Old 01-26-2013, 09:47 PM   #1
slick willie
Door issues
I'm working on replacing the rockers on a 64. So i pulled the drivers side door off. I went to reinstall it when the bolt plate dropped.. i can cut the inner panel to get to the plate back on my question is what keeps the plate from falling. I could tack it in place but then i would not have any adjustment. I would appreciate any help i can get.
By the way this is my first post... I am not sure if i should have done an intro... So here it goes. I am a visitor for the land of the HAMB.. I mainly build hot rods but found a deal on a 64 so i picked it up for my offspring as her first car. She is 14 so i have a couple of years to work on it.. Mainly fix the **** i screw up on it.... My other cars are 1932 ford roadster and 1923 ford touring.. And I am a scorpio and I believe in unicorns.
Willie
slick willie is offline   Reply With Quote
Old 01-26-2013, 11:27 PM   #2
198plus
198plus's Avatar
Re: Door issues
I don't know if this helps you. I had to cut mine out and make new plates for my door bolts because they where stripped. I cut mine from the outside, you can see the inside backing in one of the pics.
198plus is offline   Reply With Quote
Old 01-26-2013, 11:53 PM   #3
slick willie
Re: Door issues
it does help. Mine was the lower plate.. Looks like I'm gonna have to fab a backing.. Mine must have rusted off.. Again thanks for the help..
Old 01-27-2013, 02:11 PM   #4
61K10
61K10's Avatar
Re: Door issues
my lower one fell down in the pocket as yours did. fished it back up with a wire and put a bolt back in to hold it. (took awhile to fish it back up) you just have to remember it's loose in there.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 01-27-2013, 04:15 PM   #5
63sbssbbw
UCA63
63sbssbbw's Avatar
Re: Door issues
Yes ,same with my '61 cab.
To answer your q Willy,, just a couple of cheesy "L" brackets that are barely tacked in at the factory to hold those roughly( and loosly) in place,and yes tacking them in a permanant spot will result in nightmares come alignment time.
If you've lost it(LOL I mean the hinge plate) You can fish for it(like 61K10 and I did) Or cut it open and fix it.
T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 01-27-2013, 04:29 PM   #6
62 Barnfind
62 Barnfind's Avatar
Re: Door issues
I stripped one of mine out also. I just drilled out the hole bigger and tapped it to a larger bolt. Much faster and didn't have to remove the plate. I think the original thread is 3/8 fine and I went to 1/2. What ever the size is I went up one.
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
