Steering Column Donor
My restoration project has begun on a 71' GMC Sierra. The steering column needs replaced and am shopping for a replacement. Other than the obvious same year/model donors what other year/models will work as a "easy" replacement? I don't want to do a bunch of rewiring or fabrication and money is an issue. Thanks in advance for the help.
Moderator
![]() Join Date: May 2007
Re: Steering Column Donor
Van columns up until 1980. You would need to shorten your intermediate shaft (quick and easy) You would need to get a horseshoe wiring adapter (around $20). They are pretty close to plug and play columns, plus you might also be able to upgrade to a tilt if you find one in the junkyard.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
