Old 01-27-2013, 12:16 PM   #1
68fixeruper
68fixeruper's Avatar
Psi harness where to mount computer
Looking for pictures of how some of you mounted your computer. Its hard to find a plqce under the dash with the vintage air unit taking up almost all of the glove box space.i want it out of sight but accessible any input would be appreciated.
68fixeruper is offline   Reply With Quote
Old 01-29-2013, 06:54 PM   #2
see ten
WTB this ad
see ten's Avatar
Re: Psi harness where to mount computer
i put mine under the hood... i also have vintage air.
see ten is offline   Reply With Quote
Old 01-29-2013, 07:03 PM   #3
68fixeruper
Do you have any pictures?
Old 01-29-2013, 08:23 PM   #4
Clyde65
Clyde65's Avatar
Put it in the heater box under the hood. You will need to get an fbody trans dipstick tho
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 01-29-2013, 10:02 PM   #5
see ten
WTB this ad
see ten's Avatar
It's a super crappy cell phone pic... but... anyway...
Clears the master cylinder, the washer bottle and the hood hinge... My brother's has been like this for over 2 years and hasn't had any issues.
Old 01-29-2013, 10:06 PM   #6
see ten
WTB this ad
see ten's Avatar
another shot... hard to see exactly how it's mounted from this side though...
Old 01-29-2013, 11:10 PM   #7
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
I put mine in the area where the glove box was located... and routed the harness through a hole in the fire-wall/trans-tunnel.
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 01-30-2013, 08:46 PM   #8
TopFuel1966
TopFuel1966's Avatar
Mine is mounted on the inside of the left corner of the firewall behind the dashboard. The photos are before and after the finish. It's hidden from view by an A/C vent.
TopFuel1966 is offline   Reply With Quote
Old 01-31-2013, 02:08 PM   #9
mooseknuckles
mooseknuckles's Avatar
behind glove box....psi leaves lots of wire....
mooseknuckles is offline   Reply With Quote
Old 01-31-2013, 05:28 PM   #10
SamMargritz00
SamMargritz00's Avatar
I bolted mine to a piece of aluminum and used rubber spacers between the aluminum and firewall. I have the vintage air as well.
Blazer Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=483399
SamMargritz00 is offline   Reply With Quote
Old 01-31-2013, 10:19 PM   #11
rmvlt1100
rmvlt1100's Avatar
Here is where I put mine. It's under the dash below the glove box. The heater tube clears the wire harness ok. The picture makes it look like its tight to the wires but that was before I wrapped the wires.
This is my Build A 5.3L 1965 C-10 Fleetside
http://67-72chevytrucks.com/vboard/s...d.php?t=502100
rmvlt1100 is offline   Reply With Quote
Old 01-31-2013, 11:10 PM   #12
Indian113
Indian113's Avatar
I mounted mine on fenderwell,easy to get too.
Indian113 is offline   Reply With Quote
Old 02-01-2013, 09:15 AM   #13
68fixeruper
Hey buck where did you mount your fuses that came with your harness.
Old 02-01-2013, 12:33 PM   #14
C10_ustacould
Right now they are laying on top of the computer secured by a zip tie. My plan is to fabricate a new shallow glove box insert to mount the fuse/relay panel, OBD II connector, and the control box for the electronic speedometer. Just need to get a day to work on it, when I get it done I will certainly post pics.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 02-01-2013, 12:53 PM   #15
68fixeruper
Thank you i think i might just mount my computer on the firewall behind the motor and run the fuses and OBD II inside.
Old 02-01-2013, 01:14 PM   #16
mooseknuckles
wow...you're not even trying...not sure why you'd need to access the pcm that easy?...but, whatever...I didn't want my engine bay looking like a bag of snakes...so the only wires you can see are the plug wires..
Old 02-01-2013, 04:46 PM   #17
C10_ustacould
I see the injector wires, the alternator wires...
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 02-01-2013, 05:01 PM   #18
mooseknuckles
lolz..
Old 02-01-2013, 05:11 PM   #19
C10_ustacould
Looks sweet!
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 02-01-2013, 05:17 PM   #20
mooseknuckles
thanks...I'm hopin to get a ls1/ls6 intake on there to clean it up some more...
Old 02-01-2013, 05:59 PM   #21
Indian113
Indian113's Avatar
I'd like to clean up under the hood on my S10 but it's gonna have to warm up some before I can.
Old 02-01-2013, 06:00 PM   #22
Indian113
Indian113's Avatar
By the way Buck that harness I bought off of you works perfect from the git go. I can't thank you enough for your help! Ray
Old 02-01-2013, 08:24 PM   #23
C10_ustacould
I'm happy it worked out well!
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 02-02-2013, 07:51 AM   #24
68fixeruper
You wont see any of my wiring when its done. Im just looking for the best place to put it. Reason i want it accessible is im planning to do a cam swap later and dont want it mounted somewhere i cant get to it easily.
Old 02-02-2013, 07:53 AM   #25
68fixeruper
