Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech
Old 06-22-2011, 12:18 AM   #1
thirdstreettito
Resident of Here
thirdstreettito's Avatar
suggested to do a writeup for here like this
Anybody have a write up for it? The write up on CK5 isn't helpful to me, I dont have a paid account so I cant see the pics. Anyone have parts #'s? What exactly is the mod? Thanks, Bradley
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline
Old 06-22-2011, 07:29 AM   #2
b454rat
Re: Power Window Relay Mod?
I'm gonna do this on my crew if I ever get around to it.
It uses 2 relays per window, one for up one for down. Just regular relays, 30 amps I think. Instead of the voltage going thru all the wiring and loosing some by the time it gets to the motor, going thru the relay sends a full 12 volts to the motor. I guess it turns slow ass windows into an upside down guillotine.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
b454rat is offline
Old 06-22-2011, 08:47 AM   #3
thirdstreettito
Resident of Here
Where do you mount them? Etc etc!!?
~Bradley~
Miss having a truck
Old 06-22-2011, 08:51 AM   #4
baclay9
Keeping my eye on this
baclay9 is offline
Old 06-22-2011, 09:07 AM   #5
b454rat
The two relays per door fit behind the door panel. I can't remember where, I'll have to look at the thread on CK5...
I've done the headlight mod before, so wiring up relays isn't too hard. At almost $5 a pop, could get expensive with 4 doors!!! Wouldn't need much wiring, so find a place to mount the relays, run some wires, do some splicing and done....
b454rat is offline
Old 06-22-2011, 09:10 AM   #6
thirdstreettito
Resident of Here
I'll have my electrical take a look at the diagrams. I'll also see if I can do it for the tailgate window! What kind of electrical fitting d you use on the relay? The slip-on type? (Dont know the technical name)
~Bradley~
Miss having a truck
Old 06-22-2011, 09:21 AM   #7
b454rat
This is right from CK5
I have been thinking about my slow power windows. It seems it isn't just mine, but everyone's. SO I have been seeing alot of topics about adding relays to headlights to make them brighter by adding full battery voltage. And I already added a relay to my starter for the same reason.
So, I am thinking about adding some relay's to my power windows, I looked at a diagram today at work and it didn't show any. I have no problem wiring it up, but has anybody tried this yet? If not, I think I will give it a whirl and maybe do a write up on it.
Let me know what ya'll think.
EDIT, I just got one side done, The drivers, and it is almost twice as fast as the passenger side now. It used to be slower. I used 2 standard bosch relays.
Terminal 85- power from the window switch.
Terminal 30- To window motor
Terminal 87A & 86- to Ground
Terminal 87- Goes to power, I used the junction block on the firewall, so I get as much voltage as possible.
I am going to do the other side, it is just too hot right now. It was pretty simple, and they work soo much faster. It's amazing how much voltage drop there is on 25 year old wires and connectors.
here's a pic of where I put the relays. I took the pic before I ran the power wire to them.
b454rat is offline
Old 06-22-2011, 09:26 AM   #8
wyattglock
wyattglock's Avatar
That's some good info! I might have to try this on my truck.
wyattglock is offline
Old 06-22-2011, 10:38 AM   #9
N2TRUX
Happy to be here
N2TRUX's Avatar
b454rat can you put up a link to the thread? This would make a great FAQ here, but I want to ensure that the OP gets proper credit.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
N2TRUX is offline
Old 06-22-2011, 11:12 AM   #10
Low87
been here longer than Liz
Low87's Avatar
I like it. Gotta try this on the K5.
~Greg~
Mac's Garage
'87 SWB 6/8 drop "Piso"
'08 CCSB Silverado DD
the departed
'89 GMC K5 Jimmy 4x4 "Rusty Nuts"
'77 Chevy K5 Blazer 2wd
'83 Chevy stepside
"You get what you pay for" - Mike 'swervin ervin' Ervin
Low87 is offline
Old 06-22-2011, 06:12 PM   #11
48cj2a
48cj2a's Avatar
Awsome mod - I'm about ready to add PW/PL to the CUCV and this would be perfect to use since I'm starting from scratch.
Wonder if it might help the wipers and blower as well?
03 Suburban Z71 Z71
98 GMC Yukon SLT 4x4 Yukon
86 M1009 CUCV Project Milverado
48 Willys CJ2A 48CJ2A
48cj2a is offline
Old 06-22-2011, 06:22 PM   #12
JMac11
JMac11's Avatar
Do you really need help down??? My Down is good
JMac11 is offline
Old 06-22-2011, 06:37 PM   #13
TheApocalyptican
TheApocalyptican's Avatar
Not sure about the wipers.....but in my experience with our age vehicles, the blower is getting almost full battery power. Like a drop of less the .5 volts.
Also like to add that if you can find 'em, get the relays that have the bracket part made out of metal. The plastic bracketed ones like in the picture above always break off after not too long, and in this case will create a rattle within the door.
1995 Suburban K2500 454.....off road & towing
1999 Astro, work van
2006 Silverado 2wd 5.3 w/4.5" lift and 33s
TheApocalyptican is offline
Old 06-22-2011, 07:05 PM   #14
bigwheel15
bigwheel15's Avatar
I have a few relays laying around and some spare time, I wonder how much of a difference this mod makes?
bigwheel15 is offline
Old 06-22-2011, 07:09 PM   #15
TheApocalyptican
Same thing I was wondering. Might be best to quick try it on your slowest window. I wouldn't even bother running the wire thru the door, just quick wire it up, and see if it really makes a difference before you go thru all the trouble of making it nice.
Old 06-22-2011, 07:50 PM   #16
b454rat
http://coloradok5.com/forums/showthr...=window+relays
There are a couple of diagrams in there, not sure if needed or not. If so lemme know what ones and I can get them....
b454rat is offline
Old 06-22-2011, 11:19 PM   #17
rayfinseats
I just rewired my 83 using 5 relays. Some guy on e bay sells 5 (5 wire) relays WITH pigtails and FREE SHIPPING for $18.
http://www.jkowners.com/forum/showthread.php?t=1261 Here is a wiring diagram.
rayfinseats is offline
Old 06-23-2011, 12:25 AM   #18
67_SS396
I have thought about this and now that I've seen feedback, I'll be doing it to mine and my neighbor's trucks. Thanks!
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers
'66 C10 - The new hot rod
'77 3+3 Dually - 12 valve 4wd conversion tow rig project
'28 Ford 2 door sedan street rod
RevLimit Offroad
"Hang on beer, we can do this."
67_SS396 is offline
Old 06-23-2011, 01:19 AM   #19
qu1cks1lver56
qu1cks1lver56's Avatar
doing this soon. I hate waiting on my windows to roll up lol
qu1cks1lver56 is offline
Old 06-23-2011, 01:34 AM   #20
thirdstreettito
Resident of Here
Thanks b454rat! Big help! Now to buy some wire, relays, and learn how to remove/install the door panels.
AMEN!
~Bradley~
Miss having a truck
Old 07-06-2011, 09:22 AM   #21
mikep87swb
I am definately going to do this mod also..... I just have one question.... Do you need to wire up something additional for the driver to put down the passenger window... Or is that covered in the directions and I just missed it..... I would assume you have to run a wire from the switch on the drivers side to the relays on the passengers side to activate the passenger window from the drivers side???
If I am wrong I apologize..... but I am just wondering what has to be connected in that scenario...
Mike
mikep87swb is offline
Old 07-06-2011, 08:46 PM   #22
homemade87
This is a great mod. It was a simple mod and well worth doing. I did mine when I had the truck apart. I put my relays just above where the wires go out threw the fire wall to the doors. I felt they would be better protected from the weather. I also cut my wires to the motor about 2" from the motor and added a much larger wire all the way down to the motor .I pulled the original wire back up threw the door jamb to the inside of the fire wall to run the relays. 2 wires up to the relays from the motor, and 2 large wires down from the relays to the motor. It works great. The first thing my friends show off about my truck is the windows in action.
homemade87 is offline
Old 07-07-2011, 02:07 AM   #23
juiceman650
juiceman650's Avatar
Nice, I was thinking of replacing my motors because of how slow they are, but I guess I'll just do this mod and see how it works.
juiceman650 is offline
Old 07-07-2011, 04:32 AM   #24
dmartin1
dmartin1's Avatar
LOL i literally laughed out loud and spit a piece of meat outta my mouth when i read "I guess it turns slow ass windows into an upside down guillotine" haha
1969 Shortbed in progress
1982 short step, few suspension and motor upgrades.getting a 468
1978 Shortbed fleet side bonanza fully loaded
1978 k20 Silverado loaded.currently engine-less
1989 k10 suburban 9" lift
65 nova
And more
dmartin1 is offline
Old 07-08-2011, 11:06 PM   #25
TheApocalyptican
Just did this on the front drivers side window. Up or down now takes 3 seconds flat, vs 4 going down before, and 4.5 going up.
