01-11-2013, 10:45 AM | #1 |
Ididit column for 47-54
Ive been looking at picking up an ididit column for my truck. Ididit's application specific column for my truck says its a 1" DD. From everything ive seen it looks most people use 3/4 DD. It will be connecting to the t-bird rack that came in my scotts ifs. As im sure you know itermediate shaft space isnt exactly plentiful on these trucks with a sbc. Anybody know what the deal with the 1" vs 3/4"s is?
Ididit part # 1120651020 is the one im looking at. It is no key and floor shift. Anything else to consider? Posted via Mobile Device
My Lost and Forgotten build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=442712 |
01-11-2013, 11:51 AM | #2 | |
Re: Ididit column for 47-54
1.1 inch d/d x 3/4 d/d u-joint for the column 2.3/4 x 3/4 d/d u-joint for the frame 3.3/4 x 36 x 3/4 d/d u-joint for the power rack 4.3/4 d/d shaft for the steering 5.3/4 bung for the frame to secure the hime 6.3/4 hime 7.Ididit tilt steel column 8.Column drop 9.Floor mount I can help you out for sure on the above list of parts you will need for your truck.For the 1 inch d/d on the column this is what we have been installing in our shop for over 15 years. For Ididit this is the only column out there that comes with a lifetime warranty.This is the only column that is made in the USA 100%.This column also has 100% gm internal parts in the column. Justin |
01-11-2013, 12:01 PM | #3 |
Now there's some customer service for you. You didn't even call them and they heard your needs & responded!
Posted via Mobile Device |
01-11-2013, 12:10 PM | #4 |
Awsome!
01-11-2013, 12:35 PM | #5 |
Justin takes care of his customers!
01-11-2013, 03:57 PM | #6 |
Justin nows his stuff and has some of the best customer support!!
01-11-2013, 06:56 PM | #7 |
Thanks Justin, I didnt realize the 1" to 3/4" universal is how it was done. Ill shoot you an email here in a bit.
Anybody know if the stock column drop will work with this column? The billety stuff doesnt really go with what ive got in mind.
01-11-2013, 06:58 PM | #8 |
The stock column drop will not work with the new ididit column.
We have our drop that is a tubular s.s column drop looks great take a look at it on our site www.scottshotrods.com |
01-11-2013, 09:00 PM | #9 |
What is the diameter of the column where the column drop bolts up?
Are the joints you supply borgeson?
01-11-2013, 09:18 PM | #10 |
[QUOTE=PurdueSD;5811413]What is the diameter of the column where the column drop bolts up?
Are the joints you supply borgeson?[/QUOTE Two inches dia One more thing you can do if you want something to be more in line with what you are building.You can take some 3/4 dia 120 wall tubing and tig weld these to your column and this will act as your drop and then you will need to weld on a mounting plate.You should use 3/16 plate and this will mount to your dash or the mount you will make to secure the column. Just a idea Justin |
01-11-2013, 09:19 PM | #11 |
The u-joints we sell
1.Uni-steer 2.Borgeanson |
