Old 01-29-2013, 10:24 AM   #26
xpickup
xpickup's Avatar
Re: 1951 Chevy / C4
48 GMC BURB, Thank you. Glad you like it. I thought the front suspension was the earlier one.
98layinframe, I built the whole bender and the dies. It has a 20 ton air over hydraulic cyclinder so you just hold the trigger. Yes, I cut both sides like that and it slid right up. That was after I had my boxing plates in.
Shannon
xpickup is offline   Reply With Quote
Old 01-29-2013, 02:38 PM   #27
Larry Lindley
Re: 1951 Chevy / C4
Shannon very good job.I guess this is a 24 pack job,ha ha.I need to work on mine,its hard to find someone too Tom Sawyer into doing it for me.
Larry Lindley is offline   Reply With Quote
Old 01-29-2013, 10:01 PM   #28
99 to Life
99 to Life's Avatar
Re: 1951 Chevy / C4
subscribed,
jeeesh you make it look like you do this for a living. luv it
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 01-30-2013, 09:24 AM   #29
xpickup
xpickup's Avatar
Re: 1951 Chevy / C4
Larry Lindley, Thank you. Believe it or not I have not drank a bit yet!
99 to Life, Thank you. Each build I do seem to kick it up a bit. Always learning. This is the first corvette suspension I ever did. It is amazing how many things that need to be looked at for the rear suspension. I spent the evening looking up different things with it last night.
Shannon
Old 02-01-2013, 10:21 PM   #30
xpickup
xpickup's Avatar
Re: 1951 Chevy / C4
The temperature was around 27 today and windy as hell so when did I decide to measure a corvettes suspension? I spent a half hour measuring and checking the angles on it. Then went to my buddies who has a rotex hole punch. I punched out some blanks to fill all the holes in the frame. Then coped and tacked in the upper layer of the transmission cross member. I did not have the transmission so I made a 1/4" plywood template so I could check for the fit. Tomorrow I am going to start bending the lower layer.
Shannon
Old 02-02-2013, 01:38 AM   #31
oldman3
oldman3's Avatar
Re: 1951 Chevy / C4
I see lots of welding in you future....Jim
oldman3 is offline   Reply With Quote
Old 02-02-2013, 09:34 AM   #32
chev3600
chev3600's Avatar
Re: 1951 Chevy / C4
163, 164, 165....., wait, you missed a hole.
1949/1954 with LS swap-yeah!
http://s260.photobucket.com/albums/i...0/AD%20trucks/jumbled mess of unorganized photos
chev3600 is offline   Reply With Quote
Old 02-02-2013, 11:54 AM   #33
98layinframe
98layinframe's Avatar
Re: 1951 Chevy / C4
Sooooooo many holes. Good lord why?!?!? Haha
91 s10 - bagged bodydropped 4", 350/700R4, narrowed reared, cantilever rear air bag setup
1951 chevy 3100 - in build/acquiring parts process. Have full C4 Corvette suspension front and rear, tpi 350, 700r4, 18" torque thrust II wheels
98layinframe is offline   Reply With Quote
Old 02-02-2013, 12:22 PM   #34
99 to Life
99 to Life's Avatar
Re: 1951 Chevy / C4
looking good, is this getting a v8? you gonna fab your own mounts?
Old 02-03-2013, 04:49 AM   #35
solidaxel
solidaxel's Avatar
Re: 1951 Chevy / C4
Subscribed, to another great build !!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 02-03-2013, 11:32 AM   #36
xpickup
xpickup's Avatar
Re: 1951 Chevy / C4
oldman3,chev3600,98layinframe, No doubt. I do not know what they were thinking when they put them all in. The blanks will make it a little easier. I use a magnet to hold them in while I tack them. Then remove it and weld them up.
99 to Life, Yes, it is a LT1 and I am sure I will make the motor mounts. That will be a little yet .The rear end install is going to be very soon.
solidaxel, Thank you . Hope you enjoy.
Worked on it for 2 hrs yesterday and I bent one lower and coped in the spacers. Then this morning bent the other one, fit tem and tacked it all in. It gets a lower cross brace for a drive shart loop yet. I think it looks killer. I told my wife, boy if I could change mine to be like this, and she just looked at me. Here are some pictures.
Shannon
Old 02-03-2013, 12:17 PM   #37
99 to Life
99 to Life's Avatar
Re: 1951 Chevy / C4
looks great built like a brick house
Old 02-03-2013, 03:56 PM   #38
oldman3
oldman3's Avatar
Re: 1951 Chevy / C4
Shannon, super nice bud....Jim
Old 02-03-2013, 04:12 PM   #39
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Re: 1951 Chevy / C4
Nice work, I'll definetly enjoy watching this one come together!
ChuckDriver is offline   Reply With Quote
Old 02-04-2013, 03:40 AM   #40
48 GMC BURB
48 GMC BURB's Avatar
Thumbs up Re: 1951 Chevy / C4
Shannon
Your work is first class !!
48 GMC Burb
51 Chevy AD 3100/C 4 byShannon
74 Chevy P 10
48 Double Duty
04 SS Burb
01 Springer HD
48 GMC BURB is offline   Reply With Quote
Old 02-10-2013, 09:06 PM   #41
xpickup
xpickup's Avatar
Re: 1951 Chevy / C4
99 to Life, oldman3, ChuckDriver, Thank you
48 GMC BURB, Thank you. I hope you like it, seing how it is yours. HAHA
Well here is the lastest. I boxed the rear 8" of the rear section of the frame and put a 1 5/8 tube across the back. Then got ride of the factory rear cross member. THEN welded in slugs for the 5 million factory holes on the sides of the frame. Fixed the slots that I cut in the frame to get the front cross member in and finished welding it in. Then cut back the radiator support and got rid of the back portion. Boxed the frame from were I stopped to the radiator support. Then cut out the rack cut outs. Once that was cut I did not like that the cross section of the frame, it was only a little over 1". So I bent up some 1 5/8 at a 90 degrees and cut it back to fit from the bottom of the cross member to the bottom of the radiator support. Now it is strong again. I thought if you would hit something (god forbid) the front section of the frame would fold under. So now onto the rear suspension. I have to make some pieces to recontour the frame rails for the suspension. I can not wait to see it on its wheels.
Shannon
Old 02-10-2013, 09:08 PM   #42
xpickup
xpickup's Avatar
Re: 1951 Chevy / C4
Some more.
Shannon
Old 02-11-2013, 12:38 AM   #43
oldman3
oldman3's Avatar
Re: 1951 Chevy / C4
Shannon, you are doing some great fab work there my friend, just great...Jim
Old 02-12-2013, 02:15 AM   #44
48 GMC BURB
Re: 1951 Chevy / C4
Originally Posted by xpickup View Post
Some more.
Shannon
Shannon ...AKA Metal Master
You continue to amaze..
Let me know how much room there is for the gas tank
& I'll start looking for one, unless you make them too LOL
48 GMC Burb
74 Chevy P 10
48 Double Duty
04 SS Burb
01 Springer HD
Old 02-12-2013, 09:24 AM   #45
SSABMUD
SSABMUD's Avatar
Re: 1951 Chevy / C4
Nice work Shannon. I am getting close to tear down on my 52 and boxing the frame. There are a lot of holes on an S10 frame also. Not looking forward to it. I know that when the truck is done and I am telling people about the truck, 95% will not even look under the truck!
Wade
SSABMUD is offline   Reply With Quote
Old 02-13-2013, 10:19 PM   #46
xpickup
xpickup's Avatar
Re: 1951 Chevy / C4
oldman3, Thank you.
SSABMUD, They do put enough holes in them. I punched out slugs and it made it go easy. Either unibit or die grind the holes to get the rust out and they weld in good. I used a magnet to hold the slugs. It was not as bad as I thought it was going to be. But yes I know wht you mean, they will not look. And they probably will not even realize they were holes there. Your truck looks great. I love all the suttle modifications you did.
48 GMC BURB, HAHA I do love work with it.I should know how big of one after the weekend. I can make one if you want, either out of steel or SST. I can put baffles in it and TIG weld it together.
Last night I figured out what I have to do with the frame. I will raise it up about 4.5 inches so that I can keep my 6 inch ride height. I am going to make it out of 1/8 plate and weld it all together. That way I can keep it the same width of the factory frame. The front section will taper from 6" to 4" and the rest will be 4". I will use 1 5/8 tube for the cross braces and tie in the rear end nose mount also. Then try to tie into the transmisson cross member.
Shannon
Old 02-13-2013, 10:41 PM   #47
Wheelie
Re: 1951 Chevy / C4
Chassis fab looks great, I recently got my own bender at the house. I plan on doing a similiar design. Your good inspiration!
My '59 Build Thread
Wheelie is offline   Reply With Quote
Old 02-14-2013, 12:08 AM   #48
99 to Life
99 to Life's Avatar
Re: 1951 Chevy / C4
looking sweet as always. How many hours you got in her so far? Can't wait to see her all back together.
Old 02-14-2013, 12:36 AM   #49
4544speed
4544speed's Avatar
Re: 1951 Chevy / C4
That fab work looks great!! Looks like you have really added some rigidity to the frame. Man, I hate to even post my crap after seeing this
4544speed is offline   Reply With Quote
Old 02-14-2013, 12:39 AM   #50
oldman3
oldman3's Avatar
Re: 1951 Chevy / C4
Looks good, can't wait to see the new stuff made up...Jim
