#5776 |
Re: What did you do to your truck today!
Sits nice doesn't it.
#5777 |
Mine?
Ya and the ride is smooth and solid, well pretty smooth actually...for a two inch lift.
1968 4x4 Frame, with a 67 Cab and Bed A Shorter Step 1999 Dodge 2500 Cummins Diesel |
#5778 |
Only a 2" lift, it actually looks like more.
#5779 |
Does dreaming about it count???
NAME: TRAVIS TRUCK: BRUISER 71 C/10 SWB 3.5/5" drop 4.11 GEARS. F.A.S.T. BBC 408 496hp/479ft/lb JAKES 4L80E TCI TCU PTC 10.5" 2800 STALL My build thread: http://67-72chevytrucks.com/vboard/s...30#post5779530 |
#5780 |
1. I took out some trashed 6x9 that where cut into the door panels (going to be replaced anyways) painted them black just because and added a 1 off custom high speed cup holder.
2. Slaped a MDF wooden box toget her to add radio so I wouldnt have to cut my dash (temp fix), found the shift knob at Walmart thought it was kinda cool and better looking than the broken $x$ knob that I had. |
#5781 |
Got a knob from autozone kinda like that for my TC shifter.
![]() Posted via Mobile Device |
#5782 |
What did i do to my truck today.. I tried to figure out why my choke wont open to 90 degrees when warm...
#5783 |
72 C10 stock for now |
#5784 |
Its alive!!! After a great weekend working on the old girl she fires right up. Took her for the madin drive around the block no worries. Ran to the loacl mall that has a tag and tile shop and paid the additiaol 60.00 fee but was worth it. Put the tags on and headed out for a saturday night drive. Well the New Process 203 transfer case soon put a damper on my weekend. Seems the PO did not disclose all. It makes an ungodly noise. Going to check a few threads and hope its a quick fix. But doubt it. Any way it runs!
#5785 |
RAT1968 '68 Cab/'71 Parts
Nice day today.
Went out and uncovered her. Fixed the tach wire that'd come loose from the fuse panel, lined up the body lines for the hood. Lubed the hood hinges. Made this little video to check before I change the stance around a little. http://www.youtube.com/watch?v=N_ugg...ature=youtu.be Tweeked down the fuel mix a 1/4 turn, 'cause it was a little rich. Took some stills for the same reason as above. I bought 1.5" spacers for the rear. The 1" on the back I'll put up front. They are really high quality and I've been running these for a while. http://tinyurl.com/8czblhz Finally, I went for a little ride. I determined the metallic "boink!" I was hearing from time-to-time that I thought was somewhere in the suspension is the fuel tank. It's bolted in solid, but I guess I must need to put some spacers in or some rubber insulator, because I get the clunking noise every once in a while with some body "flex" going over bumps.... Here's one I Photoshopped moving the rear wheel out .5" like it will be with the new spacer. And then, the "Before". All around, a good day.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
#5786 |
Not a dagum thing!................
SOLD -77 CHEYENNE SWB, LS SWAPPED -1976 SILVERADO YUBA GOLD/NEUTRAL (2-TONE) |
#5787 |
not acutally too the truck but for the truck the bb is out of the pontiac
![]() ![]() ![]() ps....anybody wanna buy a pontiac ventura sprint ![]()
81 camaro 355 4/spd 342 posi my first love ![]() 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
#5788 |
I walked out to it , fired it up and drove off in a faint haze of oil smoke.......
Nothing new here , just another of the MILLIONS of old CHEVROLET & GMC trucks doing their thing , while those Brand 'F' junkers rust quietly in the backyard ![]() ![]() I am collecting evermore parts for some upgrades and sorely needed up fixin' , I'll try to take before & after pix to share when I finally get a rountuit . Meanwhilst , I'm getting *serious* Dollar value out of a junk light duty pickup truck just as God an Generous MotorsCoporation intended . BOWTIES 'TILL I DIE .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH ![]() |
#5789 |
Clean the other guys trash out of the bed, started re wiring until my soldering iron stopped working, new 2ga battery cables, throttle return spring bracket, pulled the right rear axle and checked the brakes (needs now ones, and bearings, and seals), and swapped some different wheels.
72 Chevy LB, LS in the works, 4L80, Grandfather bought it brand new. 66 GMC Short Step, 84 Front Suspension, many more mods to come 67 Chevy 3/4 Ton, 327, Auto, Factory A/C Ya must have been movin cause I was haulin a*$ when I passed you |
#5790 | |
Re: Re : BO - RING !
http://kalecoauto.com/index.php?main...&products_id=7
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
#5791 |
![]() Join Date: May 2012
hay Nate did you ever get the stuff i sent you....i sent it several times.
#5792 |
Went and pick up a grille at the wrecking yard now comes the cleaning of moss and light sanding and prep work to paint it and polish it up to install
#5793 |
Installed my rear brake lines from Inline Tube. The passenger side fit great but the driver side was absolutely terrible! Had to rebend it around the pumpkin, all the bends were wrong! I also installed a new door jamb switch on the driver side and now my dome light works again.
-Scott- |
#5794 |
got some parts in and did a little cleaning and painting, guess what this is going in.........maybe next week....lokar shifter should be here around next Wednesday. i am ready for an auto.
#5795 | |
But like I said, you'll do a better job than I did of making it a non-leaker *before* it goes in.
#5796 | |
#5797 |
#5798 |
Iv'e always talked about the father in law,but the mother in law is alive, I went to start the truck because it hasn't been drove in a few days to carry its rightful owner to get HER hair fixed the battery was dead. It let me down for the first time in years.
Needless to say MIL was mad. |
#5799 |
Well, it was last Sunday, but bought and installed a front and rear chrome bumper off a 69 C10 getting parted out. Also got the windshield to replace my fogged up one, Spring project.
#5800 |
Grand PooBaa Member
