Old 01-28-2013, 04:33 PM   #1
Andy4639
Old member
Andy4639's Avatar
Question Transmission bolts loose
As the title states all my bolts were loose and I have tightened them up several times before. What is the trick to keeping them from backing out?
I put star washer's on them this time with RTV. I hope this will do it.
Want to know what all u have used.
I even thought about putting longer bolts in it and nuts on them.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 01-28-2013, 04:51 PM   #2
Longhorn 70
Longhorn 70's Avatar
Re: Transmission bolts loose
I have just used new split lock washers every time and they've never come loose....I think I have torqued to 35 ft/lbs.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 01-28-2013, 05:04 PM   #3
Andy4639
Old member
Andy4639's Avatar
Wink Re: Transmission bolts loose
That's what I started to use but found the star washers and figured they be a little better. I just hope they hold tight!
