Old 01-26-2013, 06:43 AM   #1
Woogeroo
Question dash speaker 1964-1966 - mounting tips?
Howdy folks.
I bought an aftermarket speaker that is designed to fit into the same stock hole on the dash in my 1965 C10.
Do any of you have any tips or suggestions about putting a speaker in that location or taking it out?
Tips and advice welcome,
-W
Woogeroo is offline   Reply With Quote
Old 01-26-2013, 10:04 AM   #2
theastronaut
theastronaut's Avatar
Re: dash speaker 1964-1966 - mounting tips?
Going from memory, they just wedge in place on the front side and (I think) the rear mounts off a stud on the back of the radio. Been a couple years since I did it though. I do remember that the wedge fit was loose and it rattled so I had to pad the edges for a tighter fit.
Also, you'll want to borrow a kid that can fit up under the dash easier unless you're a contortionist!
theastronaut is offline   Reply With Quote
Old 01-26-2013, 01:24 PM   #3
harpo1313
harpo1313's Avatar
an arm with two elbows helps.
harpo1313 is offline   Reply With Quote
Old 01-26-2013, 09:16 PM   #4
MisterC
MisterC's Avatar
Astronaut said it best. It's all about making sure that it gets wedged back in the same way. I ended up putting a small piece of rolled over duct tape (sticky side out) over the original rubber "nub" so that it would stay in place better once wedged back in the depression in the dash.
I went with the Custom Autosound speaker setup and their measurements didn't exactly match the original speaker. Unfortunately, there was a lot of time between my remove and the install and I had thrown the original away. If I had it to do over, I would have just used the original as a template, removed the speaker component and mounted two 3.5" speakers to it and reinstalled.
Also, during the process, my original defrost duct hoses fell apart so I ended up having to replace those. It's pretty tight up in there behind the heater controls and with the ducting.
Poor and content is Rich...and Rich enough! - William Shakespeare
1966 C10 Custom Cab "Luigi"
Big Window - SWB Fleetside
350 V-8 - Powerglide
My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894
MisterC is offline   Reply With Quote
Old 01-26-2013, 11:43 PM   #5
jdl71
jdl71's Avatar
Mine has a couple of smaller speakers up there in place of the factory one, but I didn't put it there. I could get a pic or two from the underside if you like.
Psalm 23
64 C10
66 K20
jdl71 is offline   Reply With Quote
Old 01-27-2013, 04:01 AM   #6
Woogeroo
Thanks for all of the information and tips folks.
I'm sure I will need all of it.
I've seen where folks took the old stock speaker and cut it down & added two speakers... I was keen to do that, but I do not have a old speaker to use.
I know one online truck fella actually made a template and shared the measurements with everyone like a metal fabrication blueprint level design. I swore I saved it, but I can not find it in my truck related computer files, so must have been on a past crash.
-W
Old 01-27-2013, 07:53 AM   #7
brokenspoke
brokenspoke's Avatar
My experence also.....I need an orginal speaker to go back orginal mounting
brokenspoke is offline   Reply With Quote
Old 01-27-2013, 08:18 PM   #8
jdl71
jdl71's Avatar
I'm assuming you know the vendors offer a dual speaker designed to mount in the original location.
Psalm 23
64 C10
66 K20
Old 01-27-2013, 08:41 PM   #9
brokenspoke
This is why I should have gone orginal.....doesent fit good....sound isnt good either
Old 01-27-2013, 09:00 PM   #10
jdl71
jdl71's Avatar
Good to know. I don't know what's in mine as I didn't put it in there but it doesn't sound great. I just figured they were cheap speakers.
Psalm 23
64 C10
66 K20
Old 01-28-2013, 11:16 AM   #11
dracko
dracko's Avatar
I picked up this speaker from S&M Electro-Tech http://www.turnswitch.com/speakers.htm but haven't installed it, or a radio, yet. I think I have all the brackets I need but don't know how its all supposed to mount under the dash.
I know it'd be painful to snap a pic, but would be a big help if anyone has an underdash pic of the speaker/radio mounted?
dracko is offline   Reply With Quote
Old 02-05-2013, 06:35 AM   #12
Woogeroo
Well folks, I poked around under there looking around today.
Not sure how this contraption installs at all.
Looking like I might need to wiggle the inside of the heater out of the way... but I still do not see how or what it mounts too.
Anyone have any photos of the original speaker bracket ?
-W
Old 02-06-2013, 12:37 AM   #13
BLK65K10
Photos sent.
BLK65K10 is offline   Reply With Quote
Old 02-06-2013, 07:25 AM   #14
Hx16457
Hx16457's Avatar
1. Take the defrost hose off the D/S sit it out of the Way on a table or some thing
2. Remove wiper motor (& washer pump assy if eq'd)
3. Look at the speaker (if OEM brackets are present) the rubber bumper covered bracket goes in the highest internal bend ( as you are look up under the dash), this bend is on the dash, not the firewall. That rubber covered bracket goes there.
4. The opposite side of the speaker, diagonal for the rubber one, goes up to a hole in the dash where the dahs and firewall pinch welds are. If your windshield. Is in the seal will be kind of hidding the hole.
Note: get a flash light and look very closely at the top, center area of your dash. There are two tiny holes about 6" apart. You will have to find the right (passenger side) hole and be able to get at it bacau we that hole is where your only mounting screw that holds the speaker in, is located. Find a screw that will screw into this hole loosely and that will fit yor clip nut on your bracket ( mounted on the speaker).
I hope you understand these instructions!!! Ha!
This is how to do the OEM speaker, or an OEM speaker that has been cut And mounted w/2 speakers.
Not sure how to do the aftermarket dual speaker, I don't know what brackets come with it to help you.
PUT everything back after you get the speaker in there nice and tight!!
Good
Luck!
People who make excuses didn't want to do it in the first place!
http://s1326.photobucket.com/albums/...cpZZ1QQtppZZ16
Hx16457 is offline   Reply With Quote
Old 02-06-2013, 07:18 PM   #15
dracko
dracko's Avatar
thanks for the info. none of my brackets have rubber on them, gonna have to do some searching for pics.
Old 02-06-2013, 08:46 PM   #16
ljackson
ljackson's Avatar
I found a drawing in the assm manual in the 64 section. Maybe it will help.
Father and son built. Driven daily since 2012. 283, 3 speed. Mostly original. '81 PS and disk front. Fuel tank relocate.
Maintenance, repairs and upgrades on his dime now.
http://zacks64longfleet.shutterfly.com/
Higher res. photos in my gallery.
ljackson is offline   Reply With Quote
Old 02-07-2013, 06:50 AM   #17
Woogeroo
ljackson, thanks.
Yeah I flipped through my 60-66 assembly manual earlier marking anything and everything to do with the speakers and the dash speaker hole with post it notes.
BLK65K10 sent me some photos of the different setups... trying to figure out which configuration is for what year. Mine is a '65 and I am not using the stock radio... so the one with the arm from radio to speaker is out.
HHmmmmmnnnn.
-W
Old 02-08-2013, 06:03 AM   #18
Woogeroo
Wink Re: dash speaker 1964-1966 - mounting tips?
Photos taken by and courtesy of BLK65K10 :
Name:  speaker types BLK65K10 001.jpg
Name:  speaker types BLK65K10 002.jpg
Name:  speaker types BLK65K10 003.jpg
Name:  speaker types BLK65K10 004.jpg
Name:  speaker types BLK65K10 005.jpg
The speaker in this photo here, seems to be the design inspiration for the aftermarket speaker I purchased, with the way the mounts are.
FYI: according to BLK65K10 the part number for that rubber wedge piece is: 3838128
-W
Old 02-08-2013, 06:04 AM   #19
Woogeroo
Name:  speaker types BLK65K10 006.jpg
Name:  speaker types BLK65K10 007.jpg
Name:  speaker types BLK65K10 008.jpg
-W
Old 02-11-2013, 04:20 AM   #20
Woogeroo
Thanks to aerotruk63 and BLK65K10, I found out that little rubber piece that goes onto the speaker is :
3838128 (NOS GM Part number)
cushion, mounting plate <- that is what it is referred to/called.
Now, I just need to find one.... HMMNNN.
I've buzzed around a few vendors sites that deal in the NOS parts, nothing listed yet.
-W
p.s. aerotruk63 told me about this neat site I didn't know about
gmpartswiki.com
Old 03-19-2013, 04:19 PM   #21
Woogeroo
Exclamation Re: dash speaker 1964-1966 - mounting tips?
Name:  speaker coils.jpg
I took some photos of the speaker setup that I bought.
The rubber part in the photo is an old part, another Chevy truck guy sent me(thanks).
my truck is a 1965, still not exactly sure how this is supposed to work.
Hmn.
-W
Old 05-27-2013, 08:16 PM   #22
McCoyAZ
McCoyAZ's Avatar
Originally Posted by Woogeroo View Post
Attachment 1079080
Attachment 1079081
Hmn.
-W
That last picture is the exact same speaker I bought from Brothers.
I have a 64 and it never had a radio in it and I have no clue how this speaker is supposed to mount under the dash.
McCoyAZ is offline   Reply With Quote
Old 10-10-2014, 11:25 PM   #23
3/4ton Randy
Woogeroo, I bought the same speaker you did from Custom Autosound. I haven't figured out how to mount mine either (I have a '66 GMC), but this website is great! What a bunch of friends here trying to help!
3/4ton Randy is offline   Reply With Quote
Old 10-11-2014, 08:07 AM   #24
corvettejim1968
corvettejim1968's Avatar
i bought the same thing and changed out the speakers a few months ago. i installed cups made for speakers to the back and then i pilled on the Fat Mat so it has the bracket to hold it up on one side and the Fat Mat is holding it all in place also the Fat Mat makes find of an enclosure for the speakers. sounds really good with just 60 watts going to each speaker.
Hand Made Factory reproduction A/C vents
text or call 602-361-6421
Website for A/C vents
https://coolc10.com/
corvettejim1968 is offline   Reply With Quote
Old 11-29-2016, 04:04 PM   #25
uconn88
I know old post, but did original poster ever figure it out? I have same speaker and a 1965 C10. never had a radio or speakers.
Ray G
uconn88 is offline   Reply With Quote
