Closed Thread
Old 12-30-2012, 01:09 AM   #1676
NEWFISHER
NEWFISHER's Avatar
Re: What Did You Do With Your Truck Today ?
I started at 9 am pulling the granny low 4 speed, both cross members etc and installing a 700r4. I had to cut the fire wall at the bell housing for it to clear. Mounted a linear cooler, hooked up a lokar tv cable set up, re routed a brake line crossover, moved the rear axle back an inch so the 92 Sblazer 4door drive shaft would fit with a conversion joint to 1310 and welded in a CPP crossmember.
Headed back at it in the morning to install the TCI 4th gear lock up kit, fill it with fluid, toss the driveshaft in, mount the lokar shifter to the installed bracket and take it for a spin!
NEWFISHER is offline
Old 12-30-2012, 01:24 AM   #1677
Oklahoma_k5
Got the Wheel wells put in so the bed would clear the tires.
Still got some grinding to do on this side
Then I hung all the sheet metal back on it just to make sure the wheel base is right and the wheels are where I like them in the wheel wells before welding it all solid.
Oklahoma_k5 is offline
Old 12-30-2012, 01:48 AM   #1678
Daze57
Daze57's Avatar
v v sharp !
Daze57 is offline
Old 12-30-2012, 03:07 AM   #1679
arturo7
arturo7's Avatar
Worked on my beast pretty much all day. Morning, noon, and night.
Seems like I didn't I accomplish a dvmn thing...
ever forward
build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=542073
arturo7 is offline
Old 12-30-2012, 01:10 PM   #1680
lowdownstar
big guy
lowdownstar's Avatar
I have those days all the time LOL
Ray
lowdownstar is offline
Old 12-30-2012, 09:37 PM   #1681
lazypineapple
lazypineapple's Avatar
After 2yrs 9 mo I drove it.
From the Maiden Voyage today
lazypineapple is offline
Old 12-30-2012, 10:28 PM   #1682
DransportGarage
DransportGarage's Avatar
I've been off the truck project for 6 months while the tennis elbow pain healed up (cortisone, therapy, etc.). I think it's 100% now, so I'm diving back in.
I reviewed Blackdiesel's videos on one-piece window installation (great work, BTW!). The tracks are done and I've formed and installed the glass run channel. I put the bracket on the glass, and the glass in the channel. Right now I'm taking my first guess at where my power window regulator should bolt in, and I'm fab'ing the attachment to the glass.
Bob
"It won't take long and it won't cost much."
'55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed)
Bob's Retirement Build - My 55 TF
Bob's 700R4 Build (how-to)
DransportGarage is offline
Old 12-30-2012, 11:15 PM   #1683
swanny11
Got the metal bent, got the pieces tac welded andddd tomorrow we are making supports.
swanny11 is offline
Old 12-31-2012, 05:39 PM   #1684
Jaylow72
Jaylow72's Avatar
Today i ended up putting on my windsheild sunvisor 0n the 58 wow how it really changes the look
Jaylow72 is offline
Old 12-31-2012, 07:44 PM   #1685
_Ogre
_Ogre's Avatar
salt season started december 26 here
truk is officially parked for the winter
sob
shop air compressor timer
_Ogre is offline
Old 12-31-2012, 10:08 PM   #1686
NEWFISHER
NEWFISHER's Avatar
Drove a tank of fuel through mine today. Got the tv cable and shift adjusted, washed it and have been just cruisin around all day. Stopped at the hardware store and picked up some plastic coated cable, stainless eyebolt and hardware, a pad lock and made a " keep the unwated folk out from under my hood " device. Had some strange looks from people in the parking lot and asked if I "needed a jump" 3 times.
Old 12-31-2012, 11:12 PM   #1687
Coach529
Coach529's Avatar
That is a huge step....congrats!!
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline
Old 01-01-2013, 10:02 PM   #1688
rollinrooster
rollinrooster's Avatar
Worked on steering column... still need to finish.
rollinrooster is offline
Old 01-02-2013, 12:53 AM   #1689
NEWFISHER
NEWFISHER's Avatar
Drove another tank full of fuel through it. 700r4 shifts awesome, drives great with the new 250 and all the new tapered bearings/Sids steering drop axle stuff. I even convinced the wife to bundle up on our 31 degree day and hit some country roads to see how it drove! The only wrench I turned on it was to adjust Tv pressure a final time.
Old 01-02-2013, 12:55 AM   #1690
NEWFISHER
NEWFISHER's Avatar
Rollinrooster...steering looks clean, I always like the look of shooting the intermediate shaft through long tube headers!
Old 01-16-2013, 08:22 AM   #1691
pvienneau
pvienneau's Avatar
Re: What Did You Do With Your Truck Yesterday ?
Pulled the front grill radiator, top and bottom rad shrouds, fan, and Rad Bracket. Started cleaning and painting in a hammered black. Great whther this past weekend in Boston.
pvienneau is offline
Old 01-16-2013, 09:56 AM   #1692
focusedontheprize
focusedontheprize's Avatar
You are putting some serious miles on that rig, I love it haha.
How does it drive with all the steering drop axle stuff on it?
focusedontheprize is offline
Old 01-16-2013, 09:57 AM   #1693
focusedontheprize
Not physically working on it unfortunately, but gathering parts....going to order Langdon's split exhaust manifolds for the 292 this week. Was going to wait, but with the trip coming up I decided to do it earlier.
Old 01-16-2013, 09:59 AM   #1694
Jesse49chevy
Jesse49chevy's Avatar
Coach529, congrats your truck looks great. if you dont mind, what size wheels and tires are you running, also curious about the rear end?
Semper Fi
Check out my project:
http://67-72chevytrucks.com/vboard/s...d.php?t=559086
Jesse49chevy is offline
Old 01-16-2013, 10:43 AM   #1695
Jesse49chevy
sorry, i guess i should be asking LAZYPINEAPPLE....
Semper Fi
Old 01-16-2013, 10:58 AM   #1696
Coach529
Coach529's Avatar
I am curious as well!!
1949 Chevy 3600
Coach529 is offline
Old 01-16-2013, 12:43 PM   #1697
tbrown5079
Bolted the throttle control to the firewall. It will be behind the battery. Drilled the hole through the firewall and bottom battery box brace for the harness.
Finished the emergency brake cables. Used the origional handle bolted to the brake booster bracket. Movin on!
tbrown5079 is offline
Old 01-16-2013, 01:57 PM   #1698
lazypineapple
fronts are Diamond Backs 225/60/15 3.5 BS and a 1/2" spacer on 7x15 Hot Rod rallies
Rears are 245/60/15 on 8x15 w/4" BS and a 1" wheelspacer
the Diff is A 1976 GM
Old 01-16-2013, 02:13 PM   #1699
Jesse49chevy
thanks for sharing..... your truck looks great!
Semper Fi
Old 01-16-2013, 02:22 PM   #1700
Jesse49chevy
sorry for the nagging question, im trying to decide if i should keep my 8.8 Ford rear end, or go with a S-10, on your rear end, how wide is it? Mounting point to mounting point? the 8.8 i have is 64 1/4, so i beleive it is too wide.
Semper Fi
Closed Thread
