Old 01-24-2013, 08:33 PM   #26
SS Tim
SS Tim's Avatar
Re: Stock rear gear ratio info
Here is a 70 C10 power team chart for you. It really helps to post what year and series you have when asking a question like this.
SS Tim is offline   Reply With Quote
Old 01-25-2013, 10:16 AM   #27
Olive1970
Olive1970's Avatar
Thanks Tim, but yes it is a 1970 C10. I didnt know if mine had a different ratio than 3.07 because at 75mph the truck runs at about 3800rpms or so. I do have a built TH350 and 2200 stall converter however so that is probably part of the higher rpms.
Olive1970 is offline   Reply With Quote
Old 08-07-2013, 11:31 PM   #28
begrab63
Originally Posted by Olive1970 View Post
Wanted to bring up this subject again...my truck SPID is a factory TH350 trans with a 307 engine. Likely rear gear ratio? It seems that most of the 350 engines were 3.08 gear ratio with automatic, didn't know if it would be different on a 307 engine?
Thanks!
I have a 71 C-10 with a 307ci and the rear gear is 3:08...
begrab63 is offline   Reply With Quote
Old 09-13-2016, 06:53 PM   #29
X Baldwin Motion
X Baldwin Motion's Avatar
Tim (or anyone) do you have a chart like this for a 68 K20?
I have a burb that was a 6cyl 4spd and a pickup with 327 240hp 4spd
They both have the 10 bolt rear.
The truck screams in 4th gear at 50mph
1985 Custom Deluxe long bed 305 3 on tree
2015 Silverado "Great White"1987 K20 dump and plow
1968 K20 327 long bed 4spd big blue
68K20 SuburPan 4spd
79C30 L96 6L90e
86 K10 plow
X Baldwin Motion is offline   Reply With Quote
Old 09-13-2016, 07:35 PM   #30
SS Tim
SS Tim's Avatar
Thats an easy one, 4.57:1.
All you needed to do was click on the link in my signature, most are there.
http://67-72chevytrucks.com/vboard/s...05&postcount=5
4.57 gears spinning a 31" (stock 7-17.5)tire @ 50 mph = about 2475 rpm, that isn't exactly screaming. The indirect drive T-221 t-cases were never quiet.
Old 09-13-2016, 08:10 PM   #31
X Baldwin Motion
Thanks, I found the link right after I posted. So the T221 makes that jet sound normally? It starts whining at 40 and close to 50 I need ear protection.
68K20 SuburPan 4spd
79C30 L96 6L90e
86 K10 plow
Old 09-13-2016, 08:39 PM   #32
SS Tim
SS Tim's Avatar
Have you checked for the proper fluid and level at all the driveline locations? The front axle, both cardon joint balls, transfer and rear axle have a 6k service interval per the driver's handbook pgs 55-57. SAE 90 dino covers most people's use of these trucks. If, with verified correct gear oil and level, its still objectionably noisey I'd look into wear and excessive clearance issues.
Have replacement parts in hand before pulling anything apart.
The idler and output shafts should have zero end play, as in 0.00" is considered ideal as measured with a dial indicator
Suggested reading
68 Overhaul Manual pg 7-111/PDF pg334
68 Service Manual Sections 0 and 3
Old 09-13-2016, 08:50 PM   #33
X Baldwin Motion
I've checked front and rear ends, trans and transfer case. All topped up with 90w
Cardan joint balls?
The noise is worse under load, it quiets a bit when I let off the gas, clearly coming from transmission or transfer case
68K20 SuburPan 4spd
79C30 L96 6L90e
86 K10 plow
Old 09-13-2016, 09:17 PM   #34
SS Tim
SS Tim's Avatar
Cardan joint balls?
The cardon joint balls are the front axle shaft u-joint swivel housings, they have seperate filler plugs L&R and in checking the driver's handbook are to be filled with SAE140 vs the differential's SAE 90.
Old 09-13-2016, 09:27 PM   #35
TwoFiftyShifter
I always thought 3.08 and the granny 4 speed was a sweet combo. No need for overdrive and can still pull a house in first. Just watch the gap between gears!
1982 K10 SWB
1987 V20 - Sold - Doh!
TwoFiftyShifter is offline   Reply With Quote
Old 09-13-2016, 09:38 PM   #36
SS Tim
SS Tim's Avatar
Suggested reading and in hand resources.
Old 09-13-2016, 10:03 PM   #37
X Baldwin Motion
Thanks, that's great I wish I had them. Unable to download the manual onto my phone. Just need to see diagram or know where fill is for cardan joints.
68K20 SuburPan 4spd
79C30 L96 6L90e
86 K10 plow
Old 09-13-2016, 11:35 PM   #38
SS Tim
SS Tim's Avatar
Here...
