Old 01-22-2013, 09:01 PM   #1
savatreatabvr
savatreatabvr's Avatar
Oil Filter Shootout!
There are too many different "Oil Filters" on the shelf at your local parts store! I've always bought Fram oil filters but since the others are claiming they do so much more I decided to try one until I saw the prices, I'll buy the most expensive one if it's really worth it but I want your opinions first!
Here are your choices:
MicroGard - Oil Filter $4.49
WIX - Oil Filter $7.49
FRAM® Extra Guard® - Oil Filter $4.19
FRAM® High Mileage™ - Oil Filter $7.99
Bosch Premium - Oil Filter $7.49
Mobil 1 - Oil Filter $12.99
K&N Engineering Performance Gold - Oil Filter $13.99
ACDelco Duraguard - Oil Filter $4.19
ACDelco Duraguard - Oil Filter $3.69
ACDelco Duraguard - Oil Filter $6.99
ACDelco Duraguard - Oil Filter $27.99
ACDelco Duraguard - Oil Filter $16.99
Is there really that big of a difference between a $3.69 oil filter and a $27.99 oil filter?
savatreatabvr is offline   Reply With Quote
Old 01-22-2013, 09:10 PM   #2
Damon23
Damon23's Avatar
Re: Oil Filter Shootout!
I've always ran ac delco on my gm cars, Motorcraft in my excursion and ill use mopar for the new challenger when it comes time. If the manufacture uses it then it is good enough for me.
Damon23 is offline   Reply With Quote
Old 01-22-2013, 09:30 PM   #3
71swb4x4
71swb4x4's Avatar
Take a look at this: http://www.gmtruckcentral.com/articl...lterstudy.html
and his grade sheet here: http://www.gmtruckcentral.com/articl...gradesheet.htm
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 01-22-2013, 09:57 PM   #4
INSIDIOUS '86
INSIDIOUS '86's Avatar
I just went with a hp 6002 K&n gold oil filter. In my case I'm more concerned about flow than filtering.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 01-22-2013, 10:12 PM   #5
GM-power
GM-power's Avatar
I put a mobile 1 filter on my last oil change. I don't do scientific tests on my filter but I've heard goods things about them.
1979 Sierra Classic Heavy-half
1996 Silverado x-cab "the daily"
GM-power is offline   Reply With Quote
Old 01-22-2013, 10:24 PM   #6
zaccaglin
zaccaglin's Avatar
I've always used wix filters, even but them from a mom and pop local auto part store/machiene shop that's been in my town for 80+ years.
Zaccaglin
1998 Chevrolet C1500 Ext. Cab 350
Former Rig:
1985 Chevrolet K20 Suburban 6.2L Detroit/TH400/NP208
zaccaglin is offline   Reply With Quote
Old 01-23-2013, 03:45 AM   #7
INSIDIOUS '86
The K&n and Mobil one filter use the exact same filter media and made in the same place
Old 01-23-2013, 04:26 AM   #8
78 Big10 454
78 Big10 454
78 Big10 454's Avatar
I use whatever is cheapest - cause that's the way I am!
1978 Chevy SWB C-10 2WD 454/400
78 Big10 454 is offline   Reply With Quote
Old 01-23-2013, 06:21 AM   #9
tucsonjwt
X2 on cheap, especially if you change oil frequently, like every 3,000 miles and a few months. I have 6 filters in the shed which came with a free or nearly free package deals - mostly Fram. The main difference in filters is size - the original GM filters were longer (more media?), the replacement AC Delcos are smaller.
Our old trucks are not super sensitive modern machines, so I don't think a super expensive filter makes much difference. I have never heard of an engine failure due to a cheap filter - can anybody document one? If I changed my filter every 12,000 miles I would get an expensive filter.
tucsonjwt is offline   Reply With Quote
Old 01-23-2013, 08:02 AM   #10
xrcr
never had any trouble with Wix filters/Napa Gold filters
xrcr is offline   Reply With Quote
Old 01-23-2013, 08:27 AM   #11
mrhino
I used to work at several different parts store and many times the oil filter rep would come in and grab several filters of the shelf and cut them open right there. Iv seen first hand the fram filters are the cheapest made and appear to be the least effective. they have cardboard end caps glued to the filter media and either a thin string or a rubberband ( iv seen both) wraped around the filter media. Wix filters always seam to be the best constructed, Metal end caps, crimped around good quality media. most have anti drain back valves built in. Wix makes many of the filters out there, like napa gold, Carquest, Amsoil, Im not positive but im thinking the k&n as well. Puroilator is another good filter. I have not done any testing but this is just what iv seen when cut open.
mrhino is offline   Reply With Quote
Old 01-23-2013, 08:46 AM   #12
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
To save time for everyone: based on 5 criteria
30um Filtering (wt 5)
Overall Build Quality (wt 5)
Media Surface Area (wt 1)
Media Volume (wt 1)
Price Paid (USD) (wt1.5)
Best value:
#1 XG5 Fram Xtended Guard!! (I use these exclusively on my trucks)
#2 M1-302 Mobil 1
#3 30-1218 Royal Purple
#4 (tie) HP-3002 K&N
#4 (tie) EaO24 Amsoil
#6 21060 Napa (rated below 3 on scale)
#7 Don't bother running!!
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 01-23-2013, 04:55 PM   #13
Jeepwm69
http://www.300cforums.com/forums/gen...dissected.html
After looking at the fram "orange can o death" and some of the others, I wait till autozone has a sale on the GTX oil with a Bosch fliter, then stock up. I buy the oil change "special" for $21.99 using my rewards card, so it turns out to be buy 5, get one more or less free. Was a lot better when the special was $12.99 or $13.99 (circa 2007-2008), but still cheaper than I can get good oil and filters elsewhere.
And the govt says inflation is under control......
Jeepwm69 is offline   Reply With Quote
Old 01-23-2013, 06:22 PM   #14
gchemist
gchemist's Avatar
Opps, I meant to say I use Purolator Premium equivalent of Xtend Gaurd in my trucks.
Old 01-23-2013, 06:41 PM   #15
shawno72
C/10 junkie
shawno72's Avatar
Some great info. Looks like I will start using the fram extended guard.
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 01-23-2013, 06:46 PM   #16
Eyegore
What Hump?
Eyegore's Avatar
Alway used the high mileage fram on my trucks, currently my 99 suburban has 214k miles never been rebuilt same for the tranny.
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
Old 01-23-2013, 09:47 PM   #17
superwade57
X2 on napa gold or wix. And I've cut open frams and will never ever use on anything. Bosch also seems to be good stuff.
I use gtx high mileage in my 01 Tahoe (212,000 miles) and reg gtx on everything else with napa gold filters. Ran the same on my 97 ram 5.9 gas until the tranny lost reverse at 225k miles silly dodge lucky it lasted that long but motor was very strong still
superwade57 is offline   Reply With Quote
Old 01-23-2013, 09:52 PM   #18
Wazup
I use to run Fram until I found out that the Fram drop my Oil pressure by 5, I run ACDelco with No Problems .....
Wazup is offline   Reply With Quote
Old 01-23-2013, 10:11 PM   #19
savatreatabvr
Excellent information guys, thanks alot! Scientific studies are great but hearing a working mans testimony on his experience with his own personal vehicles is knowledge not earned but most definitely appreciated! Keep it coming!
Old 01-23-2013, 10:23 PM   #20
UPNADM
UPNADM's Avatar
In a former life I was a dedicated filter representative for Affinia Canada, which was a manufacturer of WIX filter. While things might be different today, our filters where branded in several different brands.
With all this in mind, I had a few cutaways still boxed up in my garage from my trade show/detailing days.
This is not to make any assumptions what is good or what is bad, just merely show you what different brands look like on the inside.
UPNADM is offline   Reply With Quote
Old 01-23-2013, 10:23 PM   #21
UPNADM
UPNADM's Avatar
More cutaways...
Old 01-23-2013, 10:24 PM   #22
UPNADM
UPNADM's Avatar
As mentioned things may be different now, but when I worked there Affinia/WIX made the same filter for the WIX brand, CARQUEST brand, NAPA brand, MOPAR, AC Delco, Motorcraft and a few other major brands.
Here are some of the cutaways from the Affinia/WIX brands.
Old 01-23-2013, 10:30 PM   #23
Redcap
I won't use anything by Fram (or Pennzoil). Ever.
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF
Redcap is offline   Reply With Quote
Old 01-24-2013, 01:47 AM   #24
andrewmp6
I will only use wix ,napa gold or motorcraft and yes sometimes the ford ones can fit other stuff.
Old 01-24-2013, 11:17 AM   #25
Desert1957
Desert1957's Avatar
Here is something for you to think about, My engine guy tells everyone he sells his race engines to. If it comes back with problems and a "FRAM" filter is on it the warranty is void.
This guy does hundreds of engines a year from stock to NHRA pro-mods, I personally have a 327 short-block he did for me that makes 600 HP. What he wants he gets, no questions.
Wix on all my stuff, "System One" reusable on my race engines.
Desert
PS: Here is a good read about filters, also has a detailed break down of the internal construction.
http://www.system1filters.com/oilfilters.htm
Desert1957 is offline   Reply With Quote
