Old 01-19-2013, 10:33 PM   #1
64tantruck
64tantruck's Avatar
Hub Cap Questions
I have a 1964 C20 pick up. I am running 8 lug 16 inch wheels with a 73/87 front disc brake conversion.
I am currenlty running 56 chevy bel-air wheel covers with thru bolts with chrome acorns.
I purchased a used set of white hubcaps with the red center circle with a white bow tie. (pic attached)
These dont fit on the wheel, just a bit too small. Does anyone know if I can get these in a larger size to fit on my current 16 inch wheels.
Thanks,
Glenn
Glenn Korec
Jamesville NY
64 C20 350ci Turbo 350 tranny 3.73 gear with air ride.
61 Apache10 (wife's truck) 327ci powerglide.
http://67-72chevytrucks.com/vboard/s...d.php?t=570100
64tantruck is offline   Reply With Quote
Old 01-22-2013, 08:40 PM   #2
Irishbleueyes
Re: Hub Cap Questions
Can you post a pic of the inside?
Irishbleueyes is offline   Reply With Quote
Old 01-23-2013, 01:31 AM   #3
oem4me
No, you will not find any like that which fit an 8 lug 16" wheel. Can't tell from the front if your nice "used" caps have a ring or flange on the back, but you could possibly attach some clips to your wheels to hold those caps in place. the fit will not be perfect, but it might work. I've been thinking of attempting this same thing on my '62 since the earliest (oldest) caps to fit my 16" nub wheels are from the 70's.
Old 01-23-2013, 02:32 AM   #4
Project 1960 Apache
What are the right caps available for which years?
Project 1960 Apache is offline   Reply With Quote
Old 01-23-2013, 02:52 AM   #5
burbluv
burbluv's Avatar
So if I am understanding you correctly there are no caps that will fit my 62 if I want rims larger than 15 inch? And also the only way to get 4x4 caps would be for me to bore out the front of two 15 inch and stay with 15 inch rims? Thanks everyone
burbluv is offline   Reply With Quote
Old 01-23-2013, 03:37 AM   #6
oem4me
No, not exactly. 16" wheels are later wheels and as far as I know, none came with spring clips for the older style flange-type hubcaps. The bumps, or nub diameter on a later 8 lug 16" wheel is also too large for a regular (flange-less) early cap. To answer your question, two larger sized wheels were optional for our era trucks: 17.5" and 19" ( I think) and both came with caps, but I'm not sure if they were available for both 1/2 ton and 3/4 ton. These will also be difficult to find.
Old 01-23-2013, 12:22 PM   #7
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Previous Thread link
http://67-72chevytrucks.com/vboard/s....php?p=5557512
Old 01-23-2013, 01:14 PM   #8
oem4me
Thanks Aero, that thread provides all the correct pertinent info on this issue, unlike my incomplete and partly incorrect response.
