Old 01-30-2013, 06:44 PM   #1
flyingbrian
1987 crew cab question dually
What is all involved in switching from a 1987 chevy grill set up to a 1989-1991 set up? I have been told I will need to change the radiator support. Will the fenders have to be changed? Also can I do this switch without removeing the fenders and hood? This is a big block truck with air. If the radiator support has to be changed, are they different for air and non air trucks?
flyingbrian is offline   Reply With Quote
Old 01-30-2013, 07:13 PM   #2
cdm10700
cdm10700's Avatar
Re: 1987 crew cab question dually
you do have to change the radiator support fenders are the same i dont think there is a difference in air non air and not sure how difficult it would be with fenders still on truck
cdm10700 is offline   Reply With Quote
Old 01-30-2013, 07:23 PM   #3
cory d
cory d's Avatar
once you have the core of ten the fenders will only need a few more bolts to come off so you might as well get on out of the way
cory d is offline   Reply With Quote
Old 01-30-2013, 09:07 PM   #4
LOW1TON
We just did this swap on a friends truck and we did it without taking the fenders off. Just loosened them up and slid the core support out and the new one back in. Did not even take off the front bumper.
"WIDER IS BETTER" (TRUCKS ONLY)
LOW1TON is offline   Reply With Quote
Old 01-30-2013, 10:18 PM   #5
meatwagon83
meatwagon83's Avatar
i was gonna answer but there is nothing more to be said!
meatwagon83 is offline   Reply With Quote
Old 01-30-2013, 10:37 PM   #6
jitteryguy
GoatLube Experss
jitteryguy's Avatar
my Girlfriend swap'd one on my carhauler while I was outa town, pretty easy.
you will need the wire harness from the new core support and graft it to the exist'n wire'n harness, color's all match just some simple splice's.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 01-31-2013, 11:13 AM   #7
Desert1957
Desert1957's Avatar
Nice having someone into your trucks that can also turn wrenches , Mine thinks I love my squares more than her!
Desert
Desert1957 is offline   Reply With Quote
Old 02-02-2013, 05:13 AM   #8
kevinr1970
Don't forget to grab the piece that goes fender-to-fender that is almost behind the bumper. It is painted body color.
The headlight bezels for the 89-91 style mount to that differently than the 81-88 style.
Not a big deal, but if you don't have it you will not have a place for the bottom mounting screw for the bezel.
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
