01-16-2013, 09:57 PM | #26 |
Re: My 42 Project
Back window is in
Posted via Mobile Device Posted via Mobile Device
1954 GMC on 93 Silverado chassis http://67-72chevytrucks.com/vboard/s...d.php?t=408344 1942 Chevy 1/2 ton Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=429494 R.I.P. TOM SEFFRON 68 FOUR DOOR http://67-72chevytrucks.com/vboard/s...d.php?t=495438 1942 Chevy that ate my brain 70 Chassis https://67-72chevytrucks.com/vboard/...d.php?t=835250 |
01-16-2013, 11:11 PM | #27 |
SAVING ONE TRUCK AT A TIME
Re: My 42 Project
window looks great.what company did you use for the seal?are you not going to use the outer trim ring?
53-suburban (99% done) 40-pick up (99.9% done) 12-cc lb dually D-max (dd) 61-crew cab D-max "PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT" 53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091 1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088 1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999 |
01-17-2013, 01:04 AM | #28 |
Re: My 42 Project
Hey Chizzler, they only had the outer trim ring till 1941 after that they changed the way the window was mounted.
01-17-2013, 02:01 AM | #29 |
Re: My 42 Project
Thanks. The seal is from Filling Station. I use them because they are real accurate and fit great. I didn't have the die cast trim so I had the glass company make it in the 46 style. I guess the glass is different for the trim. I like the look of the die cast but in 42 they had gotten rid of all the chrome. My headlight rings are painted brass. Not sure what I am going to do with those
01-17-2013, 09:36 PM | #30 |
Re: My 42 Project
I am working on my side windows today. I had the glass made to fit without the metal frames. I am using stock regulators and am not sure what to do about how to attach the glass to the regulator. I installed the bottom track of the metal frame window to the all glass window and it is twisting and binding. Any ideas about a bottom track or do I need to make something?
01-18-2013, 08:06 PM | #31 |
Re: My 42 Project
got it figured out. I am using 51 to 54 glass channel. It is the same size and it holds the window better. I will post pics when I get them.
01-26-2013, 04:22 PM | #32 |
Re: My 42 Project
Got the dash trim on
02-21-2013, 10:01 PM | #33 |
Re: My 42 Project
Posted via Mobile Devicegot the new window tracks in. Work perfect
03-03-2013, 04:30 PM | #34 |
Re: My 42 Project
I have been trying to get the windshield frame apart for the new glass and just doesn't want to come apart. All the screws have been removed and I have been soaking it in PBR but it is just stuck any ideas?
03-03-2013, 05:01 PM | #35 |
Re: My 42 Project
mine was the same way.you can try to put one end on the floor under your foot and try to wiggle it back and fourth.or try the same method and pop the corners up with a rubber mallet.depending on if your going to re-use the glass you could break the glass out which might take some tension of the connecting bars.good luck.
10-19-2013, 09:24 PM | #36 |
Re: My 42 Project
i decided to go 3/4 ton 1970 frame. Somebody gave me the frame. I will get to use my factory flatbed and it's cheap to buy parts for. Small block with a 350 and headers. Lokar shifter late model column. Two universals for power steering. Big brakes and easy no haste driving anywhere I want to go.
10-19-2013, 09:36 PM | #37 |
Re: My 42 Project
wheels stick out about 1 inch but these are wide wheels. I am using dually wheels which should be under about 2 inches
01-01-2014, 08:34 PM | #38 |
Re: My 42 Project
Got the windshield together. Wow that was a pain.
01-20-2014, 08:09 AM | #39 |
Re: My 42 Project
Did you find a transmission?
01-20-2014, 01:31 PM | #40 |
Re: My 42 Project
Yes I have two
01-25-2014, 02:56 PM | #41 |
Re: My 42 Project
Subscribed! Keep up the great work!
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
01-25-2014, 10:03 PM | #42 |
Re: My 42 Project
The motor is at the machine shop and is going to be ready next week. Should go in on Saturday. Then I can make final adjustments to the cab. Also scored a rebuilt 700r4 for it and with a lokar shifter in the almost stock position, that will look cool. Pics next week. Thanks for subscribing
03-04-2015, 05:26 PM | #43 |
Re: My 42 Project
wow its been a year since I posted. Not much on this truck going on but I did build a motor for it so its coming soon
03-05-2015, 04:57 PM | #44 |
Re: My 42 Project
Looking good! I like the color and seat combo
GOD BLESS AMERICA! |
06-13-2015, 06:09 PM | #45 |
Re: My 42 Project
Back at it
now its in the garage with its bro truck
06-13-2015, 06:10 PM | #46 |
Re: My 42 Project
06-13-2015, 06:14 PM | #47 |
Re: My 42 Project
Got the motor in and am changing the interior to the original from the other truck. Matches the seat
06-23-2015, 11:12 AM | #48 |
Re: My 42 Project
Edited by Forum Staff
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here If you need any further assistance with that please contact any Admin for help.
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 Last edited by 63 & 64 Bowties; 03-25-2016 at 08:06 AM. |
03-24-2016, 08:20 PM | #49 |
Re: My 42 Project
sorry it took so long to get back to this. I have seen that piece on ebay.
Sold the 54. The woodie is done so its time to get back to this
07-19-2016, 03:43 PM | #50 |
Re: My 42 Project
so its been a while. Changed the idea back to the original direction. Built a gantry and moved the body back to the original chassis. Installed the new sbc and 700r4, ended up rebuilding it also. Used mounts for 47-53. the worked great just had to cut them to fit. Installed a 55 car rear end. Rebuilt it with 308 gears new bearings and brakes. Looking for a radiator that will fit with the radiator support brackets. I installed corvette cast iron exhaust manifolds and they are clearing the steering box so that is cool. I guy gave me some original 46 bed sides so I am on the hunt for steel rear fenders.
