Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 01-21-2013, 10:20 PM   #1
travz500
travz500's Avatar
barrell fan shroud
$150 plus shipping
travz500 is offline   Reply With Quote
Old 01-22-2013, 12:04 PM   #2
McCoyAZ
McCoyAZ's Avatar
Re: barrell fan shroud
I had no idea those were worth that kind of money.
I just chopped on up. Removed the wings to make it fit another mod we were doing.
Man....I need to pay attention to values.
McCoyAZ is offline   Reply With Quote
Old 01-22-2013, 01:36 PM   #3
travz500
travz500's Avatar
I have learned the hard way on things like that myself but it happens these parts help me toward getting my truck built
Old 01-26-2013, 11:19 PM   #4
travz500
travz500's Avatar
anyone need this?
Old 01-28-2013, 02:03 AM   #5
pdxhall
pdxhall's Avatar
Not for ebay prices!
pdxhall is offline   Reply With Quote
Old 01-28-2013, 09:17 AM   #6
travz500
travz500's Avatar
whats it worth then they sell here for that when they are here
Old 02-01-2013, 12:39 AM   #7
WhippinSaw
WhippinSaw's Avatar
Hey travz500, I will take it if it will fit. My radiator is 21 3/4" wide, 3" deep. The bolt holes are 26" apart. The fan blade is 17.5" wide. Looks like I have a 62 radiator in my 63. Do you Know what the Shroud came out of?
WhippinSaw is offline   Reply With Quote
Old 02-01-2013, 09:38 AM   #8
travz500
travz500's Avatar
I have no idea what it came out of it was in the back of a 64 i bought the guy said there was more trucks there at one time so not sure which one it came from I will do some measuring here in a little while for you thanks
Old 02-01-2013, 10:40 AM   #9
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Here's a good post that lists the different shrouds for the 60-62 trucks:
Originally Posted by Brad54 View Post
There are actually three different shrouds available for '60-'62 trucks.
Manual-trans 1/2-ton, early version, is shown upper left.
I've found one of those in a junkyard on an untouched '60 or '61... it was rotted away, so I left it, but it's the same one shown.
What I think is a later 1/2-ton shroud ('62, maybe '61) is the one on the upper right. The barrel at the radiator is wider than the mouth at the fan, so it covers more area on the radiator.
If you have an original automatic trans truck, you also got a bigger radiator, and it had the trans cooler built into it.
The automatic shroud is a full shroud that covers the whole radiator, has a notch at the bottom corner for the trans cooler lines, and attaches to tabs brazed onto the mounting flange of the radiator. Shown on bottom.
The other two don't cover the whole face of the radiator, and they mount using the six bolts that hold the radiator to the core support.
The auto-trans radiator and the 3/4-ton and up radiator are wider and a little taller, but are a direct bolt-in to a 1/2-ton '60-'62 truck. The core support, at least on my '61 Suburban, has the blind nuts in place for both radiators. They made-up the difference in the width of the core by making the mounting flanges narrower, thus keeping the mounting bolts in the same location, but put one farther down the core support.
Over a couple years, I scored all three of these shrouds... I put a 3/4-ton 4-row radiator in my '61 Suburban, and kept the full auto-trans shroud for it....clip....
-Brad
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 02-01-2013, 11:01 AM   #10
travz500
travz500's Avatar
thanks
Old 02-01-2013, 11:16 AM   #11
travz500
travz500's Avatar
ok if you look at the ones that Lostmy65 posted mine is the same as the top left one it is 26" between bolt holes and it measures 19 1/2" across so your fan should fit and the 3" radiator appears it should fit just fine I did some measuring the only thing I noticed is someone bent the flange strait where the bolts bolt it to the radiator support but I had some had seamers and it was bending back just fine and is not noticable I will bend it all back before I ship it if you want it let me know thanks
Old 02-01-2013, 05:31 PM   #12
WhippinSaw
WhippinSaw's Avatar
Looks like it will fit so let me know what shipping is. I don't have a brake or seamers so if you could fix it that would be cool. I'm not an ebayer so hopefully shipping isn't to much. Thanks travz500
Old 02-01-2013, 05:38 PM   #13
travz500
travz500's Avatar
well I dont do ebay either tried it once never sold or bought anything but I have sold quit a few parts here I flatten it out after i posted the first reply I held it up to our 61 c-30 and it looks like it would fit perfect in there so I guess it will fit yours pm me your zip and I will see what shipping will be thanks
Old 02-01-2013, 05:41 PM   #14
WhippinSaw
WhippinSaw's Avatar
Thanks LostMy65, I saw your post in that thread and grats on scoring a shroud for your truck. Did you end using shims? Looks like everything else was good. Thanks again for your help
Old 02-01-2013, 06:07 PM   #15
travz500
travz500's Avatar
SOLD to whippinsaw thanks again Daniel will get shipped tomorrow if I have a big enough box here thank you
Old 02-01-2013, 09:39 PM   #16
kpc01
thanks for posting those pictures above. I have 1 or 2 of these and wasn't sure what was what!
kpc01 is offline   Reply With Quote
Old 02-01-2013, 11:13 PM   #17
WhippinSaw
WhippinSaw's Avatar
Answered some question for me to. Here is the original post that Lostmy65 quoted
http://67-72chevytrucks.com/vboard/s...d.php?t=364381
Old 02-02-2013, 05:49 AM   #18
LostMy65
LostMy65's Avatar
Yes, I had to use 1/2 spacers.
Looking at my radiator compared to others of that generation, mine appears to be a little thicker.
I'm real happy with how it turned out.
There's pics in my LostMy65 titled thread.
