#126 |
Re: 1968 Chevrolet SWB Stepside Restomod
I can understand about being stoked about getting a perfect or even near perfect original part as they don't come along very often. I just got my hands on a near perfect right inner fender and we all know how bad these can get. This one only has a small spot of paint missing and a very small hole about half the size of a dime. I am going to cut out and butt weld in a 1/2 by 1 inch square to have a rust free original inner fender. So Xeen I understand about the mint door.
#127 | |
![]() Join Date: Aug 2012
#128 |
Good luck with that cab as I drove almost two hours to get a really nice cab only to find one that the rain gutter was rusted through the entire cab the firewall rusted out and cab corners and floor rusted out pretty good, so really hope it is what they say it is.
#129 |
Small update.
I picked up a pair of 15x7 Rallys and a Drivers side door. Then I ran down to sears and had them mount the Eagle GTII tires I bought awhile back, so now I have a matching set of good rims and tires on all 4 corners. |
#130 |
Good I am glad that you like the rims and tires. Sometimes you like the rims. Sometimes you like the tires but there is sometimes they don't go tother. Happy building.
#131 |
Progress!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
#132 |
I'm at a awkward point in the build, I need that rear suspension crossmember frame section welded in so I can instal the C-Notches, rear sway bar, and bent style Trac bar.
Fortunately it's not so rotted out that it can't be driven. I need to decide what I'm doing about a wiring harness. I'm still searching for an engine and transmission, it's alot harder to find a 2001-2002 Vortec 5.3-6.0L with mechanical throttle with under 60,000 Miles than I thought it would be. I feel kinda stuck at this point, I need some inspiration. |
#133 | |
![]() Posted via Mobile Device
68 ![]() My other ride ,,, 07 Streetglide.. |
#134 | |
Best Regards, Leon M. Instagram: @TheDirtyDianah
Bagged | 6.0L LS | T-56 (6-Speed Manual) | Turbo Burnout/Rolling Video: Chevy C10 Stepside 6.0L LSx & 6-Speed Manual |
#135 |
Ok I know I don't do pictures as often as I should.
Here you go boys feast your eyes! Stainless Steel Coolant Overflow Tank. ![]() Stainless Steel Brake Lights and Brackets. ![]() Stainless Steel Sill Plates. ![]() Stainless Steel Radiator Cover. ![]() Stainless Steel Core Support Filler Panels. ![]() Polished Aluminum Grill Hoops. ![]() ![]() |
#136 |
Well hell, today was a dissapointing day, I was all excited because this guy made all these claims saying he had a complete 2002 <60k miles Vortec 5.3L with transmission, wiring harness, ECU and the provinance, and it was near Vic in KC so off he went to check it out for me and he gets down there and the place is a hole in the wall rats nest, the guy didnt have what he claimed he had and Vic left with the oppinion that the guy was a pathalogical liar, so long story short no engine, no transmission, no fun.
Vic just saved me from a $1200 mistake, if this were a mastercard commercial a buddy like Vic is priceless. Last edited by Xeen; 08-05-2014 at 09:07 AM. |
#137 |
Quick update.
The end of my day was better than the first part of it, I recieved the tracking number for my Genuine GM truck tilt column and it will be delivered Friday. Hell yeah! ![]() |
#138 |
Major Update.
I purchased a 53k miles Vortec 5.3L w/Aluminum heads complete pullout including 4L60E, complete Wiring Harness, ECU, Exhaust Manifolds, transmission lines, all bolts, totally complete from the radiator, to the driveshaft, nothing cut, all unbolted pulled out of the same truck. It will be delivered to me the middle of next week. I couldnt be more pleased, I will post pictures when it arrives. ![]() |
#139 | |
#140 |
Another update.
I bought an Engine stand, and Ordered a EFI Stealth - bed fill fuel tank from Boyds welding. 1/2 Ton capacity Engine stand. ![]() |
#141 |
Can't wait to see the motor when it arrives. Looks like the fun is about to begin.
#142 |
The 1971 GM Tilt Column arrived today.
It needs a few parts which is to be expected, Turn signal switch, Canceling cam, Horn contact kit, adapter retaining nut/washer and rubber floor seal. ![]() |
#143 |
Steering Column update.
It turns out my steering wheel adapter came with a horn contact kit, then I went to the hardware store and bought a 1/2"-20 flange nut, and the proper machine washer. Now I just need to order the rest of the parts I need from Classic Industries. |
#144 | |
#145 | |
![]() Join Date: Mar 2012
Victor 57 Chevy Wagon - California Dreamin'"Mecum'd" 9/2022 Dallas, TX Crusty Rusty Leaky Squeaky 67 Consigned 4/2019 Dresden, Germany Maybelline - my '57 Ford 2dr Sedan "Mecum'd" 3/2016 Location unknown Silver Streaker "Mecum'd" 4/2013 Somewhere in Texas |
#146 | |
Whats crazy is I have to dissasemble the entire tilt assembly just to change out the turn signal switch, doesn't that sound like fun? |
#147 |
Congrats on the purchase
#148 |
I went to LMC Truck in K.C and picked up my tilt steering column parts, I'm not happy with the aftermarket turn signal switch, the Hazard knob isn't removable I recommend going with #1893596 from Classic Industries instead if you need to replace yours so you can use the stock, or billet Hazard knob.
It turns out the Horn contact kit that came with my steering wheel adapter doesnt work with the stock tilt canceling cam, sigh its one thing after another...so I need to do some research and figure this out. Last edited by Xeen; 06-29-2014 at 11:21 AM. |
#149 |
Brian, try this tilt column link. It has exploded views and instructions.
#150 |
Taking steps! Sounds like good progress. Keep after it.
Tags |
1968, chevrolet, restomod, stepside, swb |
