Old 01-14-2013, 12:58 PM   #1
Dnrice
Guage Lights - only speedometer LIGHT works
Hope the new years is treating you all well. It was 70 degrees yesterday so I took the 71 out for spin. At night, I noticed only the speedometer guage light worked. I would love to have all guages lit up.
Is it a bulb or fuse to fix these problems? Also, where is the fuse box in these trucks? If it is a bulb, where do I have to take apart guage cluster?
Dnrice is offline   Reply With Quote
Old 01-14-2013, 01:12 PM   #2
74baggedbug
Re: Guage Lights - only speedometer LIGHT works
Easiest way to replace the bulbs is to remove the cluster and change the bulbs, I've heard of people changinge the bulbs without removing the cluster but I've never tried it
74baggedbug is offline   Reply With Quote
Old 01-14-2013, 03:46 PM   #3
Lattimer
Lattimer's Avatar
If you have a long skinny arm you can reach in and change the bulbs. They are #194 and they sit in a twist in 1/4 turn base.
I have a short fat arm so I pulled the cluster out.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 01-14-2013, 07:00 PM   #4
daves72C10D
daves72C10D's Avatar
I got mine out with the cluster in, skinny arms....
1972 Custom 10 Deluxe- original paint, interior- 72k miles
http://www.cardomain.com/ride/2466316
Cheap, Fast or Good. Pick any two.
1990 Eagle Talon AWD
1991.5 W250 CTD
1992 Cushman Truckster- Haulster
daves72C10D is offline   Reply With Quote
Old 01-14-2013, 07:05 PM   #5
71sierragrande
Petroleum User
71sierragrande's Avatar
I recommend pulling the cluster and replacing all bulbs at once and be done with it. 10 minutes max
1971 GMC Sierra Grande 2WD 1/2 ton, 350/400 auto
2008 Chevy Silverado 2WD 1/2 ton LT1 5.3L auto
71sierragrande is offline   Reply With Quote
Old 01-14-2013, 07:58 PM   #6
mrein3
mrein3's Avatar
If I were to take the time to pull the cluster, I'd take the time to check EVERY bulb. They are all 194s and can be easily checked by twisting the socket out and running 12 volts through each one.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 01-14-2013, 09:45 PM   #7
Andy4639
Old member
Andy4639's Avatar
Wink Re: Guage Lights - only speedometer LIGHT works
Here is what the backside looks like. This is a factory Tach dash. The lights are the little black knobs you see. They are not hard to replace at all.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 01-14-2013, 09:51 PM   #8
Tinkermc
very easy job and fairly quick
Tinkermc is offline   Reply With Quote
Old 01-14-2013, 10:11 PM   #9
jocko
jocko's Avatar
Andy posted a great ref pic so you know where to put em. I normally just pop the cluster out as far as it will go without disconnecting anything (not very far) and then reach in behind (from below dash) and in from above (between dash and cluster that is pulled out slightly) to swap em.
Old 01-14-2013, 10:15 PM   #10
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Mine doesn't have ac so it was easy without pulling the cluster, also skinny arms helped
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
