Old 01-16-2013, 12:13 PM   #1
D.FENS
Dropmember on a Dually. Steering?
Considering a Porterbuilt Dropmember and control arms on my C30 CCD.
The regular C10 dropmember kit is set up for a Unisteer or similar MII rack and pinion, and I would assume the C30 kit would be the same.
Anybody have any inside info on how the MII rack works on really heavy vehicles, like a crewcab or a Sub? I called Unisteer this morning and their guy said they haven't actually done one themselves but wouldn't recommend it.
D.FENS is offline   Reply With Quote
Old 01-16-2013, 12:28 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Dropmember on a Dually. Steering?
Talk to Nate Porter.
I know he has sold a few Dropmembers for dually projects.
Maybe he can give you some insight.
Keith
Convert to disc brakes.
Old 01-16-2013, 01:22 PM   #3
D.FENS
I posted pretty much the same question on PB's web forum a couple days ago, but as yet haven't gotten a reply.
Didn't really want to call them since I'm not ready to pull the trigger.
Old 01-16-2013, 02:48 PM   #4
PBFAB.COM
PBFAB.COM's Avatar
Plenty of guys running them. Few things to discuss. Best to give us a call.... even if you're not ready to pull the trigger yet.
I am a little behind on answering questions on the PB forum. Not enough hours in the day! LOL
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 01-16-2013, 04:19 PM   #5
D.FENS
Understand PB is a busy shop, that's why I didn't want to waste your time on the phone when I'm not really ready to spend money.
Perfectly fine with you (or whoever) answering my questions online when you have a minute. Maybe others could benefit as well.
Thanks again.
Old 01-16-2013, 07:01 PM   #6
SCOTI
SCOTI's Avatar
Thanks again.
I'm sure they know of others that lurk around waiting to learn about what it takes to install The Dropmember in a dbl wide....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-16-2013, 10:55 PM   #7
andrewmp6
I believe all of his dropmembers use a fox body mustang rack pinion.
Old 01-17-2013, 09:17 AM   #8
D.FENS
From what I've been able to find out, Unisteer uses either a Mustang II / late Pinto, or a Dodge Omni rack depending on whether it's a front (ahead of the spindle) or rear (behind the spindle) application.
My question was more focused on how well the Unisteer racks work and whether it will hang in there long-term, particularly on a heavy vehicle, as opposed to what it is or how the dropmember itself is installed.
Old 01-17-2013, 11:41 AM   #9
PBFAB.COM
PBFAB.COM's Avatar
We use a 79-93 Mustang rack.
We used Unisteer exclusively over the years until recently. They remanufacture all their racks, and do a great job with exceptional quality control. Unfortunately, since it's a rebuilt unit, they are at the mercy of the cores. There have been several core shortages over the past year or so, leading to a smaller supply.
CPP manufactures a brand new rack and pinion that is a little beefier, but holds the same dimensions. We started using this rack a few months ago. It seems to be of the same quality, but is new, and has beefier internals... can't go wrong there, as it is a better fit for the heavier front axle weight.
I don't see, nor have I seen any issues with longevity on a heaveir front axle weight vehicle like the subs or duallys. However, it would be common sense to assume that whenever a part is pushed to perform on the higher end of its intended design or capacity, it will wear at a quicker rate. I think the longevity or life of the components would depend greatly on how the vehicle was driven and how much the vehicle was driven.
What is your intended purpose for the truck?
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 01-17-2013, 04:35 PM   #10
D.FENS
Now we're getting somewhere. Thank you for taking the time to reply, much appreciated.
Primary use for my truck will be for cruising and light - to- medium hauling / towing.
I like the idea of not having to Z the frame to get the truck to lay. Tentative plan is to bag the truck with a Dropmember, spindles, PB arms, and the rack conversion.
Old 01-17-2013, 04:39 PM   #11
PBFAB.COM
PBFAB.COM's Avatar
Cruising and light to medium towing (assuming car trailer is about as heavy as you would go?) I would not hesitate.
Work truck hauling big loads on a regular basis...I would not sell it to you! LOL
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 01-17-2013, 05:51 PM   #12
D.FENS
All I have is a single car bumper pull trailer. Hoping I never own enough toys to need a three car wedge. Be cheaper to buy a used semi / lowboy combo.
Need to make up my mind about powertrain. I'm looking at LS swaps, like a 6.0 / 4L80E, but I've noticed 8.1's are available for about the same money.
Assuming the DM would address any LS motor mount issues, but what about header and oil pan fitment? Is there any particular parts combo you recommend to get the motor sitting in the truck? This might not be such a problem with an 8.1.
Old 01-18-2013, 03:21 AM   #13
andrewmp6
I wouldn't be scared of using a fox body mustang rack,I know a few fox body drag cars running a blown big block and the stock rack handles the weight fine.
Old 01-18-2013, 08:55 AM   #14
lolife99
lolife99's Avatar
Is that the issue?
Or is it more about the weight of a dually truck,... pushing on the rod ends and adapters connected to the 79-93 mustang rack?
I'm not sure how much more a dually weighs than a standard pickup, with a Dropmember.
Keith
Old 01-18-2013, 09:15 AM   #15
SCOTI
SCOTI's Avatar
Is that the issue?
Prob about 2K more....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-18-2013, 10:57 AM   #16
PBFAB.COM
PBFAB.COM's Avatar
The main issue is the force that is put on the pinion assembly inside the rack. The gear assembly can only handle so much. That is why the only real determining factor is front axle weight.
Another thing to throw out there.... the manual rack has a beefier pinion gear in it, making it possibly a better option.
As for me, I would run the power set-up, load up the wife and kids, hit the road, and not think twice.
Nate
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 01-18-2013, 11:35 AM   #17
SCOTI
SCOTI's Avatar
Swapping to the SRW front hubs & lighter wheels would prob extend the lifespan. Some like that look too (CC dually tucking some 22's).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-18-2013, 11:52 AM   #18
PBFAB.COM
PBFAB.COM's Avatar
Agreed. Keep in mind that the Dropmember and control arms will also shave quite a bit of weight off the front.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 01-18-2013, 11:57 AM   #19
N2TRUX
Happy to be here
N2TRUX's Avatar
While that "might" simulate the weight of a BBC in a dually, it won't even come close to comparing the stress put on that rack that the weight of the wheels do. There is no possible way to compare fox body drag cars and a C30 truck for stress on steering components.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-18-2013, 11:57 AM   #20
jimmydean
jimmydean's Avatar
Nate, I know the Dropmember is a ton lighter, but have you ever weighed a hub to hub setup side by side to see just how much over an OE crossmember and arms?
I am curious because I was blown away at how much lighter the Corvette brake setup Boris has was over an OE C10 disc setup. I would think the difference would be considerable in this case, too.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 01-18-2013, 12:01 PM   #21
PBFAB.COM
PBFAB.COM's Avatar
I have, but don't have the numbers in front of me. It was over 100 lbs lighter (a bunch of that was in the steering components). I will get some more exact numbers.
Nate
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 01-18-2013, 01:53 PM   #22
jimmydean
jimmydean's Avatar
I just know how heavy my '75 front setup was hub to hub because I had to get it in the back of the truck by myself.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 05-19-2014, 07:57 AM   #23
Ghostwhite
Squarebody guy
Ghostwhite's Avatar
Thread from the dead!
Just ordered the dropmember for my c30, what pn powered-steering rack do I need from CPP and will the recommended shaft joints for the c10 work on the c30(are they different)?
Trying to get my ducks in a row, my schedule doesn't coincide well with your office hours Nate, thanks!
Ghostwhite is offline   Reply With Quote
Old 05-19-2014, 08:07 AM   #24
lolife99
lolife99's Avatar
I would email Nate or Dave,... or PM him directly.
Should still use the 79-93 mustang rack.
Keith
Old 04-17-2015, 04:28 AM   #25
slimneverdies
slimneverdies's Avatar
Does it help with the turning radius of these big trucks?
Long live SLIM
At least try to buy American
slimneverdies is offline   Reply With Quote
