Oh wow thats neat
1971 GMC Sierra
1959 GMC 100
Old 01-19-2013, 10:37 PM   #340
ryanroo
ryanroo's Avatar
Re: 72 k20 project
So... i havent posted much in the way of pics, most of what ive been doing has been seen before. but here are a few of some of the end results
and i am having some fitment issues with the DS rocker. the PS looks like it will line up better, but i wont know till i hang the door.
Does anyone have GM rockers?
i have the door pushed in all the way. i didnt spend much time trying to adjust this, so it may be able to be better
the cab corner matches the door very nicely. the rocker just seems to short
72 K20 12v build
Old 01-19-2013, 11:56 PM   #341
boonedogs72
boonedogs72's Avatar
Re: 72 k20 project
My repop rockers fit the same way....
boonedogs72 is offline   Reply With Quote
Old 01-20-2013, 10:09 PM   #342
ryanroo
ryanroo's Avatar
Re: 72 k20 project
So i fiddled with the rockers today and got them zip screwed in a much better way. they will work pretty good now. i also think i am going to try the pliogrip epoxy glue to attach the rockers.
not a real good look at the fitment, but it also looks like the gaps will turn out pretty decent. plenty good enough for me.
i also added another emblem to the wall. i think i found something to collect. i already collect books(i read A LOT and try to buy a new book every week or so) but i really like decorating my wall with these...
ryan
72 K20 12v build
Old 01-20-2013, 10:39 PM   #343
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: 72 k20 project
Nice work! I'm told doors can be a real bear to align - is it possibly the doors not the rockers that are giving you grief?
BTW - Have you read any Cormac McCarthy? If not check out Blood Meridian or The Crossing...
Old 01-20-2013, 11:17 PM   #344
ryanroo
ryanroo's Avatar
Re: 72 k20 project
the doors line up real well with the contour of the cab, so i was more irritated that the rockers didnt stick out far enough. im sure the doors will be fun, but i plan on having the body guy help me out if i cant get the panel alignment done myself. they seem to be into masochism. anyhow, i got the rockers to come out a little without affecting the other important relationships. i think it was just stamping differences from stock.
i haven't read any McCarthy, but i will order some next time i hit the bookstore!
72 K20 12v build
Old 01-20-2013, 11:25 PM   #345
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Re: 72 k20 project
Looking real nice! But did Mr. Fab just say hes going to use glue to attach the rockers?
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 01-21-2013, 12:46 AM   #346
ryanroo
ryanroo's Avatar
Re: 72 k20 project
Hahaha...
bodywork doesnt feel like fab to me. the metal is to thin.... case in point, i cant stop thinking about the links/bags for the rear, and i think i am going to order the link tubing soon. i just need to see if we can single point internal thread 1 1/4"-12 deep enough with our tooling at work or if i should just use tube adapters... its gonna be fun to make some beefcake links
72 K20 12v build
Old 01-21-2013, 01:35 AM   #347
Dieselwrencher
Re: 72 k20 project
I had the same fitment issue on my rockers too. Slice and dice then weld.
Beefcakes, ehhhhhhhh?
Ryan
Old 01-21-2013, 02:15 AM   #348
jbclassix
Junk Yartist
jbclassix's Avatar
Re: 72 k20 project
I have the same garage door opener... That's probably the most important thing you will ever remember me sayin.
-Jeremy
Rebuilding an NP205
Old 01-21-2013, 09:39 AM   #349
gerfunken
gerfunken's Avatar
Re: 72 k20 project
I tell you, those garage door openers are pretty styling...
Anyway, been lurking around the build for a while, figured I'd jump in. Love the K20's....
-Scott
1972 Chevy K20
Picture Gallery
Build Thread
1930 Chevy AD
Picture Gallery
1929 Ford Model-A
Picture Gallery
1975 Triumph TR-6
Picture Gallery
Old 01-27-2013, 10:39 PM   #350
ryanroo
ryanroo's Avatar
Re: 72 k20 project
a few more bits of stuff done. i have a bunch of weld finishing to do and the cab will be ready for the blaster and painter/body guy.
i cut way more out than was rusty, just to make sure there was nothing bad happening close to the area that was rusted through. i douched the in between area with rust convertor as best as i could, but there was nothing more than surface rust anywhere else
hopefully a minimal amount of filler will be required
rockers are all glued on. i am really glad i decided to try the panel adhesive. i used LORD Fuser. i still need to buff the ooze off but it is slow to cure in my cool garage
got the firewall converted to A/C and patched the little spot of rust in the blower motor area.
and i patched the lower cowl area. the inside was pretty clean but it had a bit of rust through in one area. the inside was covered in rust converter as well
72 K20 12v build
