Old 02-01-2013, 08:24 PM   #1
Don Quixote
Don Quixote's Avatar
3/4ton Rear End Swap Questions
My '72 C25 has a 14-bolt sf rear (9.5") with 3.73s and I am looking into swapping in a 14-bolt ff rear (10.5"), maybe with 4.10s as I am also contemplating a ranger box as well. I have found a duelly in a '91(?) but I don't know how much trouble I will have with the swap or should I keep looking for a single. I tow a lot with this truck but I want to keep it a single. Any advise would be helpful.
Rocinante: 1972 GMC C25, 292, SM465, 14 bolt, power nothing, 440k and still handles my PCS moves
Jorge: Kia Roller-skate with lots of buttons for the wife
Wovoka: 2017 Indian Chief Vintage, better on gas but not much
So far, this is the oldest I've ever been.
Don Quixote is offline   Reply With Quote
Old 02-02-2013, 11:14 AM   #2
Mike C
Mike C's Avatar
Re: 3/4ton Rear End Swap Questions
Look for the single wheel. Unless you need the extra gear, I'd stay with what you have persoanlly. The 9.5" semi-float is a pretty stout axle and at least up to par with the rest of a 67-72 truck in terms of load carrying.
But if you are going to do it, definitely get the single wheel, and look for the one with the bigger brakes.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-02-2013, 02:00 PM   #3
Don Quixote
I have to admit that that rear pulls my 15000 lb trailer cross country like a champ but I worry about the bearing supporting the weight that wouldn't be an issue with a full floater. I am getting a bit of a coast vibration but nothing major yet. Thanks for the input. I didn't realize that the duelly rear was that different..
Old 02-02-2013, 08:17 PM   #4
Mike C
Mike C's Avatar
A dual wheel 14 bolt is from a cab and chassis truck which is a little different than the true dually axle which will be a Dana 70 HD. The C&C 14 is not as wide as the dually axle, but the 70 is way too wide for a single wheel use.
I have a semi-float 14 in my Jimmy and it is leaps and bounds ahead of the 12 bolt it replaced.
44 Willys MB
52 M38A1
64 Corvette Coupe
