Old 01-28-2013, 12:46 AM   #1
hpcgmc
hpcgmc's Avatar
Will a rear axle off a 78 Chevy fit my 67 GMC?
I've got a line on a 78 Chevy 1/2 ton pickup that's being parted out. I'm thinking of getting the disc brakes off the front, and the rear axle. I haven't checked the gearing on my 67 GMC, but it's very low gears with heavy duty leaf springs. I assume mine came out of a 3/4 ton truck. My truck is 6 lug, so the rear end will give me 5 lug front and rear.
I read that the front end will be about 1" wider with the 1978 assembly - is the rear end 1" wider also? Do the 5 lug rally wheels stick out an inch to far?
And will the 78 Chevy rear end bolt right in? Can I also use the leaf springs from the 78 Chevy?
Thanks!
1967 GMC 1500 SWB. Driving this truck since I was 14.
hpcgmc is offline   Reply With Quote
Old 01-28-2013, 01:52 AM   #2
72chevynoob
Re: Will a rear axle off a 78 Chevy fit my 67 GMC?
The rear end might swap, but you should measure the distance between the u bolts on both to double check. I have a coil spring rear and am in the process of welding new mounts on a rear end from an '80. The rally wheels will not stick out too far, and the rear ends on the 67-69 and most '70 trucks were actually narrower than the front. Assuming you have a stock rear end right now, the rear end from the '78 will be a total of 1.5" wider. Im not sure about the front for width.
Justin
69 lwb project: http://67-72chevytrucks.com/vboard/s...d.php?t=558011
72chevynoob is offline   Reply With Quote
