Old 01-26-2013, 09:13 PM   #26
Bhelton
Bhelton's Avatar
Re: Project "Grandpa gets a transplant"
Looks good Bill
Bhelton is offline   Reply With Quote
Old 01-26-2013, 09:22 PM   #27
Malamute
Malamute's Avatar
Lookin' good.
Malamute is offline   Reply With Quote
Old 01-27-2013, 10:26 AM   #28
Rusbuilt
Rusbuilt's Avatar
Wow, nice work! Moving along quickly!!
Rusbuilt is offline   Reply With Quote
Old 01-27-2013, 04:33 PM   #29
Zoomin
Man of Mini-Talents
Zoomin's Avatar
It's nice to see all the family getting involved.
Looking good so far.
Zoomin is offline   Reply With Quote
Old 01-27-2013, 06:11 PM   #30
builtbyKane
builtbyKane's Avatar
You can run some air line out and do a T-fitting with a shrater valve or shrater valve each bag independently. I do it all the time to get my projects moved around. You can buy them almost anywhere for a couple bucks each. Works great, and when your done with them save them for the next project.
builtbyKane is offline   Reply With Quote
Old 01-27-2013, 06:50 PM   #31
gdavis
gdavis's Avatar
I see you have a guard dog guarding your parts. And the way your family pitches in is something real nice. Keep up the good work and good luck my friend
gdavis is offline   Reply With Quote
Old 01-27-2013, 11:19 PM   #32
biohazardbill
Thanks for all the comments guys.
I have one thing to say.... control arm bushings can *()(*&*&%^&%()*)(_&$^%#$#^&*&()*&...
k...
So i got up early to set up the control arms... messed up one of the bushings so had to drive about 45 min 1 way to get a replacement...
Was not a good start to the day.....
however when i got home wifey had a surprise for me....
no not that... lol
she got in and sanded the engine compartment.
The she even painted it while I was still dinking around with the control arms etc...
Keep in mind it is a rattle can job so it isnt perfect but neither is the truck so we are in good shape. We chose to only paint inside the motor compartment to keep everything outside as we had purchased it.
Crossmember in:
Now we started looking at the time and was running out of daylight, so not alot of pics of progress at this point as we just wanted to get it done.
So here are a couple after dark pics. I thought the front end would have been lower being on bags and aired out, however the tires we put on were 29 inch we had laying around so that accounts for some of that. Once the rear is done then I will see how it looks and see if we may change up the front a bit.
biohazardbill is offline   Reply With Quote
Old 01-27-2013, 11:21 PM   #33
biohazardbill
Oh yeah.. front is now 5 lug.....
Old 01-27-2013, 11:22 PM   #34
Rusbuilt
Rusbuilt's Avatar
Looks good! Are you running drop spindles?
Old 01-27-2013, 11:29 PM   #35
biohazardbill
Front consists of 2" cpp drop spindles and the suicide doors plate and cup kit with ss8 bags
Old 01-27-2013, 11:34 PM   #36
Rusbuilt
Rusbuilt's Avatar
Did you cut off the bumpstops?
Old 01-27-2013, 11:36 PM   #37
biohazardbill
Yes bumpstops were completely removed and ground smooth before it was powdercoated.
Old 01-27-2013, 11:39 PM   #38
Rusbuilt
Rusbuilt's Avatar
You could trim your bag cups down a little. That would only help just a little though
Old 01-27-2013, 11:44 PM   #39
biohazardbill
Yeah... thought about that... not doing anything til I get the back dropped.. depending on work schedule tomorrow might pop off the bed and get started.
Old 01-27-2013, 11:46 PM   #40
Rusbuilt
Rusbuilt's Avatar
Good deal friend, you and your family seem to be making short work of this old truck! Keep it up!!
Old 01-28-2013, 11:48 AM   #41
biohazardbill
Ok... so a pic in the daylight...
Guess the spindles were in the box to long. Started to rust a bit in spots.
Looking at the bag and cup, it looks like I can trim it down if need be. Rusbuilt, you can see here where the bumstops were completely removed.
Old 01-28-2013, 01:10 PM   #42
67cheby
67cheby
67cheby's Avatar
love the truck, keep up the great work !
67cheby is offline   Reply With Quote
Old 01-28-2013, 01:23 PM   #43
jhama78
jhama78's Avatar
looks killer man, glad to hear that you are keeping the exterior 'grandpa fresh'
-j-rod
'06 3500 LWB CC 4wd, 8.1 Allison
jhama78 is offline   Reply With Quote
Old 01-28-2013, 01:42 PM   #44
Rusbuilt
Rusbuilt's Avatar
Yes sir, nice job. Do you think you'll cut those cups down a bit?
Old 01-28-2013, 02:15 PM   #45
biohazardbill
Thanks for the compliments guys...
I will wait til I get the rear down to see the stance. Right now the front crossmember is 5 inches off the ground so once I get the right set of meats on there I assume that it will drop about an inch.
If work would quit getting in the way, I am going to try and pull the bed off this afternoon to start on the rear.
Old 01-28-2013, 07:09 PM   #46
biohazardbill
Ok so it is supposed to rain the next couple days. Made time today to make sure I can work on this inside the garage without too many issues while it is raining.
Lets begin:
No the burb in the back is NOT the one from TSC.
Bed is steel (for now) so made four drain holes and temporarily filled with hooks.
Position the Gantry
Going up:
And off
Voila..
Now I know they had a steel bed in here but underneath is kinda off I think, maybe you guys can tell me how it is supposed to be.
Look at the bed area I am not sure how many actual supports are supposed to be here but here is wat it had.
Left by the cab seemed to be touching both the bed floor and the frame.
Next one over to the right was only connected to the frame, once i got the bolts loose it was free.
One over the springs. Not sure this is factory. Had some really crappy welds attaching it to the frame.
Next to the right between the crossmembers this one has a piece of 3/4 steel tube welded to the top: see below
And the one to the far right seemed to touch both the frame and bed floor.
So what is the right configuration?
Old 01-30-2013, 06:24 PM   #47
biohazardbill
More progress...
Wife says I take too many pics so I kept this Short and sweet.
Naked backside
Extremely Naked Backside
Was running out of daylight so sprayed the frame as best we could knowing there would be touch ups later, most of the notch is in, still need to put on pan hard bar etc..
Frame is sitting level but still kind of high I think for being on bags. Right now it is sitting at 6.75 inches off the ground. Now these are 29 inch tires on it so that will drop some when I put the new wheels/tires on it. Not sure yet what to go with.
Old 01-30-2013, 07:00 PM   #48
Rusbuilt
Rusbuilt's Avatar
Lookin good!
Old 01-31-2013, 11:44 AM   #49
67cheby
67cheby
67cheby's Avatar
nice
Old 01-31-2013, 01:30 PM   #50
sgaylord
Project collector
sgaylord's Avatar
Cleaning that up nicely!
69 CST-10 SWB (disguised as a 67) 383/700r4 Jezebel
Jezebel 3.0 NEW!!!
2020 GMC 3500 Denali Duramax
2016 Harley Street Glide CVO
Roll Tide!
sgaylord is offline   Reply With Quote
