Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 01-23-2013, 02:43 PM   #1
MattBMiller
MattBMiller's Avatar
Disc Brake Axles?
I just picked up a 71 GMC 5500. I'm planning on building a custom western hauler style bed for it and using it to haul hot rods and tractors to shows. Planning on a 12 valve 5.9 Cummins with a 6 speed manual.
I'd like to get disc brakes up front. Are there any axles that are a direct bolt in or are the P30 knuckles the way to go?
The rear axle is a 7.17/9.76 right now. I have my eyes on a new Spicer S110 axle out of a Ford F550 that I may pick up for it, that would get my disc brakes in the back and a 4.10 gear.
MattBMiller is offline   Reply With Quote
Old 01-23-2013, 02:45 PM   #2
MattBMiller
Re: Semi Modern Axles
A couple pics. This is the bed that came on it. Pulled that off and hoping to get going on the bodywork and drivetrain removal this weekend.
Old 01-23-2013, 06:17 PM   #3
6066gmcguy
6066gmcguy's Avatar
Re: Disc Brake Axles?
You need to find a NEWER truck that has disc brakes on it. a 5500 is a pretty heavy truck, you won't want to use parts from a one ton (30 series) they would be too small.
The Ford 550 mite be OK, but you shoud get both front and rear axle and then only haul what those axles are rated for on the truck and not what the truck is rated for now.
Some poeple I have heard are using axles from those newer mid size cabover trucks.
Jolly ~ The 6066 GMC Guy
Try the 6066 GMC Guy Facebook Page
Jolly's Truck & Car Show Page!
6066gmcguy is offline   Reply With Quote
Old 01-27-2013, 01:34 PM   #4
KQQL IT
At the body shop.
KQQL IT's Avatar
Look for a 89 c 60 drove one with disc brakes on all 4 corners. And later model U haul trucks
KQQL IT is online now   Reply With Quote
Old 02-14-2013, 07:10 AM   #5
D13
D13's Avatar
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 02-14-2013, 09:03 AM   #6
C10 - C90 Bill
C10 - C90 Bill's Avatar
Nice looking truck. Looks real clean and looks like it has real nice sheet metal. Like the Spoke Wheels.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
C10 - C90 Bill is offline   Reply With Quote
Old 02-14-2013, 12:31 PM   #7
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Nice, clean truck Matt! Subscribed.
ETsC10 is offline   Reply With Quote
Old 02-15-2013, 03:48 PM   #8
D13
D13's Avatar
My apologies moderator. My forgetful errror.
1987 2 ton
Old 02-16-2013, 11:27 AM   #9
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Accepted and thanks...only part of the mod thing I hate.
Ellen
Forum Guidelines and Rules
Buying and Selling Code of Conduct
Become a Board Supporter!
Truck FAQ
Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member...
Old 02-16-2013, 04:16 PM   #10
mrolds88
Why not look at the late model c4500 and c5500 trucks?
keep it all GM then.
mrolds88 is offline   Reply With Quote
Old 02-16-2013, 11:38 PM   #11
rkn463
rkn463's Avatar
I picked up an 89 C-60 recently for that very thing. It has 4 wheel discs with hydro-boost. It will stop ona dime! The problem I have is the fron axle is much wider than my 68. I haven't had a chance yet to pull them apart to see if the knuckles from the 89 will fit the older axle. If not then I'll be looking a set of 68-72 c70 fenders as they have a wider flare. I'm 99% sure that the chevy a and GMC fenders for this series are interchangeable.
One problem I see that you would have is that the type I am speaking of is a ten lug wheel unlike what your truck has. Wheels to fit that specific 10 lug pattern are very hard to find in anything but "widow makers" or 19.5's.
Great looking truck you have there!
-Richard
I may have too many Chevys... Is that possible?
68 c50 pickup build: http://67-72chevytrucks.com/vboard/s...d.php?t=704713
rkn463 is offline   Reply With Quote
Old 02-18-2013, 07:20 AM   #12
D13
D13's Avatar
Mine has 20" steel Budd style wheels. I'll have to check if they are 10 bolt but I believe so. I think there was a lot of transition in that period and the wheel combo is very load range sensitive. Mine's under 26K GVW, was apparently a Ryder truck and then a light duty landscape dump.
1987 2 ton
Old 02-19-2013, 11:36 AM   #13
Woogeroo
ya'll know the big semi trucks still use drum brakes... I'm just sayin'.
-W
Woogeroo is offline   Reply With Quote
Old 02-19-2013, 11:55 AM   #14
KQQL IT
At the body shop.
KQQL IT's Avatar
-W
And air which is far better than juice drum brakes.
Also the next 5 Pete's we have will be air disk brakes.
Old 02-19-2013, 06:08 PM   #15
D13
D13's Avatar
I was wrong, mine are 10 bolt steel Budd's in 22.5.
Next door is KW 10 yard dump with a set of polished Aluminum Budds with super singles on the front... droool.... He's got 30 wheels...
1987 2 ton
Old 02-23-2013, 03:55 PM   #16
rkn463
rkn463's Avatar
You are very lucky, the 22.5's in our lug pattern is extremely difficult to come by.
-Richard
Old 03-04-2013, 02:41 AM   #17
V3500KING
V3500KING's Avatar
-Richard
So what years came with disc brakes? I am looking to get one of these heavier duty trucks and would like to have them.
V3500KING is offline   Reply With Quote
Old 03-10-2013, 12:20 AM   #18
rkn463
rkn463's Avatar
I do not know
