Old 01-16-2013, 07:54 AM   #1
bigd65
bigd65's Avatar
Rear end guys
Will my 5 lug half ton axles fit in the rear differential of a 6 lug Suburban. Can't tell the year of it yet, but I believe it's Pre 88
2004 Silverado Crewcab
1972 Chevy Monte Carlo
2017 Chevy Tahoe
bigd65 is offline   Reply With Quote
Old 01-16-2013, 08:16 AM   #2
6gears
Re: Rear end guys
Yes...as long as it is not a 14bolt semi float.....
6gears is offline   Reply With Quote
Old 01-16-2013, 08:47 AM   #3
bigd65
bigd65's Avatar
Re: Rear end guys
Cool, the burbs are usually geared 3.73 and some cases factory posi, am I correct on that
2017 Chevy Tahoe
Old 01-17-2013, 11:05 PM   #4
bigd65
bigd65's Avatar
Re: Rear end guys
Hey this Burb is a 4x4/ 6 lug and I think the guy will seperate and sell me the rear. I asked him to check the code on it to see the gearing, but I gotta a question. It's an 88 year model, is that when they changed the splines won the axles. I don't want to give up my 5 LUG.
2017 Chevy Tahoe
Old 01-18-2013, 01:26 AM   #5
MalibuSSwagon
Re: Rear end guys
A 6 lug axle should be a 10 bolt like your 5lug 2WD axle. The question is, is the width the same?
MalibuSSwagon is offline   Reply With Quote
Old 01-18-2013, 08:43 AM   #6
bigd65
bigd65's Avatar
Re: Rear end guys
It's a SQUARE BURB, shouldn't the rear be the same. I'm trying to locate a 3.73 geared rear and was told that some of the Burbs were 3.73 and if they were 12 bolt or 4x4, possibly factory posi. This Burb is an 88 with 6 lug. If this was one of the rears I was referring to, can my 5 lug axles fit, to replace the 6 to 5 lug
2017 Chevy Tahoe
Old 01-18-2013, 10:50 AM   #7
Rich84
Rich84's Avatar
Re: Rear end guys
I think those are 30 spline starting in 1988..Just get some axles from an 88 and up 2wd. They are 5/8" longer.
Rich84 is offline   Reply With Quote
