Old 01-28-2013, 11:15 PM   #1
jbristo67
resident oilfield trash
jbristo67's Avatar
Muffler help
I just bought a 91 k5 and while it sounds good its just too loud. I really want to run flowmasters but I'm afraid they will be too loud too. Is there a quieter series of flowmaster that I should be aware of? Thanks in advance
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 01-28-2013, 11:24 PM   #2
big10ratrod77
big10ratrod77's Avatar
Re: Muffler help
on my 1977 c-10 i ran true duel 2 1/4 pipes off the manifold through an h pipe into duel flowmaster 40's out the side(infront of the wheel) and my truck sounds perfect it sounds bad to the bone outside the truck and nice and quiet going down the road i wish i had done that years ago...
77 chevy BIG 10 350/sm465/12bolt w 3.73 bout 240 horse power NO power steerin
79 chevy 1/2 ton 250/three on the tree/3.08s soon to get built 250/floor shift conversion/3.08s
81 mercedes 300d 25 MPG
77 chevy BIG DOOLEY 454/sm-465/14 bolt 4.10s "fully loaded"
73 plymouth duster 225 slant six/230 3 speed/8 1/4 trying to acheve 300 horse six http://www.cardomain.com/ride/3135091
'77 chevy trucks. built to stay tough.
life is short build a hot rod
big10ratrod77 is offline   Reply With Quote
Old 01-28-2013, 11:25 PM   #3
big10ratrod77
Re: Muffler help
on my 1977 c-10 i ran true duel 2 1/4 pipes off the manifold through an h pipe into duel flowmaster 40's out the side(infront of the rear wheel) and my truck sounds perfect it sounds bad to the bone outside the truck and nice and quiet going down the road i wish i had done that years ago...
Old 01-29-2013, 11:08 AM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Muffler help
I'll third that.... but 79 and Jimmy lol
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 01-29-2013, 12:22 PM   #5
dieseldawg142
dieseldawg142's Avatar
Re: Muffler help
i put a flowmaster 70 series on my '90 stepper d.driver. slight rumble at idle, just a little more when on the throttle. probably the quietest f.master you can buy
dieseldawg142 is offline   Reply With Quote
Old 01-29-2013, 02:58 PM   #6
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: Muffler help
Get a flowmaster or fill the exhaust full of concrete. Same thing really
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 01-30-2013, 12:00 AM   #7
85Bowtie
85Bowtie's Avatar
Re: Muffler help
If you want ultra quiet you can always get a large case Dynomax Super Turbo. If you are set on Flowmaster, then the 70 series is the way to go.
'69 Dodge Charger R/T 440, 727, 3.55 Sure Grip
'68 Plymouth Road Runner 383, 727, 3.23 Sure Grip
'89 Dodge Diplomat ex cop car 408, 727, 3.55 Sure Grip
'77 Dodge Monaco ex cop car 440, 727, 2.71
'79 Dodge 'Lil Red Express pickup 360, 727, 3.55 Sure Grip
'12 Dodge Challenger SRT8 392, M6, 3.92
'85 Chevrolet C-10 SWB 2wd 305, TH350, 2.73
85Bowtie is offline   Reply With Quote
Old 01-30-2013, 12:12 AM   #8
cory d
cory d's Avatar
Re: Muffler help
in all fairness, flowmasters are far from being masters of flow. most any cheapy turbo with our perform them.
cory d is offline   Reply With Quote
Old 01-30-2013, 12:32 AM   #9
85Bowtie
85Bowtie's Avatar
Re: Muffler help
You mean based off of the BS "flow" tests? Since when can you properly test muffler "flow" on a bench? Hot gases flow completely different in an exhaust system than any flow bench test.
The "flow" in a muffler is not always as important as the velocity. More volume moving slower isn't always better then less volume moving faster. Just as an X pipe works, chambered mufflers work off impulse from the exhaust valve closing to help pull exhaust out. Like anything else, you have to match the correct size muffler/exhaust system to your engine.
And FYI, most of my cars have Dynomax Super Turbo's on them...because I like the "stockish" sound.
Old 01-30-2013, 12:59 AM   #10
Billett
Billett's Avatar
Re: Muffler help
^Not to mention we've been over this in dozens of threads. Unless you are spending thousands on a drag truck there is no need to worry about the performance of one muffler over another. There's a 5hp gain maximum. Go with what you like the sound of. I have no problems with the volume on my super 44's but they exit out the back of an 8 ft bed. I'd go with 40 series and exit out the back in your application. The side may not be too bad, but the rear will definitely be quieter.
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
Old 01-30-2013, 01:09 AM   #11
jbristo67
jbristo67's Avatar
Re: Muffler help
I think they flow fine. I like the way they sound more than that. It's just really loud in my k5 and I want to keep the sound I just want less of it
2011 Nissan Armada
Old 01-30-2013, 01:13 AM   #12
Billett
Billett's Avatar
Re: Muffler help
what do you have in there now? some sound deadener may help as well.
Will
2024 Toyota Sienna
Old 01-30-2013, 01:36 AM   #13
jbristo67
jbristo67's Avatar
Re: Muffler help
They look like 2 chamber flowmasters. I think what's throwing me off are the echoe tips. I was planning on cutting them off today but I couldn't find a metal blade.
2011 Nissan Armada
Old 01-30-2013, 02:14 AM   #14
Billett
Billett's Avatar
Re: Muffler help
Gotcha, yeah tips can change the sound a bit. I really do think some sound deadener might help you out too though. That way you can keep the tone you like, but kill some of the sound coming into the cab through the floor. It's pretty easy to lay down and doesn't cost a lot as long as you don't get dynamat.
Will
2024 Toyota Sienna
Old 01-30-2013, 02:53 AM   #15
INSIDIOUS '86
Re: Muffler help
Flow masters have tone? Lol. Maybe back when they made them right. Nobody at the car shows around here can stand them anymore cause they sound a lot diff than they used to. The drone will never go away changing the tips may make a small diff but not much. I would recommend magmaflow pypes or spintech. Both know what they are doing when it comes to exhaust.
Old 01-30-2013, 03:21 AM   #16
Bloodhound
Re: Muffler help
Borla. Nuff said.
Bloodhound is offline   Reply With Quote
Old 01-30-2013, 03:31 AM   #17
wraprail
wraprail's Avatar
Re: Muffler help
This^
wraprail is offline   Reply With Quote
Old 01-30-2013, 11:40 AM   #18
OutlawDrifter
Re: Muffler help
exhaust is my favorite part of any build, i've used about everything out there. on my ls powered camaro i run a hooker aerochamber and really like it. no drone at cruise and it sounds great when you mat the pedal. if i ever change i'm going to do a single exit pipe with a banks monster muffler.
running the pipes out the back helps in any application. i had an el camino with spintech sportsmans that was obnoxious going down the road....the pipes shout out in front of the rear tires, after i ran the pipe over the axle and out the back, it was easier to live with as a daily.
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 01-30-2013, 01:34 PM   #19
jbristo67
jbristo67's Avatar
Re: Muffler help
Is there anyone who carries it locally
2011 Nissan Armada
Old 01-30-2013, 01:45 PM   #20
Billett
Billett's Avatar
Re: Muffler help
Couldn't tell you for sure. I got some reflectix from lowes, but that's more for heat insulation. They probably sell sound deadener, but it wouldn't be as good for the application as some of the stuff you can get online. I went with FatMat, but there are plenty you can get for cheap that work fine. I got 25sq ft on amazon for $55, but I'd go with 50sq ft.
Will
2024 Toyota Sienna
Old 01-30-2013, 09:10 PM   #21
Sterling
Re: Muffler help
Go to big box hardware/carpet store (i used home depot)
Go to carpeting-ish isle (somewhere in that area)
Find carpet insulation or I think they call it carpet pads (its in big rolls, like the carpet they stock there, its the stuff you put under home installed carpet)
Go with the thickest packed kind (just push on each and see which is most dense, at my home depot, the blue colored kind was the most dense)
Get a few feet by a few feet cut for you
20 bucks later you have cuttable, formable, cheap but very effective insulation
and thats coming from a guy who deals with the rattles of a diesel
ALSO
Home depot carries stuff called QUICK ROOF, its roofing heat insulation, it has its own peelable sticky side (peel away coating, it sticks to anything). This stuff is the poor man's Dynamat.
Stick quick roof to floor pad, you have the ultimate insulation, for less than $40 for your whole cab
P.s., if you are thinking twice about using home carpet padding in a truck, I just pulled the factory carpet out of my truck, guess what I found, the same stuff installed from factory. Ever look under the dash against firewall? Carpet padding, or as the car world calls it, jute. Pretty much ground up foam attached to a sheet with glues
-Sterling
Sterling is offline   Reply With Quote
Old 01-31-2013, 12:38 AM   #22
INSIDIOUS '86
Re: Muffler help
That peel and seal glides off in heat. Not foot for putting it on verticals surfaces or ceiling
Old 01-31-2013, 12:45 AM   #23
Billett
Billett's Avatar
Re: Muffler help
Reflectix doesn't have adhesive on the back, I just stuck it on the door with some gorilla tape. Not professional, but it works and no one knows its there.
Will
2024 Toyota Sienna
Old 01-31-2013, 12:45 AM   #24
lilpoindexter
lilpoindexter's Avatar
Re: Muffler help
I got peel n seel from the section where they have metal gutters in Lowe's...although not all lowes carry it. I Stuck it on the floor and back wall of the cab. No problem sticking even in the California heat. The key is a nice clean surface. My truck has a 250 with 2 1/2 single exhaust to a two chamber flowmaster. It's fun for the first 5-10 minutes...but then the sound gets old. I'm 41, so that might have something to do with my dislike for the drone. i think i will stick an expansion chamber or a small muffler somewhere upstream of my flowmaster.
lilpoindexter is offline   Reply With Quote
Old 01-31-2013, 07:46 PM   #25
guitarfreak235
guitarfreak235's Avatar
Re: Muffler help
the flowtech raptor mufflers are what i use in my true dual system. 25 a pop and have a nice deep sound with a little rasp. perfect. they sound good with the windows down but are very quiet inside. i really am amazed at how quiet the interior is but how they are fairly loud on the outside. they turned out to actually have the terminator series internals but were still cased and labeled as the raptor series. so 80 buck mufflers for 25$ ? yes please. not sure if they all are like that but i would expect so.
2 inch add a leaf, bilstein 5100 shocks, 33" hankook dynapro mt's, flowtech headers true duals and terminator mufflers, 35w and 55w 6k hid headlights, 35w 3k foglights, complete led conversion, 2 kicker cvt 12's, soundstream rub5.800 amp, soundstream speakers
guitarfreak235 is offline   Reply With Quote
