01-25-2013, 10:28 AM | #26 |
Re: DM Mild/Stage 2 Rear Coil Over Pics
Yes, with bags, you will lay frame with the extreme drop member, and touring if you are running a shorter tire.
01-25-2013, 10:31 AM | #27 | |
01-25-2013, 10:35 AM | #28 |
That was a typo, my apologies. The ride height will be 1" lower.
01-25-2013, 10:54 AM | #29 | |
We have found it best to reference a specific point on the truck to measure from... and call that "ride height". We take a measurement from the bottom of the frame under the front cab mount to the ground and reference this measurement. It can then be compared to the customers truck and they will know how much drop or lift it will have compared to their current height... make sense? We also take a measurement from the bottom side of the frame under the rear cab mount. On this truck, he is running a 26.3" tall tire and a 2.5" McGaughy's drop spindle up front. The bottom of the frame to ground measurement under the front cab mount is right at 6". Throw a Touring DM on there and it will be at 5". Change the tire size and it will vary the height as well. A popular combo up front would be a 28" tall tire and a CPP 2" drop spindle... with this combination it would raise the front measurement another 1.5" but fill the wheel well up a little nicer. Another thing to keep in mind, is that when going to a Touring Dropmember, it may be necessary to modify or go to a replacement inner fender well. On the rear he is running a 28.5" tall tire and the bottom of the frame to ground measurement is 8". He has right at 3" before his axle bottoms out in the notch. Hope that helps clarify the drop it has... I know it's a longer way to describe it, but much more accurate when making comparisons. Nate
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
01-25-2013, 11:02 AM | #30 |
Yeah, what he said ^^^^ lol
Thanks for the extra clarification. |
01-25-2013, 11:05 AM | #31 |
C/10 junkie
Thanks guys. You can't get much clearer than that
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" |
01-25-2013, 11:30 AM | #32 | ||||
The front can be used with a shockwave, but the rear will be a traditional bag and shock set-up. Quote:
Dropmember Touring This was our performance variation that we introduced a couple years back. It only narrows the trac-width .25" per side, but also has the same benefits as the extreme. The suspension geometry is much more aggressive and designed for performance. It can be run with a coil-over or airbag. It is possible to lay frame with this variation depending on spindle and tire diameter. There is no notching of the frame for rack and pinion clearance with this version. The "Touring" is right at a 2" drop when compared to the factory crossmember. Dropmember Mild This is the EXACT same thing as the Touring version, but 1" less drop built into it. Quote:
We don't currently offer any rear components for the 73-87 Blazer or Jimmy, as they have a completely different chassis than the trucks. Nate
01-25-2013, 09:38 PM | #33 |
Nate does the Touring or Mild dropmember move the tires up in the fender like the extreme version. I currently have the forward arms now, would these be compatible with the touring or the mild dropmember or would I need new arms.
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
01-25-2013, 10:11 PM | #34 | |
Nate Posted via Mobile Device
01-26-2013, 12:33 AM | #35 |
Thanks Nate that's what I figured.
02-10-2013, 06:41 PM | #36 |
02-15-2013, 02:08 PM | #37 |
Boosted Member
Nice setup guys. Awesome parts and great customer service. I'm kinda wishing I would have gone with a coilover DM up front instead of what I chose.
However, I do have porterbuilt rear suspension....sorta. My hacked up PB trailing arm to allow coilover mount, and panhard rod You can kinda also see my modified PB trailing arm crossmember with built in trans mount.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2023 Ford Explorer ST - Twin Turbskis 2023 Ford F150 RCSB - Whipple Supercharged 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
02-15-2013, 02:32 PM | #38 | |
Been a crazy week, and running short handed. We had the flu go through the shop and it knocked the shop manager (my dad) out for a week! Dave missed a day, and I have been feeling it as well, but pushing through it!
02-15-2013, 02:34 PM | #39 | |
I will have to go take a peek at your build thread. Nate
02-18-2013, 11:42 AM | #40 |
Boosted Member
Yep, it's a blazer. 4x4 to 2wd swap.
07-11-2013, 10:23 PM | #41 |
I've been looking all over the Porterbuilt website and cant for the life of me find the rear coil over set up anywhere? I'm just working out pricing right now and wanted to see what it is going to run me. Any clue to what the rear touring setup with coil overs will run?
Rob 1971 c10 - ground up in progress Tripp's Speed Shop Build - http://67-72chevytrucks.com/vboard/s...d.php?t=589750 |
07-11-2013, 10:28 PM | #42 |
Check azproperformance.com they can get it I bet
Posted via Mobile Device |
07-11-2013, 10:31 PM | #43 |
Oh cool. Thank you!
07-12-2013, 01:26 PM | #44 |
So can we know what that center section is now? Haha
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
08-05-2013, 07:25 PM | #45 |
What is the difference in ride height when using a Shockwave? Do the Ridetech coilovers and Shockwaves have the same eyelet/eyelet measurements when at ride height?
08-06-2013, 03:59 AM | #46 | |
http://item.mobileweb.ebay.com/viewi...341&cmd=VIDESC Posted via Mobile Device
Scott |
08-06-2013, 06:49 AM | #47 | |
A day late and $1 short...
http://67-72chevytrucks.com/vboard/s...d.php?t=588497
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
08-21-2013, 08:50 AM | #48 |
I'm basically going to be running the stage 2 with the coilover setup and my factory trailing arms. Does the coilovers eliminate the need for springs on my trailing arms?
Thanks, Scott Duckworth Posted via Mobile Device
Scott |
08-21-2013, 09:02 AM | #49 |
Yes
08-21-2013, 09:41 AM | #50 |
Thanks Buck
Scott |
