01-25-2013, 06:14 PM | #726 | |
Re: Slosh Tubz new company project "Square Peg" frame laying 1987 GMC Jimmy
another option might be turbocharging or fitting a centrifugal supercharger to a otherwize stock motor , it would give a great wow factor to the motor too compared to the prices of the fast setup it doesnt cost a lot more extra the supercharger will give a ton of power down low , it will pull the towhitch right of the trailer , you are going to need a little bigger radiator though to keep everything cool enough to operate under boost for a longer time at highway speeds pulling cloud 9 , at low boost putting in 1 extra injector operating by a boostswitch mounting a stronger fuelpump and putting in a boostreverenced fuelpressurevalve should be enough to keep the fuelratio in the green i seen a lot of turbo stuff using the lq and ls type motors they seem to be able to handle boost verry whell
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
01-25-2013, 08:27 PM | #727 |
Ls1 intakes are cheaper than the ls6 intakes. Ls6 intakes make a little more power, but more importantly they don't have a large hole in the top of them for an egr valve like the ls1's do. You can block it of with a freeze plug but it doesn't look as good. Last time I checked it was pretty easy to find a ls6 intake for around $300-$350 but it's been a while since I've looked.
1968 chevy lwb, getting ready to join forces with the 70 gmc 1970 gmc swb, getting ready to be a 68 chevy swb 1971 gmc lwb 2500 2wd Sierra Grande 1988 chevy 1-ton crew cab 2wd waiting for a 12v cummins |
01-26-2013, 08:14 AM | #728 |
Just call me "Johnny-Come-Lately", page 30 and I'm just now getting in on it and subscribed. Better late than never right?? lol
Admittedly I am quite the newby, however, I did notice that this is a lot of talk about intakes going on and something you may want to consider in the decision is the heads. I may be wrong, but I'm pretty sure that the ports on the LS- truck heads are a "Cathedral Port" design. If you're using the stock heads on an LS truck engine they may be different from the port design on the intakes built for the cars (Corvette/Camaro). I don't know how different the Cathedral port design is from the oval or square port, but you definitely want them to match.... again just a newby, but the thought crossed my mind anyhow.
"I just don't think my Suburban Has much to do with climate change, oh woah, Has much to do with climate change and my mind you cannot change..." Tim Hawkins - Free Bird Parody |
01-26-2013, 09:43 AM | #729 |
Happy to be here
When your trying to decide what intake to run, note that most of the low pro intakes make the motor look squished. They sit low in a square making them look even flatter. If asthetics are of concern, you will need a taller truck style intake.
01-26-2013, 09:50 AM | #730 |
That's squished area is where the supercharger goes.....duh
Jim '71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E '57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works '87 BMW 325i - daily driver |
01-26-2013, 11:27 AM | #731 | |||||||
67cheby
I would love that.....just cant afford that ! LOL |
01-26-2013, 11:30 AM | #732 |
Happy to be here
Good idea. I like spending other peoples money for them.
01-26-2013, 11:34 AM | #733 |
Happy to be here
If you really want some "wow" factor under the hood, consider on of the Harrop intakes.
01-26-2013, 12:06 PM | #734 |
67cheby
i think i am in love....i would take that over the supercharger !
01-26-2013, 01:30 PM | #735 |
$5000 DAMN haha
01-26-2013, 01:34 PM | #736 |
expencive maibe but oh wow
http://www.youtube.com/embed/NK1JThr...layer_embedded btw check out the australian raptor supercharger there about 3000 dollar new not sure if they have a setup that will fit the LS1 though
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts Last edited by watahyahknow; 01-26-2013 at 01:48 PM. |
01-26-2013, 03:59 PM | #737 |
I agree!!! That thing is real purdy.
01-26-2013, 04:17 PM | #738 |
the single intake tubes on the harris intake will kill all the low down grunt i was thinking about sumting like that on a turbo motor but the builder advised me not to as it would be out of the operating range of the turbo's cam and basicly the engine as a whole
another nice option would be the stock coveringplates from a corvette painted in the same colour as the body and some plate over the intake itself , i seen it a few times and it looks verry clean you might even be able to let that plate flow intoo the same type of radiatorcovering you did on cloud 9 and hide the airfilter under it too
01-26-2013, 06:36 PM | #739 |
The ls1/ls6 intake will work with truck heads just fine. If you get into the ls3 and newer heads they will not. But that doesnt really matter for you because to run those heads you gave to have a bore bigger than 4.000 which the 5.3 doesn't have
01-26-2013, 06:38 PM | #740 |
VA72C10
You're thinking about this all wrong.....you need a sponsor for your intake or supercharger....
Looking for a 67-72 swb or blazer project in or around VA. |
01-26-2013, 08:41 PM | #741 |
Exactly what I was thinking....
01-27-2013, 10:36 AM | #742 |
Mikey...thought u and every one else need to check these guys out...someone posted this on lateral-g.....talk about every fab skill explained....check out the hidden door release for shaved doors when they won't work............jim
http://www.jefflilly.com/fabrication/#
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791 |
01-27-2013, 12:11 PM | #743 |
You think that cool, look at his 11 year old son!!!!!!!! Wonder how old he is now? Amazing stuff they do there, and the write ups are killer.
http://www.jefflilly.com/fabrication/metal-work/
67- 72 Parts collecter |
01-27-2013, 03:12 PM | #744 |
its all in the feel for the material and less to do with strength , i think a young person would learn it eazier as long as hes somewat patient
i used to work with the paintstripper at a place where they overhaul airliners we where packed in pretty good but i was sweating and after wiping myself off i noticed there was a blob of the stuff on my sleeve i used to wipe my forhead with , it turned intoo a cartoonish (myheadisonfiremyheadisonfire) run to the badroom to wash the stuff off and i had a big red burn on it for a few weeks after , the kid actually shouldve worn long sleeves along with the gloves when working with the stuff
01-28-2013, 11:34 AM | #745 |
67cheby
LOL...maybe i can find an intake sponsor dont think i wont ask ! LOL That is some pretty cool fab stuff !
Here is what we did this weekend, got the frame table unloaded (wheel welded back on) started mocking up stuff I was revisiting the thought of using the stock frame once again but once i trim off the bottom of the frame i will then have to lift my front crossmember so...i think it is complete frame now ! I did make a template of the outside of the complete frame rail |
01-28-2013, 12:14 PM | #746 |
Diggin this phase! So---is the frame the same on a 4-by as a 2-by? Particularly the front crossmember 'arch'. And while I'm asking, maybe a '69-'72 K-to-C Blazer conversion veteran can chime in on the same Q for that gen.
JK
JK |
01-28-2013, 12:16 PM | #747 |
67cheby
yes the frame is the same the 4x4 just doesnt have the factory holes for the crossmember to bolt in like the 2wd does
01-28-2013, 12:27 PM | #748 |
"I was revisiting the thought of using the stock frame once again but once i trim off the bottom of the frame i will then have to lift my front crossmember so...i think it is complete frame now !
I did make a template of the outside of the complete frame rail " I missed that line---I see now that the Scott's crossmember is lower than the rails. As an alternative to a custom frame, a 2wd square body frame would be easier to find (and cheaper) than a 1st gen C blazer---would that have the correct front crossmember location? Alternative #2--how about a C10 frame from the front horns back to the rear notch cut? JK
JK |
01-28-2013, 12:29 PM | #749 |
Oh, didnt realize you were replying my first post while I was pondering the second. ......nevermind!
JK |
01-28-2013, 12:36 PM | #750 |
wow mike youre flying , missed a few pages , ive been busy u know why !!! looking good bud !!!!
check out my build thread 71 c/10 step side 5.3 twin turbo http://67-72chevytrucks.com/vboard/s...d.php?t=485320 raul |
