Old 01-27-2013, 06:35 PM   #1
Malamute
Malamute's Avatar
Thermostat housing on sbc 400
The PO had a cheapo chrome housing which started leaking recently. Pulled it off today and there was a lot of grimy stuff in there and in the threads of the manifold. There also was just rtv and no gasket.
Two questions: Should I use a gasket w/ rtv on each side(what I always thought you should do) and what is the best way to clean the threads out? I don't want to get the bolt cross threaded in the manifold, that would not be good.
Thanks.
Malamute is offline   Reply With Quote
Old 01-27-2013, 06:56 PM   #2
69GWC
Re: Thermostat housing on sbc 400
I have found that it seems only the chrome housing that have a rubber O-ring seem to seal well, the ones without and just use a standard gasket allways seem to leak and I have had that the surface had warped and made them leak.
That said I would coat both sides of the gasket with a then layer of sealant and a tap would clean the threads out the best.
69GWC is offline   Reply With Quote
Old 01-27-2013, 07:03 PM   #3
Malamute
Malamute's Avatar
I replaced the chrome one with a more cast-looking one. It's a Murray from O'Reilly so we'll see how it does. I'll lightly coat each side after I get those threads cleaned out.
Thanks.
Old 01-27-2013, 07:04 PM   #4
Pop's C-10
Pop's C-10's Avatar
felpro 35562T gasket..
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 01-27-2013, 08:34 PM   #5
Malamute
Malamute's Avatar
Thanks Pop's. Go with that over the one that came with the housing?
