01-21-2013, 09:35 PM | #1 |
Seat question..
Will the bench seat from a 1990 silverado, be a direct fit in my 82 C10?
Thanks guys. |
01-22-2013, 01:58 AM | #2 |
Re: Seat question..
ALMOST. I just did this today. Had to get a 2 inch piece of square tubing to run along the front of the seat where the runners mounted to raise it as well as give a mounting surface for the runners, BTW, had to cut off two inches of the front of the runners after mounting it. The rear has two mounting mounting legs on each of the runners. Bolt the outside one down and drill and bolt the inside legs. Then you have to notch the rear mounting holes where they mount to the floor, the holes will be about 1/2 inch off. Measure , measure , measure.... Your holes
2004 Silverado Crewcab 1972 Chevy Monte Carlo 2017 Chevy Tahoe |
01-22-2013, 01:37 PM | #3 |
Re: Seat question..
Does the 88-91 seat give you more leg room? How is the room behind the seat?
01-22-2013, 06:46 PM | #4 |
Re: Seat question..
yes it is actually more comforable. the foam is thinner but sturdier that the springy seat. I used a 2 inch block in front of mine so it would lean it back slightly. Im am 6'3 and weigh in at about 260 so I need the leg room. it is alot more comfortable. I had to get mine in and fitted becaue I am fixing to get my interior re-done
01-22-2013, 06:56 PM | #5 |
Re: Seat question..
any chance we could get a shot of the seat. are you staying somewhat original or a little custom? nice truck. thank you
Posted via Mobile Device |
01-22-2013, 07:11 PM | #6 |
Overcamber
Re: Seat question..
yes anxious to see a pic
01-22-2013, 07:48 PM | #7 |
Re: Seat question..
01-22-2013, 07:48 PM | #8 |
Re: Seat question..
Pay no mind to the fact it's dirty, I'm fixing to get my interior redone and had to get the seat fitted
I don't know why it only posts one picture, I tried to post four, with the brace Posted via Mobile Device
01-22-2013, 07:51 PM | #9 |
Re: Seat question..
looks good and comfy. hope we can see new interior shots when done. thank you for photo.
01-22-2013, 07:52 PM | #10 |
Re: Seat question..
Just tried to repost the picture of the brace and it said t was a duplicate post , where are the other pics then
01-22-2013, 08:36 PM | #11 |
Re: Seat question..
Posted via Mobile Device Y E A , look at that professional work :-)
01-22-2013, 08:54 PM | #12 |
Re: Seat question..
Looks good
01-22-2013, 09:53 PM | #13 |
Re: Seat question..
Looks great, thanks for the info.
Does anyone know of any seats that are a direct fit on our trucks? |
01-22-2013, 09:58 PM | #14 |
Re: Seat question..
With our strange floor design, I think even GM figured it out after the square bodies
01-22-2013, 09:59 PM | #15 |
Re: Seat question..
Don't let that picture scare you off, it's not that bad of a job and that is way under the seat, you can't even see it
01-22-2013, 10:14 PM | #16 |
Re: Seat question..
Yeah, it looks great. I just don't have cutting tools, and most likely not really the skills do to that kind of thing.
01-23-2013, 07:24 AM | #17 |
Re: Seat question..
Nothing to it, it's 51.5 inches long. Cut the agles 1.5 inches and diagonal bolt it down and drill the drill the holes for the new bolts, really nothing to it. I could it ALOT faster now that I have done it once, but took a couple hours to do it the first time
01-23-2013, 12:10 PM | #18 |
buffle
Re: Seat question..
I am planning to mate the 1987 frame to the 88-98 seat. Hope it gives me more belly room.
Life is like a roll of toilet paper. The older it is, the faster it is used up. |
01-23-2013, 12:30 PM | #19 |
Frequent Flyer
Re: Seat question..
This a 93 seat in my 76 using modified 93 tracks. The seat was too high with the 93 brackets so we cut them down.
You can kind of see the where the bracket was cut down in the 2nd pic. And dont make fun of the tweed the truck is in the process of an interior overhaul! |
01-23-2013, 01:21 PM | #20 |
Moderator
Re: Seat question..
JWall, was the bracket cut level or angled since the front needs some rise? I've been looking for a nice red bench because my belly and the steering wheel are a little too close at times.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
01-23-2013, 01:35 PM | #21 |
Re: Seat question..
i have later model seats in my truck, (not 88-98) & one thing that i found to really make them shine (regardless of which seats you use), is to throw a tilt column in with the seats. it's pretty much impossible to not get comfortable then
01-23-2013, 02:17 PM | #22 | |
Frequent Flyer
Re: Seat question..
You can kind of see it in the below best I could find quickly. I can get better pics over the weekend. The trucks not at my house right now. |
01-28-2013, 01:48 PM | #23 |
Re: Seat question..
Big D and J-wall,
Thanks for the picture of the seat. I think I am going to try to find a cloth tan or brown 88-91 seat for my 84. I am 6'3'' and could use a little bit more room. I also feel like I am all up on the steering wheel. I will keep my eye out the next time I go to the pick n pull. |
01-28-2013, 11:10 PM | #24 |
Re: Seat question..
Well that's the way to go. I'm 6'3 and it helped my leg room tremendously
01-28-2013, 11:43 PM | #25 |
Re: Seat question..
1st pic is a 93 seat (60/40) in my 74 truck. 2nd pic is buckets out of a 90 suburban I picked up at the junk yard cheap. 88-91 suburban seats, bench or buckets are nicer than regular truck seats in my opinion and will fit fairly easy since the floors have the same hump as the trucks. The 88-98 c/k seat like mine are nice too, but are a pain to install. I had to cut and modify the brackets just like the seats earlier in this post.
