Closed Thread
Old 01-20-2013, 09:55 AM   #6826
weaintscared
weaintscared's Avatar
Wink Re: What did you do to your truck today?
Well I when and picked up a 1969 short bed this makes my 2nd 69 short bed
1st truck is 502 BBC w/ T56 6 speed
2nd old pantina 6 cyc. W/auto going in it from the first donor truck
1st truck build; http://67-72chevytrucks.com/vboard/s...d.php?t=468622
2nd truck; http://67-72chevytrucks.com/vboard/s...=1#post5829151
weaintscared is offline
Old 01-20-2013, 11:46 AM   #6827
hemifalcon
Originally Posted by mark 66 View Post
what do you use for all those spot welds? I have a roto broach bit but, doesnt seem to last very long.kinda costly to keep replacing
I have the Blair Rota-Broach as well. The trick that I've found is that at low-speed on the drill, they'll cut just fine. Also-when they start getting "lazy" (dull) with a lotta muscle they'll still cut through. I'm pretty damned sure that I've cut close to 500 spot welds with two bits in the Blair kit. Yesterday I did finally break the pilot drill bit that goes inside the broach arbor along with one of the cutters when I was fighting a particularly stingy spot welld on the dash.
In my spot weld count I've removed two dashes, approximately spot welds on my burb.
-2X front driver kick panels at 3X on one panel and 43 on the second.
-3X Rocker panels with unknown number of spot welds..
I was able to order two of the 3-Pack's of 3/8" Blair cutters at my local NAPA for only $20... I thought that was far.. I'll likely need at least one.. And then I'll have extras for the next project.
My '65 Suburban Resto build--
http://smg.photobucket.com/albums/v6...65%20Suburban/
And it's story of being 'saved'
http://www.jalopyjournal.com/forum/s...d.php?t=631495
hemifalcon is offline
Old 01-20-2013, 08:40 PM   #6828
62 Barnfind
62 Barnfind's Avatar
Installed my wood bed and set the bed back on the truck.
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline
Old 01-20-2013, 09:00 PM   #6829
joedoh
joedoh's Avatar
holy blue I love that color
joedoh is offline
Old 01-20-2013, 09:31 PM   #6830
3rd Coast Z
3rd Coast Z's Avatar
Really nice Barnfind.
3rd Coast Z is offline
Old 01-20-2013, 09:32 PM   #6831
3rd Coast Z
Muahaha I got a blower for my 350 build. The flame has been reignited.
Dang it, I can't seem to post this pic straight.
Old 01-20-2013, 09:37 PM   #6832
wutnxt
Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
Worked on my project low and go ....front inner fenders and rear steel bed mods.....it's getting closer
1966 Pro street build http://67-72chevytrucks.com/vboard/s...?t=448089[
1958 LS 2 build http://67-72chevytrucks.com/vboard/s...d.php?t=527123
1966 SBFS low and go http://67-72chevytrucks.com/vboard/s....php?p=5799909
1966 SBFS street HULK http://67-72chevytrucks.com/vboard/s...=1#post5886625
Poject Low and go gets a 6.2 ltr LSA supercharged with 6 speed automatic
Aluinum Radiator Dealer pm for details
wutnxt is offline
Old 01-20-2013, 09:41 PM   #6833
dantimdad
dantimdad's Avatar
I cleaned out the insulation/deadener and vacuumed up the new/older cab.
It will need rockers, both from floor supports, part of both sides of the floor boards and some dummy beat in two spots on the firewall to fit in an engine it appears.
Not even close to as bad as the first cab even though it's more area.
All in all, I am still stoked about the cab.
I am still debating on shaved drip rails...
Steven
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.” - Nikola Tesla
Matt. 6:27 "Who of you by worrying can add a single hour to his life?”
http://www.67-72chevytrucks.com/vboa...=507266&page=2
dantimdad is offline
Old 01-20-2013, 09:42 PM   #6834
boomy3555
There is NO WAY IN HE DOUBLE TOOTHPICKS That I would ever take a project down to the spot welds like you have. Where do you draw the line?
60' GMC 4000 15' flatbed dump
boomy3555 is offline
Old 01-20-2013, 09:44 PM   #6835
boomy3555
Originally Posted by hemifalcon View Post
Did this..Here's the update of the burb.. I'll let the pictures tell the story.. There were over 200 spot welds lovingly drilled out today...
Here's the driver's side outer floor and inner rocker welded in.. Still have to smooth the welds..
And--here's the mayhem I caused today.. I removed the entire inner structure in expectation of finding internal rot in the A-Pillar.. After rmoval of the dashboard and inner panel-I found that the inside was solid.
I will be coating the inside with rust converter and then using the cutaway pieces below to make everything solid.. I will sandblast all the individual pieces before slapping them together...
Does anyone re-produce these placards? I used a little Simple Green cleaner on mine to get the oxidation off, but the color started coming off worse than it already was. I figure I can get a new one if they are re-created and just stamp the original codes and numbers in the blank spaces.
And, here's the finished steering wheel. It's a GM Pewter Metallic Dupli-Color spray can color from NAPA. I think the lighting makes it look pretty close to the "Fawn" color although I was looking for more of a silver. The metallic in it is really nice-can't wait to get it in some better light.
There are more pictures in my link below showing today's work..
There's no way I'd take a project down so far. I'd let it go and get something with a little less work involved.
Old 01-20-2013, 10:17 PM   #6836
Andice
Andice's Avatar
Picked up my seat at the upholsterer's place.
Andice is offline
Old 01-20-2013, 11:06 PM   #6837
akaupp
Yesterday was new fuel pump and rubber lines. Today I installed my west coast mirrors that I picked up yesterday.
akaupp is offline
Old 01-20-2013, 11:10 PM   #6838
derail
derail's Avatar
Picked up a Flarestat hazard switch at pick-n-pull today. It's one of those things that I always wanted but couldn't bring myself to pay $100 for. $16.00 out the door. Has gmc on it instead of the bowtie, but I'll live with it. I drilled out the hole for the choke cable (don't have a choke anyways) with a 5/8" bit and it fits perfect.
derail is offline
Old 01-21-2013, 09:20 PM   #6839
E911manager
Wiring, steering column, windshield wiper motor and linkages, brake booster and master cylinder, inner fenders, inside side vents installed with new seals. Started it for the first time in 4 months..
My Build CAPRICKUP 1964 Chevy SWB on a 94 Caprice
http://67-72chevytrucks.com/vboard/s...d.php?t=492640
E911manager is offline
Old 01-21-2013, 09:25 PM   #6840
hemifalcon
Unfortunately--this is -was a California truck and there's a sentimental attachment due to the trip I took with it.... Believe me--the rust was all pretty well hidden.... Besides--you can't just discard things once you start--you have to see them through--or so I've been taught
Old 01-21-2013, 09:30 PM   #6841
jayoldschool
Moderator
That B Body cluster looks right at home in there! Nice job. The LT1 is going to really haul.
jayoldschool is offline
Old 01-21-2013, 09:35 PM   #6842
E911manager
Thanks for the positive feedback... I have driven it on the road sitting on a bucket, no doors, windshield, fenders, inner fenders, bed, etc. It does run good..
Old 01-21-2013, 10:33 PM   #6843
ABX131
ABX131's Avatar
Had a good day working on the truck despite the fact it was only 32 degrees out. All went well until I broke off a bolt that holds down the thermostat cover...Snap!
ABX131 is offline
Old 01-21-2013, 10:53 PM   #6844
mud.man.rj
mud.man.rj's Avatar
Haha, only 32 degrees, it is minus 32 degrees here, no working outside like you can.
mud.man.rj is offline
Old 01-21-2013, 11:02 PM   #6845
ABX131
ABX131's Avatar
Isn't it always frozen in Canada? Ha ha ( I am originally from BC so I can make that comment!) I forgot to add that I have no garage but with no rain it was not too bad!
ABX131 is offline
Old 01-21-2013, 11:45 PM   #6846
raic65
raic65's Avatar
Actually did it last week, but installed a class V trailer hitch, Rick's fuel tank with gen 5 Camaro fuel pump module and new poly bushings for my CPP panhard bar all in preparation to tow a mustang home from Ventura
raic65 is offline
Old 01-22-2013, 12:10 AM   #6847
mud.man.rj
mud.man.rj's Avatar
In the Northern part of Saskatchewan Canada we get a whole 2-3 months of semi warm car weather, whoohoo.
Old 01-22-2013, 12:24 AM   #6848
ABX131
ABX131's Avatar
Hey if it got too hot your igloo would melt!
ABX131 is offline
Old 01-22-2013, 07:30 PM   #6849
mud.man.rj
mud.man.rj's Avatar
Somedays I wish I was further North where the igloo's are, easy and cheap to build not like all my insulation I put in my house to keep the -20 to -30 plus weather out. Oh well a few more months and the ice will melt and a couple of months of summer, haha.
Old 01-22-2013, 08:23 PM   #6850
forestb
forestb's Avatar
I know this weather is horrible. It is almost 80 out there and I would do some work on my truck but I fear I might break a sweat.
forestb is offline
Closed Thread
