Old 01-31-2013, 04:17 AM   #1
Scott>72-GMC
Scott>72-GMC's Avatar
Alternator bracket ??
I'm wondering what the correct alternator bracket is I jimmied this one on cause the one it came with didn't allow any adjustment but this one slams it against the valve covers. It's a 72 3/4 ton gmc not original engine I'm not sure what year it is Do you have pictures of your set ups ?? Thanks
Scott>72-GMC is offline   Reply With Quote
Old 01-31-2013, 04:20 AM   #2
Scott>72-GMC
Re: Alternator bracket ??
Old 01-31-2013, 06:28 AM   #3
JimKshortstep4x4
Here is a picture of a stock 72 setup.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 01-31-2013, 09:17 AM   #4
sanford&daughter
sanford&daughter's Avatar
Cant see your lower bracket but the upper is not an original it looks like a universal mr gasket
sanford&daughter is offline   Reply With Quote
Old 01-31-2013, 10:35 AM   #5
hayhauler71
hayhauler71's Avatar
no ac
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 01-31-2013, 11:49 AM   #6
Scott>72-GMC
I believe the bottom is correct but the top that it came with did not seem right at all. The one that's there I put on just to get it home.
Old 01-31-2013, 11:49 AM   #7
Scott>72-GMC
Is there a diffrence with/ without ac mine has ac
Old 01-31-2013, 12:24 PM   #8
Andy4639
Old member
Andy4639's Avatar
Wink Re: Alternator bracket ??
I don't know if it's correct year are not but it works fine and I have AC. I have spacers to make it line up correctly also. Been like this for 15 years with no belts ever being thrown off.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 01-31-2013, 12:29 PM   #9
Scott>72-GMC
I'm not really going for year correct. From what I'm seeing. I'm thinking they had to short of a belt on cause it pulled the alternator clear back against the valve covers with no adjustment
Old 01-31-2013, 10:42 PM   #10
RHGuyettejr
RHGuyettejr's Avatar
If you are using that bracket, go to autozone, or advanced auto and have them reference the belt #, there are 2 options, go with the one that is like 1/2" longer. I can't remember what the length was (I want to say 50 something inches?) I just did this too. My po had one that was way too long on it. I got the longer belt and there is just enough slack to get it on with the alternator against the valve covers, then adjust it out.
Sorry that's the best pic I have right now.
RHGuyettejr is offline   Reply With Quote
Old 01-31-2013, 10:48 PM   #11
Scott>72-GMC
If you can see the bolt hole at the front of the manifold that is where the po had the bracket mounted which from ur guys pictures is wrong for this year guessing it was an 80s engine
72 GMC super custom.
