11-01-2003, 03:29 PM | #1 |
Stylin
warm up idle
i have a 600cfm edlebrock performer carb with electric choke and the damn thing idles so high that i spin the tires everytime i put it into gear until the choke lets go, this is especially bad when im on a gravel road and i sit there and power stall does anyone know how to adjust the choke on this????
Ive been traveling for some time, with my fishin pole and my bottle of shyne. Most Girls like finished products and just dont understand what a good addiction does for you http://www.paulwall.us/ |
11-01-2003, 11:09 PM | #2 |
Is there a black canister on the left side of the carb (when looking from the front of the truck toward the back)? If there is, there should be three screws holding it on. Loosen the screws and rotate the canister, not sure which way. If you look on the canister, it should say Rich and Lean with arrows pointing oppisite directions. Rotate it toward the lean side. This will let the choke open sooner. Hope this helps some.
"When I start my car in the morning I want the neighbors to think the world is comming to an end." Homer Simpson I'm not stuck, I've still got some gas left" |
11-02-2003, 02:13 AM | #3 |
Stylin
yea i didnt notice it at first but it was on the 4th line on the rich side and i moved it all the way back to 2 on the lean side. how is my truck gona act in the morning?
11-02-2003, 03:20 AM | #4 |
Formerly yellow72custom
Here is what you need to do:
Start the truck up in the morning when it is cold, pop the hood, and loosen the 3 screws that hold down the black plastic electric choke adjsutment. When the engine reaches the temp that you want the choke to come off at (say....140?), turn the choke adjustment to the rich position until the choke flap on the carb starts to close...then move it back 1 mark lean, tighten it down, and you will be good to go
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
11-02-2003, 05:11 AM | #5 |
Guys are right on the money, mine did about the same until I used that method.........
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
11-02-2003, 12:17 PM | #6 |
so did mine, but there is also a screw underneath the choke on my q-jet, that i adjusted that brought down the high idle.
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
