01-13-2013, 09:14 PM | #1 |
04 Denali cluster troubleshooting question
Hey GM techs!
Not the typical stepper motor failure. A relative has an 04 Denali and the cluster has an intermittent total failure. No LCD readout, no gauges move. Will work for a day, then not. Was out for a few weeks recently. It was inop when I started looking at it today. Pulled the cluster, opened the back, took a peek at the back of the circuit board and didn't see any obvious solder cracks at the connector pins. Found this wiring diagram online; http://www.justanswer.com/chevy/36yc...e-cluster.html I'm guessing the power/ground is the same in this diagram as it would be for the Denali. I have constant 12v @ B11, switched 12v @ B9 and ground @ B12 The serial data lines show a flicker of A/C voltage (<1v) when the key is switched on (I consider that normal) Cluster did start working again after I called it a day and plugged it back in. Stayed working thru a few key cycles and the car left. I'm thinking that something on the power supply in the actual cluster is taking a dive, but I want to make sure I'm not missing something on the vehicle side.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
