Old 01-16-2013, 11:11 PM   #1
cmyc5575
Two more weeks until 5/7 drop but opinions wanted.
Hello everyone, Like the title says I have about two more weeks before i take my truck to a good friend and square fans house that is going to help me lower my truck with a belltech 5/7 kit. My questions or concerns is its going on an 82 lwb has anyone have any pics of this and have rub complaints when driving over railroad tracks and or massive parking bumps? Thanks for all your input guys.
cmyc5575 is offline   Reply With Quote
Old 01-16-2013, 11:14 PM   #2
J Knight
J Knight's Avatar
Re: Two more weeks until 5/7 drop but opinions wanted.
What tire and wheel sizes are on your truck, it does make a diference with that much drop?
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 01-16-2013, 11:20 PM   #3
cmyc5575
they are 255 70-15/s on a 15x8 wheel not sure the bs on the rear. But, I also bought some 15x10's with 4.5 inch bs and I know im going to have to have the rear fender lips trimmed when im ready to put them on. im afraid tho im going to be draggin my frame accross the speed bumps and rail road crossings.
Old 01-16-2013, 11:32 PM   #4
cory d
cory d's Avatar
im about there adn i have 255/70/15's. i rub in the front adn i drag headers. beltechs hopefully have a stiffer rate then stock coils. 3/4 or 1 ton coils with one cut may be better
cory d is offline   Reply With Quote
Old 01-16-2013, 11:36 PM   #5
J Knight
J Knight's Avatar
With those tires on the front on 8in you will probably rub the top of the tires on the underside of the wheel wells with a 5in drop, you may want to get some 245/60/15s or 255/60/15s. (I would prefer a 245/60/15)
what tire are you going to put on the 10in wheels on the rear?
John
Old 01-16-2013, 11:50 PM   #6
cmyc5575
I havent thought about that but most likly something that is going to not rub when all i am going to want to do is trim off the inner fender lip. Cory I plan on keeping my manifolds on, but where else in the front are you rubbing? Im even seriously thinking about removing the front inner fenders is there anything unsafe about driving without them.
Old 01-17-2013, 12:06 AM   #7
J Knight
J Knight's Avatar
You dont want to remove the inner fenders, its going to throw all the road grime all over your motor. Your realy going to be close to rubbing with a 7in drop and 10in/4.5inbs rims.
John
Old 01-17-2013, 12:22 AM   #8
cmyc5575
Ok then Ill just run a smaller tire on the front and leave the fenders in.
What area would be rubbing in the rear tho?
Old 01-17-2013, 12:31 AM   #9
J Knight
J Knight's Avatar
The fender lip to the sidewall of the tire.
John
Old 01-17-2013, 12:35 AM   #10
cmyc5575
Yeah, I plan nho triming it off. Would it rub anywhere else?
Old 01-17-2013, 12:40 AM   #11
J Knight
J Knight's Avatar
No it shouldn't.
John
Old 01-17-2013, 12:47 AM   #12
cmyc5575
No it shouldn't.
Ok what do you think if i replaced the front cut coils with hd coils that are cut?
Old 01-17-2013, 01:02 AM   #13
J Knight
J Knight's Avatar
Why do you think you need HD coils?
John
Old 01-17-2013, 01:35 AM   #14
cmyc5575
alil stronger sprig rate so i can run 70-15's.
Old 01-17-2013, 07:27 PM   #15
SCOTI
SCOTI's Avatar
No guarantee that you still won't rub if running too tall of a tire. A 255-70-15 = 29" tall. My guess is you will rub even w/HD coils. A 225-70-15 will allow more clearance @ 27.5" tall....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-17-2013, 10:25 PM   #16
82ccshorty
82ccshorty's Avatar
I have a 6/8 on my truck running a 265/70r17 a 31.7 with no rub anywhere
1969 chevy camaro Z28 #matchin Factory 4wheel disc
1969 chevy cst10 big block overdrive 5/7 drop dog dishs
1997 gmc yukon 2 door 2 wheel drive project 4/5.5 22s
2004 gmc sierra dually 4/4 lowering daily driver
82ccshorty is offline   Reply With Quote
Old 01-18-2013, 10:59 AM   #17
SCOTI
SCOTI's Avatar
Lets see a side pic. There's a diff between the starting height of a C20/30 vs a C10.
My 74 was dropped approx 6/8 & I couldn't drive the truck w/255-40-20's (28" tall) w/o the tires constantly buzzing the top of the inner fenderwells. This is the exact reason I installed Slosh Tubs into my dually project as I wasnt to run 29" or so tires @ the minimum.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-18-2013, 01:46 PM   #18
Rich84
Rich84's Avatar
I have a 30" tall tire with a 4.5/5..No rubbing at all..Ever.
1.5 drop spring, 3" spindle
flip kit
Rich84 is offline   Reply With Quote
Old 01-18-2013, 07:59 PM   #19
baclay9
He is now gonna be running 245/60's in the front and 255/70's in the rear with 15x8.5 slots all the way around. He is installing "Clifford's" old drop and wheel/tire combo so I know they will work together.
baclay9 is offline   Reply With Quote
Old 01-18-2013, 08:11 PM   #20
SCOTI
SCOTI's Avatar
And.... They'll work w/a 6/8-ish drop so a 5/7 allows greater clearance .
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-18-2013, 11:37 PM   #21
cmyc5575
Lol Barclays. Your da man! Thanks for all the help guys I appreciate it! Sorry took me so long to reply back been having issues with my computer!
Old 01-19-2013, 12:57 AM   #22
82ccshorty
82ccshorty's Avatar
6/8 265/70r17 it doesnt rub when fully turned either way it probly would drag headers on speed bump
Old 01-19-2013, 04:49 AM   #23
cmyc5575
Well that was mainly why I started this thread was not so much tire rub but where in the frame is it rubbing or parts? I have to take in account on a lwb that having a longer wheelbase gives me a much bigger chance to bottom it out.
Old 01-19-2013, 05:09 AM   #24
cory d
cory d's Avatar
the canadian whe assembled ym frame was drunk because my suspension cross member is not centered. when i turn, my left tire can catch teh fender pretty bad and ding it up, it rusted so i went to town on it wil the ol' ball peen. my cross member is ofset to the left quite a bit, maybe 1/4" or more. not too uncommen with these truck i guess. so watch out for that when it is lowered
Old 01-19-2013, 05:19 AM   #25
cmyc5575
coryd the Canadian u assembled? frame was drunk?
