Old 01-26-2013, 02:40 AM   #1
Scott>72-GMC
Scott>72-GMC's Avatar
One more ? Key hole ???
What could this key hole go to ( under gas cap on the cab) anyone know??
Scott>72-GMC is offline   Reply With Quote
Old 01-26-2013, 02:47 AM   #2
jocko
jocko's Avatar
Re: One more ? Key hole ???
I believe it is a security thingy... I've seen them mounted on fenders, look just like an additional keyhole. Used to be popular until crazy giant metal bars that make it impossible to turn the steering wheel came out.
Old 01-26-2013, 02:49 AM   #3
Scott>72-GMC
That makes sence I knew it couldn't go to the gas tank but had no idea. I'm only 22 so that era is a little over my head lol
Old 01-26-2013, 08:54 AM   #4
SS Tim
SS Tim's Avatar
Actually that would be a good location for that type of alarm arming switch. Here is a picture of a reproduction Corvette switch that may very well have been installed. However the barrel key switches were also popular for aftermarket installations.
SS Tim is offline   Reply With Quote
Old 01-26-2013, 09:18 AM   #5
norske
I have one above the gas cap. There's wires hanging from it on the inside. Old school alarm, dealer installed I think.
norske is offline   Reply With Quote
Old 01-26-2013, 10:53 AM   #6
kelsfine69
18 Till I Die
kelsfine69's Avatar
That might be a camper plug
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 01-26-2013, 11:07 AM   #7
mrein3
mrein3's Avatar
Back in the day the switches like SS Tim showed were a decent theft deterrent. Before cars came with alarms from the factory, here is what my Dad used to do:
Take 12V off the dome light (sorry to all you guys without dome lights, this won't work). Run that 12V to that switch. From the other side of the switch run a wire to a spot close to the horn under the hood. You need a relay, a flasher, and some heavy wire. You want to rig the relay so when the contacts close in the relay, 12 volts goes to the horn through the relay.
When unarmed the horn and dome light work as usual. When Mr. Crook opens the door and energizes the dome light, that relay clicks and
HONK HONK HONK HONK HONK HONK HONK
until you go shut it off.
The trick then is to leave your wing vent unlatched. That way Mr. Crook pushes open your unlatched wing - not breaking it - reaches in and rolls down the window, unlatches the lock, opens the door,
You wake up happy in knowing your truck is safe and a crook out there needs a change of underpants.
For all you twenty nothings out there with remote clickers and whizz-bang alarms we would call this old school.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 01-26-2013, 11:23 AM   #8
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Good idea! My 72 dont have a door activated dome light, only at the switch. Are they all like this or was that an option?
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 01-26-2013, 12:32 PM   #9
pritch
pritch's Avatar
I have the key switch on the driver's fender on my Panel. Look for aftermarket plunger-type switches on all your doors and hood, or strange holes where they might have been.
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 01-26-2013, 01:44 PM   #10
Scott>72-GMC
I love it
Old 01-26-2013, 07:02 PM   #11
I would put those on the driver side fender just below the back of the fender badge. I thought it looked kind of like the "r" you'd see for "registered trade mark" under logos. It was one of those tasteful and acceptable necessary evil holes you'd drill i your primo ride. Hey,a little 1/2" hole beats a burnt stripped hulk.
Old 01-26-2013, 07:25 PM   #12
Scott>72-GMC
Could get away with one in plain sight now days cause obviously from my unknowing they are a forgotten thing mostly. I think I'll try to get a new one I have a key to and keep it
Old 01-26-2013, 07:35 PM   #13
SS Tim
SS Tim's Avatar
The door operated dome lamp was an option (RPO C80) on the base trucks and included with all the other trim levels. However it will be often seem on the SPID.
It should not be hard to add the two grounding switches at the doors. If you have not yet done so download the manuals for your truck and check the schematics to see how it is run.
Too true. It sure would have been great having a unibit when I had to drill them.
Old 01-26-2013, 07:40 PM   #14
SS Tim
SS Tim's Avatar
Here is Paragon's page for it. Granted it is a reproduction Corvette expensive but for an active alarm system it is a good option and period.
http://www.paragoncorvette.com/p-351...ey-switch.aspx
Old 01-26-2013, 07:46 PM   #15
Scott>72-GMC
Awesome!! I apriciate it
Old 01-26-2013, 10:36 PM   #16
pritch
pritch's Avatar
The PO that added a similar system to my Panel put switches on each door, the barn doors in the rear and on the hood. All the parts are long gone except for the key switch and the plunger switches. And no, I don't have the key
'68 Panel
'68 C-10
Ol' Green
Old 01-26-2013, 10:50 PM   #17
SS Tim
SS Tim's Avatar
Pretty sure Lock Doc Leon could fix you up!
Old 01-26-2013, 11:07 PM   #18
pritch
pritch's Avatar
That's what I'm hoping for, when the time comes!
'68 Panel
'68 C-10
Ol' Green
Old 01-27-2013, 12:34 PM   #19
That's true,but I meant a 1/2" hole beat a stolen vehicle.
