#26 |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Re: Lets talk body/frame swapping
There's pics in these forums of it done.
It won't sit right. It won't look right. Leave it on the correct frame. Posted via Mobile Device
#27 |
Thanks for the replays. If you know what are the differences in the 88 frame vs. the 87. Also I'm not aware or been told of any legal frame swap. Can you explain what these might be for CA.
Thanks Posted via Mobile Device |
#28 | |
the Ca. info is all in the following link. it is a bit of reading, but the info is there http://www.bipac.net/semaga/TagTitleToolbox_CA.pdf ron |
#29 |
Here in Kansas, in most cases, you go to the DMV, have a State Trooper run the numbers on your body and the frame. If both check out ok, then your options are: a builders' title, or transferring the body number to the frame,with the proper paperwork attached. Also, in some cases the state can assign a new ID number and will attach it in the door jamb. KS seems to normally lean towards titling as the body year. If all your paperwork is done correctly, there are no insurance issues. Proper documentation, may be lengthy, but in the end, well worth it.
#30 |
I have a 2003 that I've been tempted to put my '66 Burb body on.
Somehow that seems silly. The idea of owning an old truck gets lost in that. At the same time, I look at crate engines and all new supension parts for the '66. I would still rather have an all original nice '66, than a resto-mod. As soon as I see changed "anything" in a 4-sale ad, I lose interest quickly. Probably because none of what someone else has done, would be what I would do, so I don't want to pay for it.
Jon S 1966 GMC Suburban 305 V6 Las Vegas NV |
#31 |
60-66 Nut
The '88 and up frames are much wider, as well as the side profile is much different. The front suspension is totally different, and I believe the wheelbase may be different as well. Most anything can be done if a guy has the desire and the skills to make it happen. But IMO swapping to the '88 and up frame is way too much work, for basically no real gain over the early frame and suspension. In fact I have yet to see a 2wd swap like this ever get finished. Usually they give up on the project due to the difficulty. I have only seen one finished that was a 4x4.
To keep a frame swap legal, check with your DMV or State Police to see what is required in your state, or just read thru the link Ron posted above.
#32 |
Good thing I did not listen to people when I built my 54 GMC that sits on a 1993 Silverado chassis. Click on my link
1954 GMC on 93 Silverado chassis http://67-72chevytrucks.com/vboard/s...d.php?t=408344 1942 Chevy 1/2 ton Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=429494 R.I.P. TOM SEFFRON 68 FOUR DOOR http://67-72chevytrucks.com/vboard/s...d.php?t=495438 1942 Chevy that ate my brain 70 Chassis https://67-72chevytrucks.com/vboard/...d.php?t=835250 |
