#51 | |
BigBlockBobby
Re: Baby blue 1970 GMC LWB resto-mod
Bob |
#52 |
I like the old school tack mounting on column, and truck looks to be in great shape, nice buy.
Kerry My build thread. http://67-72chevytrucks.com/vboard/s....php?p=3657823 1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears 1988 Chev Extendacab 2010 Honda VT1300CS Sabre 2005 Buick Rendezvous wife's ride |
#53 |
What is your seat out of? Looks like a good fit, and the truck's coming along nicely.
Posted via Mobile Device |
#54 |
Looks great. Mine is lowered about 4" up front and 5" in the rear, but I want to install bags so I can bring it up just a bit while driving and drop it when parked.
Mike Email: Click here to email me -- 2019 Silvedrado 4x4 1970 Chevy 3/4 ton, 396BB, on air bags |
#55 | |
![]() Join Date: Mar 2012
http://fssteeringwheels.com/shop/aut...=0&sort=normal
#teamlongbed "I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb 1978 Chevy shop truck - static 6/8" 1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497 Last edited by Square_78; 02-02-2013 at 11:55 AM. |
#56 |
The seat came with the truck. I have no clue what its out of. Im going to replace it someday, but I have lots of other things to do first.
#teamlongbed "I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb 1978 Chevy shop truck - static 6/8" 1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497 |
#57 |
That would be pretty cool. Im working on installing the Accuair eLevel right now. Still waiting for the Slam Specialties bags and front brake 5 lug conversion to arrive though.
#58 |
Got my tank and compressors mounted up in the EXO brackets and ready to bolt to the frame. Also started refinishing my lower body trim. Just shining it up a little and repainting it with satin black before I install it. Looks pretty darn good. It will sure look different when I get the roof painted white, all the new emblems put on, and get the lower trim on it.
#59 |
Where did you end up getting you air ride parts from, since I'm also in Canada and will have "fun" sourcing it all out. Since mine is a C-20 I'm staying 8-bolt to keep the truck as close to what it should be. Also general price of the items you bought for the air suspension so I can start my list and budget.
#60 | |
Heres one www.airassisted.ca They are out east and carry almost everything. All the fittings and air line you can get from any place that deals in air brake parts. Its just DOT air brake line and fittings. Im using all the push to connect fittings on mine that came with the Accuair kit.
#61 | |
BigBlockBobby
Bob |
#62 |
Yeah its actually not a bad wheel. Its better than I expected. I expectations werent very high for an $80 wheel plus the adapter, but its quite nice. Hiigh quality, and the billet adapter is good too. The black vinyl cover is kinda cheap but I am going to replace it with heavy black leather. The half wrap vinyl part comes off the billet wheel with 4 allen bolts on the back. The only thing is, I wish it was a tiny bit larger. The 14" diameter is a little small. 14.5" would be nice. I have power steering so its ok, but it might be tough to drive without power.
#63 | |
Second KMS in Kelowna carries PORTERBUILT.............WHAT!!!!!!!. The KMS here in Coquitlam gave me a blank stare when i asked if they heard of PB. Our next step is the Accuair setup, make sure to post pics of your install. |
#64 |
Thankyou! Im pretty sure I saw a small Porterbuilt banner up on the wall at KMS. Maybe I am wrong.
#65 |
Been collecting parts... STILL waiting for my air bags and CPP brakes to arrive. Brutal. Got my GMC emblems installed, and got all the side trim cleaned up and repainted. I might install it this week. I bought all my 4 guage battery cable for the compressors, 80amp fuse block, continuous duty soliniod to control the compressor power. I made up some cables tonight with the 4 guage and copper ring terminals from the battery to the fuse and made a new 4 guage ground strap to go from the battery to ground. Just been slowly plugging away at it.
#66 |
Got my body side trim installed yesterday... Im very happy with how it looks. The last pic is how it looked without the trim and fender emblems. Much better with it all on there. Doesnt look like such a plain jane base model now.
#67 |
The trim painted up looks real good on your truck.
Are you planning on running a new wheel/tire combo? Just to let you know, if your looking for any parts that you cant buy aftermarket, there is a good guy in Keremeos along hwy 3 that has a bunch of 67-72s. I did a search and his shop is Cawston Tire & Mechanical. He has a real sweet 68 suburban that he's building for his wife. |
#68 |
Hey cool thanks for the info! I will for sure check that place out. Yes those are just the wheels that came on the truck when I bought it. I have 15x8 rally wheels going on it as soon as my 5 bolt disc brake kit shows up. I hope to have racelines on it by the end of next winter.
#69 | |
Looks great with the trim! Nice job on the emblems too! I need to do something like that. I found a nice set of 910 emblems in Victoria, they were in great shape aside from a hole the PO drilled right through the middle cause he was to lazy to mount them from the inside. Damn shame, I just couldn't see passed that.
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=547706 |
#70 |
He drilled through them? That's too bad. Those 910 emblems are hard to find. I used silicone adhesive to mount my emblems. I drilled the holes in the fenders to get the location, then used the silicone to mount them. They are never comig off without a pry bar. I also used silicone to glue on the moldings because I didn't want to drill all the holes in the body. The molding is never gunna fall off and will probably be next to impossible to remove if I ever have to haha.
#71 |
![]() Join Date: Dec 2012
The moldings really improved it!
JK |
#72 |
Thanks! I'm very happy with how it looks. White roof is next after I fix the drip rail sealant.
#73 |
That will be a good mod too! Had you considered white below the molding instead of the top as an option? I'm thinking that would be a good look too. Cloud9 is that way, and he won TOTY. I'm just saying....
JK |
#74 | |
#75 |
I do agree it wouldn't really fit while the black wheels are on it (which was a good idea on those rims btw). but when you put the 5 lug rally's on it, the white bottom would be good. I cant fault that concept of doing the rocker first, though.
JK |
